05-24-2016, 02:54 AM | #21 |
Pebble Pounder Join Date: Apr 2016 Location: Australia
| New to axial yeti
Coming together, just waiting for a couple of parts to turn up and she'l be done. I threw a crappy Hpi servo in until I buy a better one.. Last edited by VNEMSS; 05-24-2016 at 02:51 PM. |
05-24-2016, 03:43 PM | #22 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
| Re: New to axial yeti |
05-25-2016, 04:12 AM | #23 |
Zip tie's are just extra insurance. But yeah I might try the forza holder or the traxxas one. Thanks mate I tired on these hot bodies axel extenders. I'm not sure if I'm going to use them as the hub carries are more exposed, but the track is heaps wider. P |
05-29-2016, 12:37 AM | #24 |
Got bored!!! Lols Looks cool tho |
05-29-2016, 07:10 AM | #25 |
Pebble Pounder Join Date: Oct 2015 Location: Riverview,fl
That thing is pretty awesome!! I like the darth Vader=) |
05-29-2016, 06:08 PM | #26 |
Newbie Join Date: Apr 2016 Location: florida
Looks good
05-29-2016, 09:59 PM | #27 |
Newbie Join Date: Apr 2016 Location: Ballsackistan
Dart Vader is a nice touch. I've always wondered why more people don't build complete rigs from parts that other people have removed. i think that I'm going to go this route to get a yeti. Have you had any trouble locating parts? Or were they pretty easy to find?
05-30-2016, 01:11 AM | #28 | |
| Re: New to axial yeti Quote:
Thanks mate, yeah I was being a tight ass and the parts where going pretty cheap on eBay. Most parts I bought the cheap. I probably saved around $150, the kit is around 550 or so. Most parts are easy to find. Jrc where selling heaps on eBay but have now slowed up on the YXL parts. The main problem was screws, even tho I bought there "so called" screw set, it was missing heaps and I had to buy from dollar hoobies and axial/tower hoobies. If you can get them cheap on eBay I say go for it, otherwise get the kit and it comes with everything besides esc motor etc saves waiting for parts from the mailman. Cheers Ben | |
05-30-2016, 08:05 AM | #29 |
I would get the kit and hop it up and use the old parts to build a second xl. I changed so much stuff on my truck all I really need is differential gears , transmission and a main chassis and I can build another truck.
06-03-2016, 02:30 AM | #30 |
| New to axial yeti
Finally!!!! It's done, parts turned up today yay Built from cheap parts on eBay, stole the esc and motor of my savage flux alza cd truck, but that's ok will replace later on. I did have to use Hpi big bore shocks on the front, the yeti shocks are so soft, I refilled shocks but didn't do much, might try something thicker. I took it for a quick spin (dark outside) and impressed so far, plenty of power, and plenty torque twist, shocks are all way to soft but will test it out a bit more before I changed oil and it does need the rear sway bar but will have some fun with it first. Hopefully get it out this weekend and stretch its legs. Cheers Ben Oh and the steering is shit house. I will be upgrading the rest of the steering and getting Aluminum bell crank. Last edited by VNEMSS; 06-03-2016 at 10:46 PM. |
06-07-2016, 03:11 AM | #31 |
| New to axial yeti
Well that lasted about 5 mins Lost wheel nut, wheel isn't stripped but it's actually melted the plastic around the hex, that's pretty piss poor for about 5 mins run time. And that was on grass and painted (slippery) cement, il be sending an email to axial and ask for a replacement set. What is a better rim to use? Lucky I have spare wheels. Last edited by VNEMSS; 06-07-2016 at 04:11 AM. |
06-07-2016, 04:38 AM | #32 | |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
Stop wile your ahead !!! I KICK myself in the ass for sticking with the RTR hubs !!!!!!!!!!!!!!! I would Highly recommend the HR hub kit !! The XL that I bought from Capwn has them and he NEVER stripped a wheel !!! BTW ... Its funny that the V1 wheel nut had a nylon lock ... The V2 would of been better if they added a nylon lock... Quote:
06-07-2016, 05:01 AM | #33 | |
Where can I get this Hub kit from please!!!! Thanks mate | |
06-07-2016, 05:07 AM | #34 |
Hot Racing YEX10X02 17mm Hub 3.8 Raceline Hub W Serrated Nuts - Yeti Xl RTR Hot Racing's 17mm hex wheel adapter set with +5mm hub extensions and serrated captured wheel nuts for the Axial Yeti XL RTR vehicle. This set features an optional wheel support ring for specific use with the 3.8 RaceLine wheels. For use with the 3.8 RedLine wheels, the slots in the wheel support ring engage the webbing on the back of the wheel to provide additional support to the wheel. For use with wheels besides the 3.8 RedLine wheels, the support ring may be either flipped over or removed altogether, with no consequence to performance or vehicle track width. FEATURES: - CNC machined billet aluminum construction - Red and black anodizing for durability, corrosion resistance, and great looks - 17mm wheel hex - +5mm hub extensions (each side) for greater stability over any terrain - Large serrated and captured aluminum wheel nuts with 17mm hex - Six-slot wheel support reinforcement ring cups - Hardened steel axle nuts fit inside hex hub to secure axle to hub. Axle nuts are tightened with included hex wrench. YOU WILL RECEIVE: - Four (4) 17mm hex, +5mm hub adapters - Four (4) six-slot reinforcement ring cups - Four (4) serrated captured wheel nuts - Four (4) axle nuts - Four (4) axle pins - One (1) hex wrench for axle nuts REQUIREMENTS: - Axial Yeti XL RTR - 17mm hex driver for wheel nuts SPECIFICATIONS: - Axle pins: 2.5x14mm COMMENTS: - This set is compatible ONLY with the Yeti XL RTR - NOT compatible with the Yeti XL kit version - For Yeti XL Kit use YEX10KX01 - See Hot Racing RSYEX10Xfor replacement/spare M5 axle hub barrel nuts |
06-07-2016, 05:09 AM | #35 |
| Re: New to axial yeti Hot Racing YEX10X02 17mm Hub 3 8 Raceline Hub w Serrated Nuts Yeti XL RTR | eBay kit ^ Axial Racing AX31259 Front Axle Stub 16x39mm 17mm Hub Yeti XL | eBay XL Kit front CVD hub ^ http://www.ebay.com/itm/Axial-Racing...oAAOSwxj5XQF2U KIT Rear axle shaft ^ Sell you rtr hubs and don't look back !! The EXTRA cost now will save you some seriously pissed off trips !!! I've been smashed down by this TOO many times !!! Effort setting up the rig.. Charging batteries, loading up tools , grabbing cameras , getting the time to GO , drive 15 minutes to the bash spot .. and just to see a wheel strip out in 5 minutes !! This gets very old QUICK !!! I came close to smashing it off a tree last time ..... Last edited by BarHarborBasher; 06-07-2016 at 05:16 AM. |
06-07-2016, 05:47 AM | #36 | |
Cheers mate, I've been there before, driven 20 mins just to lose a wheel nut in the first minute. Lucky today it was in the front yard. I was only trying to run down my battery's and recharge for the weekend. Just found this lols | |
06-07-2016, 06:38 AM | #37 |
WTF !! Never had that one happen to me lol That's crazy !! Once again the HR Hub adapter is the cat's ass !! Next time don't crank it down too tight, use blue Loctite and let it cure over night . After a had a couple wheels strip; I started overnighting the wheel nuts causing the pin to have way to much stress leading to them breaking easily !!! Your pin looks bent as well. Last edited by BarHarborBasher; 06-07-2016 at 06:44 AM. |
06-08-2016, 06:25 AM | #38 |
Ok hub kit on the way. Thanks again Bhb for the advice. Found a storm trooper head to go with Vader. |
06-08-2016, 09:57 AM | #39 |
06-10-2016, 09:56 PM | #40 |
Aussie yeti XL - Similar Threads | ||||
Yeti, Set, GO!!! FastEddy Bearings for the Axial Yeti | FastEddy | Axial Yeti | 13 | 04-21-2015 07:33 AM |
Yeti Located - Axial Yeti bashing | eunique | Scale Videos! | 0 | 02-12-2015 08:42 AM |
Yeti Located - Axial Yeti bashing | eunique | Scale Videos! | 0 | 01-09-2015 02:10 AM |
