05-29-2012, 01:12 PM | #141 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Re: Del Monte's Secret Agent build |
05-29-2012, 01:16 PM | #142 |
05-29-2012, 01:17 PM | #143 |
05-29-2012, 01:37 PM | #144 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
You can make your own...it's the easiest thing in the world...and cheap! Buy this: DELRIN TUBE #1830T119 (5FT.) and this: 3MM TAP #8305A32 You can use a small tubing cutter (any hardware store will have this) Cut your length, put the tap in a drill...tap both ends...done! Last edited by TURBOFEST; 05-29-2012 at 01:40 PM. |
05-29-2012, 01:49 PM | #145 | ||
| Re: Del Monte's Secret Agent build Quote:
Thanks for the info but I got it figured out now Thanks to Jeremy's great service and fast response | ||
05-29-2012, 01:51 PM | #146 |
05-29-2012, 02:20 PM | #147 |
05-29-2012, 05:47 PM | #148 |
05-29-2012, 05:57 PM | #149 | |
And that's debateable Last edited by TSK; 05-29-2012 at 06:25 PM. | |
05-29-2012, 06:00 PM | #150 |
^ Damn your good! |
05-29-2012, 06:06 PM | #151 |
05-29-2012, 06:26 PM | #152 |
05-29-2012, 10:04 PM | #153 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
| Re: Del Monte's Secret Agent build I ended up mounting the shocks to the inside of the double shear tabs f/r. I am using the Dlux upper shock mounts, and the shocks felt like they would bind up unless mounted almost vertically. With the shocks inside the tabs, everything is smooth and bind free throughout travel. |
05-29-2012, 10:08 PM | #154 | |
05-29-2012, 11:47 PM | #155 |
I wanna be Dave Join Date: Aug 2008 Location: Having fun again...
| Re: Del Monte's Secret Agent build i think that makes sence... |
05-30-2012, 05:47 AM | #156 | |
05-30-2012, 09:27 AM | #157 |
Rock Stacker Join Date: Feb 2010 Location: Manila
So I finally pulled the trigger and purchased the SA3.5. Will my Delrin lower links from Crawler Innovations still fit on this chassis or do I have to purchase new titanium links also?
05-30-2012, 11:11 AM | #158 |
Big bores don't leak only if you screw them on finger tight. (Thanks Joel) Looking good Jake. Wish I could have saw it in action a little, it looked good going through gate one and nearly taking out my ankles. Any pics of a bottom shot to see the secret link bends... |
05-30-2012, 02:51 PM | #159 | |
05-30-2012, 02:58 PM | #160 |
Del Monte's Secret Agent build - Similar Threads | ||||
Del Monte's XR10 Build #1 | Del Monte | Axial XR10 | 619 | 12-16-2014 09:10 AM |
Del Monte's '07 Falcon | Del Monte | Tamiya TLT Crawlers | 48 | 07-26-2012 07:19 PM |
Featherweight Secret Agent 3.5 Bodiless Build | 4xFord | Axial XR10 | 241 | 06-20-2012 05:43 AM |
Del Monte's MRC | Del Monte | Losi Mini-Rock Crawler | 18 | 04-23-2010 09:24 AM |
Del Monte's Banana Tuber | Del Monte | Tamiya TLT Crawlers | 11 | 07-27-2008 01:43 PM |
