06-19-2012, 06:24 PM | #241 | ||
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
| Re: Del Monte's Secret Agent build Quote:
Here's a better picture that shows my link and shock positions. I am running the rear shocks all the way out on the chassis, and the fronts in one hole from the outside. The front and rear links are mounted one hole from the top f/r on the chassis, and on the middle holes on the VP upper link mounts. I still have a 3mm spacer under my front link mount, so this roughly works out to running the top hole on the VP mount without spacers underneath it. I'm very pleased with how my skins from Krawler Konceptz held up. I'm only running .015" lexan panels, but since the skins are inside the panels, it hides how much time I actually spent on my lid at PCC Last edited by Del Monte; 06-19-2012 at 06:40 PM. | ||
06-19-2012, 06:32 PM | #242 |
Man our setups are very similar. You will be suprised how much little weight gain there is in the Y-Town wheels to the plastic wheels. |
06-19-2012, 06:56 PM | #243 |
I wanna be Dave Join Date: Dec 2008 Location: ?
| Re: Del Monte's Secret Agent build I was using the stock hex's.
06-19-2012, 07:20 PM | #244 |
| Re: Del Monte's Secret Agent build Have you ever thought about using an epoxy to secure the hexes? I have beat on my plastic HPI's with epoxied hexes and I've had zero failures to date.
06-19-2012, 07:59 PM | #245 |
| Re: Del Monte's Secret Agent build |
06-20-2012, 01:10 AM | #246 |
RCC Addict Join Date: Dec 2009 Location: Newcastle, Australia
| Re: Del Monte's Secret Agent build I was running the mrc silvers in the rear and mini silvers up front, rig just didnt feel right since dropping weight from 2300g to 1900g so a few days before the comp i swapped to mini silvers all round, now it feels far more settled and just flat out works.. dropped my oil to 35wt/r 25wt/f but will goto 35wt all round |
06-20-2012, 05:35 AM | #247 |
06-20-2012, 06:08 AM | #248 |
06-20-2012, 08:34 AM | #249 |
Rock Crawler Join Date: Oct 2010 Location: Switzerland
Great Job on PCC Jake Do you have a messurement of your front lowers?? eye-to-eye? |
06-23-2012, 11:47 PM | #250 | ||
My front lowers are 121mm eye to eye. 95mm Lunsford link + Losi 17* bent rod end + Losi straight rod end. | ||
06-24-2012, 01:11 PM | #251 |
Are these axle all plastic's?
06-24-2012, 02:50 PM | #252 |
Quarry Creeper Join Date: Sep 2008 Location: Isle of Man
| Re: Del Monte's Secret Agent build Looks like it |
06-24-2012, 07:07 PM | #253 |
Rock Crawler Join Date: May 2007 Location: Salt Lake City
Good job! Truck looks great and I can imagine after you get some drive time on this thing you'll be unstoppable. I also have the same problem tipping over allot and have contemplated switching back to bodied but the body less looks so cool. I admire your building and drivin style. |
06-25-2012, 08:08 AM | #254 | |
Rock Stacker Join Date: Mar 2012 Location: Carson City
06-25-2012, 08:59 AM | #255 |
| Re: Del Monte's Secret Agent build It doesn't have a tip over problem and It was actually designed to tip back on its wheels better than the previous versions but like any body less chassis when you tip over in sand or flat ground it is harder to get back on the wheels than with a body.
06-25-2012, 09:22 AM | #256 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Caption Contest...
...cause this build thread collects a lot of dust from lack of traffic. J |
06-25-2012, 09:48 AM | #257 |
Rock Crawler Join Date: Mar 2008 Location: amherst, ny
^^^ Watch this guys... i swear its so good it will drive itself!!
06-25-2012, 06:08 PM | #258 |
Rock Crawler Join Date: Aug 2010 Location: Martinique
Hey Jake, Looks like you're not using the axle tops neither in the front, nor the rear. Am I right, M. Wright ? I mounted mine focusing on your test and added 110mm lunsford on for uppers both sides... My SA seems to work and I just have to improve my driving skills. Thanks for any input ! Emmanuel. |
06-25-2012, 06:23 PM | #259 |
06-25-2012, 08:51 PM | #260 | |
I'm glad the SA is working for you... just wait until you get some drive time on it | |
Del Monte's Secret Agent build - Similar Threads | ||||
Del Monte's XR10 Build #1 | Del Monte | Axial XR10 | 619 | 12-16-2014 09:10 AM |
Del Monte's '07 Falcon | Del Monte | Tamiya TLT Crawlers | 48 | 07-26-2012 07:19 PM |
Featherweight Secret Agent 3.5 Bodiless Build | 4xFord | Axial XR10 | 241 | 06-20-2012 05:43 AM |
Del Monte's MRC | Del Monte | Losi Mini-Rock Crawler | 18 | 04-23-2010 09:24 AM |
Del Monte's Banana Tuber | Del Monte | Tamiya TLT Crawlers | 11 | 07-27-2008 01:43 PM |
