09-30-2014, 07:08 AM | #121 |
RCC Addict Join Date: May 2012 Location: Folsom
| Re: Cormier33's CC Smash Build "TEAM OTTSIX Post Season Build Off" official entry thr
It looks to me like the signal for steering servo is getting confused by going through the bec. Try a signal wire from servo direct to rx.
09-30-2014, 07:09 AM | #122 |
That is the right servo/bec/rx idea.. Like Solitaire posted as well.. Spektrum or not, I'm not a big fan of leaving any of it without a ground.. All 3 from servo to bec, all 3 out of bec to rx (minus the power wire into the rx) The rear axle, "making sound like a servo binding".. Sounds like the Holmes Hold may be on, to me.. It's almost like a servo trying to find center.. The motor is bein locked by Holmes Hold and makes that noise.. |
09-30-2014, 07:25 AM | #123 | |
| Re: Cormier33's CC Smash Build "TEAM OTTSIX Post Season Build Off" official entry thr Quote:
I got my MT-4 when I stepped into dual esc's.. This setup came from Chris-the-Battery-man, a couple years ago.. I run this bec setup in both my pro's an both sporty's. Does the same thing as a bypass adapter, without the extra plugs an wire, in theory.. Lol.. | |
09-30-2014, 12:34 PM | #124 | |
Quarry Creeper Join Date: Jun 2013 Location: Langley, British Columbia
and......that completes my build! Wow..... Thanks everyone for all the advice and assistance! Now I just need to get some time on the rocks and perfect the adjustments, etc! Now, anyone have any final thoughts/opinions/advice from this point? | |
09-30-2014, 07:12 PM | #125 | |
RCC Addict Join Date: Oct 2011 Location: British Columbia
Thoughts...looks like a very clean build, Adam Opinions...it's waaaaay too clean Advice...get that thing out on the rocks at Ioco on Sunday. It's our last comp of the season and you're long overdue for a maiden. | |
09-30-2014, 07:38 PM | #126 |
^^^ agreed ^^^ My only thought is.. Ur cab's on backwards! Lol.. Looks great Adam! What's ur break over height, with shocks fully extended? Front shock forward a hole, would be my only recommendation. |
09-30-2014, 08:57 PM | #127 |
How's the clearance for that battery tray when you're at full lock R & L? Doesn't take much to take out a sidewall when a tire crunches up laterally. I'd be a bit concerned with the sharp edge of the tray. Maybe take a couple of pics at full lock both ways. |
09-30-2014, 09:42 PM | #128 | |
Thanks everyone. Much appreciated. Troy, the breakover height is 3 1/2" with shocks at full extension. With that in mind, would you still move the front shocks forward one hole? Solitaire, The battery tray is totally fine, the tires don't come close at all. That being said, they did before which is why I cut the top half of the tray off. While I was at it, I also sanded the edges butter smooth so nothing could snag on them...just in case. | |
09-30-2014, 10:44 PM | #129 |
I was just concerned about the area in green... Tires get all squirrely when you're in a bind or trying to grab a ledge. Especially soft VooDoos. Maybe trim that little end piece off? |
10-03-2014, 08:56 AM | #130 |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
Hopefully you can make it out the season ender this weekend Adam.
10-03-2014, 11:59 AM | #131 |
Solitaire, I will take a look at it when I get back home and see if I need to trim it a bit more. Thanks for the heads up. Chevotafun, I am away yet again but will be returning next Saturday. Of course that will be too late for me unfortunately. A little frustrating for me as I have been dying to get this thing out crawling! |
10-26-2014, 01:19 PM | #132 |
Solitaire, As you may have expected, you were right. I put it through a couple of quick trials on a pile of rock I have and the tire was getting awfully close to hitting that part of the battery tray. So, I ended up trimming it off Thanks again for the heads up. |
10-26-2014, 11:04 PM | #133 |
Ah, good you caught it before ripping a gash in those nice new VooDoos. Missed you at the the POD today...maybe see you Nov 9th? |
Cormier33's CC Smash Build "TEAM OTTSIX Post Season Build Off" official entry thread - Similar Threads | ||||
Hittman's SMASH Build | Hittman | Axial XR10 | 994 | 02-28-2015 09:21 AM |
Chaotic Smash/Dlux Superlite axle build thread | Chaotic Crawlers | EnRoute Berg | 146 | 04-21-2014 08:43 AM |
***Paystin go Smash*** | paystin | Axial XR10 | 136 | 02-10-2014 08:43 PM |
Ricky's Smash Build... | Ricky G | EnRoute Berg | 15 | 09-05-2013 10:49 PM |
Electronics smash | showtime90 | Axial XR10 | 8 | 05-20-2013 09:49 PM |
