05-11-2011, 03:37 AM | #101 |
Build looks great Jake! Nice line in that video, not bad for the stock chassis Body looks killer |
05-11-2011, 04:24 AM | #102 |
Nice line Jake! Haha....no controversy....I kind of figured he was joking (especially after seeing HN's location), but sometimes it is hard to read intonation on a BB. |
05-11-2011, 04:46 AM | #103 |
Quarry Creeper Join Date: Aug 2009 Location: Heilbronn/Germany
Nice vid ... nice rig ... only a bit tuning and testing and you can send it to me |
05-11-2011, 09:05 AM | #104 | |
05-11-2011, 12:04 PM | #105 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
05-11-2011, 12:04 PM | #106 |
Rock Crawler Join Date: Jul 2008 Location: Hesperia
05-11-2011, 12:06 PM | #107 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
| The same thing we do every night Pinky....TRY TO TAKE OVER THE WORLD.
05-11-2011, 12:17 PM | #108 |
Rock Crawler Join Date: Jul 2008 Location: grand rapids, bay area, nyc.
Looks good man can't wait for more of your updates! Good luck in your tuning/ upcoming comps |
05-15-2011, 09:40 AM | #109 |
Newbie Join Date: Sep 2008 Location: jackson
any new updates??
05-15-2011, 11:10 AM | #110 |
He's out testing today...working on suspension setups & such so I'd expect to see some updates later today or tomorrow.
05-15-2011, 03:35 PM | #111 | |
First off, I installed some Vanquish bling Full axle cases, Zero Ackerman knuckles, Chubs, and upper link mounts F/R. I know that its pretty much common knowledge now... but holy hell these parts are nice With all this bling, I had to make a better looking battery tray. I started with some 1/2" x 1/2" Aluminum angle and the CF "tongue" that I cut off of the Axial electronics tray. Same as before, I drilled a single hole in the axle case and threaded in a 3mm screw. If you put the hole in the right place, there is enough room inside for a low-profile 3mm locknut. Here's the finished product | |
05-15-2011, 04:02 PM | #112 |
I wasn't very happy with the way the front suspension was cycling in testing, so I tried a few things with it that seems to have made a big improvement. First off I tried Brandon's front shock setup. I used the stock front link/shock mounts and bent up Ti lowers. I started with 92mm straight Ti links before the bend, and ended up with 74mm between the rod ends, the same as the stock front lowers. I settled on 2-hole pistons with 22.5wt oil and an 8mm external limiter for the front shocks. This may change once I get more testing on some big vertical stuff, but so far this setup feels really good. You can also see where I added an extra mounting hole in the chassis. With the links mounted in the highest hole on the VP front link mount, the truck needed more link separation at the chassis. With this setup, I added a 6mm spacer to each upper link to clock the axle back up to where it started. The battery tray is a tight fit with an 3S 860 pack, but the little 430 fits with tons of room to spare. You guys will have to ignore the messy wiring for now, I'll tidy everything up once I get my Futaba gear installed. |
05-15-2011, 04:10 PM | #113 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
Looks good Jake. How smooth is it with thee front shocks on that angle?
05-15-2011, 04:14 PM | #114 |
That Skippy jar didn't have a chance. Looking good buddy. Are we gonna see some tungsten anytime soon?
05-15-2011, 04:32 PM | #115 | |
Already playing with a few ideas Although I don't think this truck will need as much weight down low as my Losi did | |
05-15-2011, 06:02 PM | #116 |
Quarry Creeper Join Date: Dec 2010 Location: Earth
05-15-2011, 06:04 PM | #117 |
Quarry Creeper Join Date: Jan 2011 Location: Spokane
Moves the servo horn closer to the tire and less likely to get hung up on a rock.
05-17-2011, 07:04 PM | #118 |
Pebble Pounder Join Date: Jan 2009 Location: sandiego
Looking good Jake can't to see it work at the az shoot out |
05-17-2011, 08:23 PM | #119 | |
RCC Addict Join Date: Jun 2009 Location: California
surprisingly makes it even smoother. | |
05-17-2011, 08:36 PM | #120 |
