05-28-2012, 12:19 PM | #121 |
| Re: Del Monte's Secret Agent build |
05-28-2012, 01:51 PM | #122 |
Rock Crawler Join Date: Aug 2010 Location: Martinique
Hi Jake ! I see you running straight upper links and was wondering how they worked for you ? What size are they ? I'd like to use the axial bent ones I had on my BJV4. What do you think of it ? Thanks bro !!! |
05-28-2012, 01:55 PM | #123 |
05-28-2012, 03:14 PM | #124 |
Quarry Creeper Join Date: Sep 2008 Location: Isle of Man
I presume 22.5 is Losi shock oil, what does that approximate to on the Associated scale?
05-28-2012, 03:18 PM | #125 | |
| Re: Del Monte's Secret Agent build Quote:
05-28-2012, 03:54 PM | #126 |
Cheers, I was presuming 60wt was ballpark for big-bore on the agents
05-29-2012, 08:39 AM | #127 |
| Re: Del Monte's Secret Agent build We received these over the weekend...they're going fast |
05-29-2012, 08:57 AM | #128 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
05-29-2012, 09:47 AM | #129 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
19 hours of crawling...Must be Nice!! I think I get that much in throughout the entire YEAR! LOL
05-29-2012, 09:51 AM | #130 |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
| Re: Del Monte's Secret Agent build Jake are these 2g lighter per side than STOCK or than the 6mm Hulksta ones?
05-29-2012, 09:56 AM | #131 |
Rock Stacker Join Date: Feb 2010 Location: Manila
Can anyone give me an idea how tough these carbon fiber chassis hold up to damage? I have this vision of the chassis snapping when the rig falls on it's lid. I really want to get the SA or the Switch but this worry is holding me back.
05-29-2012, 09:59 AM | #132 |
| Re: Del Monte's Secret Agent build I have been beating on my SA for a while now with no issues, and my cf bj4.2 before that. YTC chassis are made from high quality CF. |
05-29-2012, 10:18 AM | #133 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
Were did you get this brace between the shocks? |
05-29-2012, 10:35 AM | #134 |
| Re: Del Monte's Secret Agent build Looks like he just has it assembled different. That looks like the same piece everyone typically runs at the very nose of the truck. These professional guys do things differently than us normal folk. Then again, a setup like that might not be quite as sturdy than the "normal" setup
05-29-2012, 10:38 AM | #135 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
05-29-2012, 10:41 AM | #136 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
I was going to say the same thing. It just looks like a delrin rod cut to length to suit the chassis Having it would help to eliminate the need for the chassis stiffeners, with out too much of a weight gain. |
05-29-2012, 11:19 AM | #137 | |
On top of that, the doublers/stiffeners are need to get the chassis to meet the 8" minimum length. Last edited by TSK; 05-29-2012 at 11:21 AM. | |
05-29-2012, 12:42 PM | #138 |
Have any of you found the need of a brace between the shocks?
05-29-2012, 01:01 PM | #139 |
| Re: Del Monte's Secret Agent build I know one guy on here busted his SA at the shock mount. I personally think the chassis got damaged during assembly though (i.e. the shock hole he used got chipped while inserting the shock mount screw). Every other build i've paid attention to seems to have it assembled in the "standard" way and seems to be holding up fine.
05-29-2012, 01:03 PM | #140 |
I run delrin spreader bars between my shocks for stability and piece of mind.
Del Monte's Secret Agent build - Similar Threads | ||||
Del Monte's XR10 Build #1 | Del Monte | Axial XR10 | 619 | 12-16-2014 09:10 AM |
Del Monte's '07 Falcon | Del Monte | Tamiya TLT Crawlers | 48 | 07-26-2012 07:19 PM |
Featherweight Secret Agent 3.5 Bodiless Build | 4xFord | Axial XR10 | 241 | 06-20-2012 05:43 AM |
Del Monte's MRC | Del Monte | Losi Mini-Rock Crawler | 18 | 04-23-2010 09:24 AM |
Del Monte's Banana Tuber | Del Monte | Tamiya TLT Crawlers | 11 | 07-27-2008 01:43 PM |
