06-04-2012, 10:05 AM | #181 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
| Re: Del Monte's Secret Agent build Yeah...we're talkin the difference between a buncha LCC's & a few older 7lb Bergs tryin to getta run at this thing & todays rigs. Im sure even with a well built XR...It isn't an EASY climb but like ol Tomer said...probably a lot more doable. Jake knows that desert like the freckles on his....um...hand so Im SURE he's got another gnarly bounty something or other for us. If your club hasn't done this...its a blast. I think we did $1.00 buy ins? Ya get ONE shot. 1st penalty & your turns over. The pot grew FAST & it was fun to cheer, laugh & get pissed at the failed attempts. Jake also threw in a set of Boss Claws to sweeten the pot. Not sure what the cash made it up to but it was a stack of bills & even a pile of quarters as cats started emptying their ashtrays. Good times. BTW...After everyone had tried & failed multiple times...Jake showed that it COULD be done...with his COMP CRAWLER. |
06-04-2012, 10:14 AM | #182 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Re: Del Monte's Secret Agent build You sure the other part is the Irish? It might be his Red hair I have red hair so now I just need to grow a beard and I'm set |
06-07-2012, 08:48 AM | #183 | |
RCC Addict Join Date: Jul 2009 Location: Shreveport, LA
| Re: Del Monte's Secret Agent build Quote:
06-10-2012, 07:37 PM | #184 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
Anyone got a pic of the Climb? By the way, Amazing build. Last edited by stelerzman; 06-10-2012 at 09:35 PM. |
06-10-2012, 08:35 PM | #185 |
Pebble Pounder Join Date: Feb 2010 Location: Apple Valley
| Re: Del Monte's Secret Agent build |
06-10-2012, 09:35 PM | #186 |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
Lmao. thats just stupid. He makes it look so dang easy. We need to post the videos of the 20 other guys who back flipped that 10 times in a row. Also a side view of the actual incline would give a lot better perspective.
06-10-2012, 10:15 PM | #187 |
RCC Addict Join Date: Jul 2006 Location: barstow
and dont forget the super's that cant make that climb
06-11-2012, 01:33 AM | #188 |
Wow...that just looks dumb.
06-11-2012, 02:02 AM | #189 |
Rock Crawler Join Date: Jul 2009 Location: Wil - Switzerland
06-11-2012, 02:36 AM | #190 |
RCC Addict Join Date: Oct 2008 Location: Finland
You made that look really easy! Great driving. |
06-11-2012, 08:58 AM | #191 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
I could get that climb probably 3 out of 10 tries with the RT, but 9 out of 10 tries with the agent. After this weekend's test session with joel, tomer, and doncrawla, I think I have the agent pretty well tuned in. Look for some pictures and maybe a little video tonight |
06-11-2012, 09:35 AM | #192 |
Rock Crawler Join Date: Mar 2008 Location: amherst, ny
Great to here. Looking forward to more pics and video! can you share the shock setup you are liking? Still running with no added weight? thanks man |
06-11-2012, 10:02 AM | #193 | |
Rock Crawler Join Date: Oct 2010 Location: Switzerland
06-11-2012, 11:58 AM | #194 | |
For some comp sites with twisty sections I think I will be able to pull out some of the shock limiting and drop the added weight. Even with the knuckle weights the truck ended up just under 4lbs, but with massive forward bias. | |
06-11-2012, 12:22 PM | #195 | |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
You gotta show me that bounty launch some time. J | |
06-11-2012, 01:20 PM | #196 | |
do you have a Compressed and uncompressed Shock length? | |
06-11-2012, 02:37 PM | #197 | |
So are you running something closer to a 70/30 forward bias with your links? | |
06-11-2012, 04:31 PM | #198 |
06-11-2012, 06:52 PM | #199 |
What oils are you using in your scx shocks? I love how theres no bounce in that truck when it gos up. Sent from my EVO using Tapatalk 2 |
06-11-2012, 10:05 PM | #200 |
Here's how it sits as of tonight I still think there's a ton of untapped potential in this rig, but its coming along quite well. With this shock/link setup, it transfers a lot more weight rearward and puts down a lot of traction. The rear upper links are 1/8" Ti bent and tapped for 6-32 threads. I finally had to ditch my straight tube rear upper links because I couldn't get enough compression in the rear suspension without them hitting the motor or crossmember. I still would like a little more rear compression, but this is a big improvement over the last setup. Here's the current shock setup: Front 45wt Oil 9mm external limiters Mini-T silvers Rear 45wt oil 12mm internal limiter 3mm external limiter Mini-T silvers Even with the big limiters, I still have a little over a tire's height of travel at full flex. With the limited wheel travel, the truck doesn't work quite as good without added weight. |
Del Monte's Secret Agent build - Similar Threads | ||||
Del Monte's XR10 Build #1 | Del Monte | Axial XR10 | 619 | 12-16-2014 09:10 AM |
Del Monte's '07 Falcon | Del Monte | Tamiya TLT Crawlers | 48 | 07-26-2012 07:19 PM |
Featherweight Secret Agent 3.5 Bodiless Build | 4xFord | Axial XR10 | 241 | 06-20-2012 05:43 AM |
Del Monte's MRC | Del Monte | Losi Mini-Rock Crawler | 18 | 04-23-2010 09:24 AM |
Del Monte's Banana Tuber | Del Monte | Tamiya TLT Crawlers | 11 | 07-27-2008 01:43 PM |
