06-28-2014, 11:37 PM | #41 | |
Quarry Creeper Join Date: Jun 2013 Location: Langley, British Columbia
| Re: Cormier33's CC Smash Build "TEAM OTTSIX Post Season Build Off" official entry thr Quote:
06-29-2014, 01:22 PM | #42 |
Quarry Creeper Join Date: Jul 2013 Location: Maple Ridge B.C. Canada
They are correct you just need to replace the ends and you will be fine. We all run them or most of us
06-29-2014, 02:34 PM | #43 |
| Re: Cormier33's CC Smash Build "TEAM OTTSIX Post Season Build Off" official entry thr |
06-29-2014, 04:56 PM | #44 |
Not sure what's closer but Pit Stop should have they if not Future Shop will as they sell traxxas stuff now
06-29-2014, 07:40 PM | #45 | |
I'm not sure then. Maybe it's for stock Knuckle's? I know they sold 2 types, depending on brand of Knuckle's. VP Knuckle's and other Knuckle's. Glad you posted.. | |
06-29-2014, 08:51 PM | #46 |
| Re: Cormier33's CC Smash Build "TEAM OTTSIX Post Season Build Off" official entry thr That's probably what it was. I must have got the one for the stock knuckles. Ah well, the Jato ends will sort that out |
06-29-2014, 09:02 PM | #47 |
Well, progress is continuing. Today I was able to attach all of the beautiful Chaotic Crawler Ti links so that my CC Smash chassis could finally be joined to my axles. After a few frustrating moments, I realized that the only way I was going to get the lower front links to fit into the front axle was to trim the Revo ends a bit. So, after a bit of careful sanding to allow a bit more clearance, they fit quite perfect. A question for the experts, was this a fix for awhile? Or was I the only one having issues with the revo ends fitting the stock XR10 axles? I added 30wt oil to the beautiful modified Traxxas big bores that DLUX Fab sent me. I would like some input from guys that have a similar setup. I realize there are a 1000 different answers as to what weight you can use but if anyone has some information or input to add, it would be appreciated. I also mounted the shocks and it wasn't until that moment that I realized the CC chassis kit doesn't come with screws to mount the shocks Unfortunately, the LHS's are closed, the local hardware stores didn't have anything and I even checked Future Shop (thanks for the advice) but they only had the nuts, no screws/bolts in stock in Langley. Ah well, later this week it will be Here are some more pictures. For the experts, please pay attention to the link positions/angles and let me know if I could do anything to improve or correct my install. As a side, the Ti link sliders are not held in place yet, they are just being held in place by friction until I am satisfied with the build. Last edited by cormier33; 06-29-2014 at 09:06 PM. |
06-30-2014, 03:24 AM | #48 |
Quarry Creeper Join Date: Jan 2008 Location: Hellsberry
Really excited to watch this build. What a great compilation of parts. Winnerone23 will have all the answers in your previous post regarding link positions. :cool:
06-30-2014, 08:09 AM | #49 |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
The truck is coming along very nice. Can't wait to see it at one of our comps |
06-30-2014, 09:31 AM | #50 |
Yes great job, now we need to get her finished so you can come comp with us. hats the best way to tune it is on the rocks.
06-30-2014, 05:00 PM | #51 |
Well, she's officially a roller now I went to a not so local "LHS" that was opened today and they had all the hardware/parts I needed. Needless to say I am quite happy. They had the extra long Jato rod ends which was exactly what my Ti steering tie rod needed. They had the M3 screws I needed to mount my shocks to the CC smash chassis and lots of 4-40 screws to mount my wheels to the hubs Here are some pictures for your viewing pleasure/critique. My first thoughts are to reverse the rear upper links as I noticed slight pressure against the springs during full compression (full compression only during a full twist..if that makes sense). But, then I thought that lowering them one or two holes to be more even with the front upper links could solve that issue. |
06-30-2014, 05:24 PM | #52 |
Well, the kids let me have a few moments and I just couldn't let this go. I moved the rear upper link mount down two notches (to match the front) and then slightly bent the rear lower links out about an 1/8" inch. Then I tested full articulation and after a couple of tries, I've got unrestricted, full articulation. The only thing that stops it is when the shocks bottom out Now, just waiting on those electronic goodies that winnerone23 is doing up for me! Pretty excited. |
06-30-2014, 07:28 PM | #53 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
You'll probably find you'll need to lower the links even more. Also lower the chassis some, it looks very high. Possibly by internally limiting the shocks and/or laying them back a notch.
06-30-2014, 07:43 PM | #54 |
Your upper rear links are way high. I think you may be in the cab holes.
06-30-2014, 08:36 PM | #55 |
Thanks for the input guys. Ok, I lowered the rear upper links and moved the shock mounting positions by two holes each. Not sure if that's too much but it seems to look much better and sits at 6 1/4" in height now. More pictures for visual reference:
06-30-2014, 08:50 PM | #56 |
Looks low and mean. Wait till you see what this thing will do on the rocks. You're gonna love it! I have a Switch, but wish I had a Smash.
06-30-2014, 09:04 PM | #57 |
| Re: Cormier33's CC Smash Build "TEAM OTTSIX Post Season Build Off" official entry thr Well, the cab was designed to have more of a forward lean to it. This sets the skid at a bit of an angle upwards at the rear. So, you may have to move the rear shocks back a notch and limit the fronts a tad. Also, use a heatgun and bend the front and rear parts of the skid upwards. This will help not to get 'em snagged. |
06-30-2014, 11:27 PM | #58 | |
I also took the heat gun to the skid and modified it like you suggested. Thanks again! | |
07-01-2014, 02:40 PM | #59 |
I copied a pic from Farmertom's build thread to show the slant of the skid. Pretty well inline with the rake of the front portion of the rear lowers.This helps with the transition from skid to rear lowers. Notice also how the top of the cab is barely over the top of the tires. Nice and low CG. |
07-01-2014, 06:29 PM | #60 | |
Thanks for the picture reference Solitaire. It puts things into perspective. I had both upper links on the highest VP link mounting position possible. I duplicated Farmertom's setup and moved them. The front is now in the middle position and the rear is in the lowest position. Aside from that I haven't made any changes. I am hoping my 3.5" Traxxas Big Bores aren't the issue but I am guessing I will have to internally limit them as you have suggested. Quote:
Cormier33's CC Smash Build "TEAM OTTSIX Post Season Build Off" official entry thread - Similar Threads | ||||
Hittman's SMASH Build | Hittman | Axial XR10 | 994 | 02-28-2015 09:21 AM |
Chaotic Smash/Dlux Superlite axle build thread | Chaotic Crawlers | EnRoute Berg | 146 | 04-21-2014 08:43 AM |
***Paystin go Smash*** | paystin | Axial XR10 | 136 | 02-10-2014 08:43 PM |
Ricky's Smash Build... | Ricky G | EnRoute Berg | 15 | 09-05-2013 10:49 PM |
Electronics smash | showtime90 | Axial XR10 | 8 | 05-20-2013 09:49 PM |
