12-26-2011, 12:02 PM | #101 | |
Pebble Pounder Join Date: May 2009 Location: Northern Virginia, USA
| Re: Best XR10 Wiring Jobs... Quote:
12-27-2011, 03:17 PM | #102 |
Pebble Pounder Join Date: Mar 2011 Location: Calgary, Alberta
Yes but remover the batteries the comp guys are running are normally a max of 900mah. Running a 45c pack will only put out 40.5 and you will probably never get to that,
12-27-2011, 04:34 PM | #103 |
Quarry Creeper Join Date: Jul 2009 Location: UTAH
So here is my xr10, it has dual tekins a cc bec and a futaba reciver, i was able to fit the tekins and and my bec in the axial case with the reciver right behind the box, i also put the wire stuff on all the exposed wires. let me know what you think. |
12-28-2011, 12:32 AM | #104 | |
Newbie Join Date: Oct 2010 Location: Alicante
If the 90% of the time in a course i'm going below 20 Amps, there is no reason to use big wires. Anyway, as the 900mAh 45C lipos can't punch over 40A, the max voltage droop must round 7% with 20 AWG. Therefore using 16-18 AWG semms to be the more weight-vdroop balanced option. ¿What AWG comes with the fxr's? I'm using these. | |
04-18-2012, 12:31 PM | #105 | |
Pebble Pounder Join Date: Mar 2012 Location: Visalia
They cannot efficiently dissipate heat in an enclosed plastic box. | |
04-18-2012, 12:44 PM | #106 |
This is the most compact tray I could come up with while allowing heat to dissipate efficiently and allowing full view of the ESC indicators. The caps are actually used to operate the INC buttons and the dean plugs fit right into the ESC post slots. The battery (not shown) is mounted at a 45 degree angle between the front upper shock mounts. It makes it super easy to remove/insert from above. |
04-18-2012, 01:41 PM | #107 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
Heres some of my work that I offer to people. Link to my services: Official Custom ESC wiring thread. FXR Shrink and thread: Tekin FXR Shrink Thread rbgerrish wire job: Ryan B. Gerrish Gets Super Smashed! House: House's Generic Ti-Fighter XR10 with mamba micro pro's Spiffy XR10 Electronics shrinkage TheSCorpionKing |
04-18-2012, 01:54 PM | #108 |
Here's my electronics package for my Rockshow SS. Castle BEC (2) Mamba Micro Pros Futaba Receiver Chris The Battery Man's By Pass connector. Power leads are soldered to the motors. The ESCs have both servo tape and wire to tie them down to the skid. I cut recesses into the bottom of the skid top conceal the wire from the rock. They are very stable and aren't effected by connecting and disconnecting the battery plug. Last edited by Stormin2u; 04-18-2012 at 01:57 PM. |
04-18-2012, 03:09 PM | #109 |
| Re: Best XR10 Wiring Jobs... |
04-18-2012, 04:57 PM | #110 | |
I love how you have the bec wired into the vacant batery posts, but where'd the bec cap go? | |
04-19-2012, 06:24 AM | #111 |
04-19-2012, 07:32 AM | #112 |
Quarry Creeper Join Date: Sep 2008 Location: Isle of Man
Would you even need the cap on it if you reconfigured the two ESC's & CCBEC so there was only one larger cap?
04-19-2012, 08:42 AM | #113 |
Quarry Creeper Join Date: Oct 2011 Location: Detroit
Beautiful, but how the eff does that fit into an XR10 rig? Sent from my DROID2 using Tapatalk 2 |
05-23-2012, 08:47 PM | #114 |
Pebble Pounder Join Date: Jan 2009 Location: Olympia
This thread is way old! I just got my ems pliers and futaba connectors, I'm ready to do work! This thread has some sick wiring jobs!
05-23-2012, 08:58 PM | #115 | |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
i'll post my wiring after i get my electronics plate. or you can check out my youtube to see my build videos, there's one showing hwo i squashed the 2 sidewinder micros, and where i hid the bec... info is in my signature. | |
05-25-2012, 05:21 PM | #116 |
I'have made a new layout for the elctronics. All but the TX is foward the front link screws in the skid. I've moved the bec under the servo and i've removed all the innecessary wires. Now i have the same bias than before when i wear more weight in the knukles. I've welded inside the esc's the power switch and i don't see this cuted wire anymore. Now, the front motor wires are short and the rears are very long!!! All the wires to the receiver goes by the same side and together and i think i've archieved a clean job: |
05-25-2012, 05:30 PM | #117 | |
05-25-2012, 07:01 PM | #118 |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
2 Mamba Micros, BEC. RX/BEC bypass adapter, 16 gauge TQracing wire. and a Futaba R614FF Rx. Done by Chris |
05-25-2012, 07:06 PM | #119 |
crappy joke about big cap[/insert]
06-01-2012, 05:46 AM | #120 |
Rock Stacker Join Date: Jun 2009 Location: Denmark
Here is my attempt. |
