06-23-2016, 03:21 AM | #61 |
Quarry Creeper Join Date: Jan 2015 Location: Bucharest, Romania
| Re: Aussie yeti XL |
06-23-2016, 04:04 AM | #62 |
Pebble Pounder Join Date: Apr 2016 Location: Australia
06-23-2016, 05:21 AM | #63 |
Newbie Join Date: May 2016 Location: The hills
| Re: Aussie yeti XL
I have the GPM shock mounts on mine. Well I wouldnt really call them shock mounts, more ali bracings as they spread the load from the shock over 2 screws rather than 1 as I mount the shock as originally specified in the manual. Ive managed to brake a top rear arm before I have broken anything off the shock/holder, and I'm running the stock plastic shock caps. I'm keeping most of the rear end plastic at the moment so it can brake when I do something stupid rather than bending/snapping expensive ali parts. My front end is mostly ali to hold the diff etc all together, and so far with the original gears it's working well, the bearings have taken a few hours abuse and no grinding from the front. I'll take some photos when I replace the driveshaft and rear upper arm |
06-23-2016, 10:10 AM | #64 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
06-23-2016, 05:47 PM | #65 |
| Re: Aussie yeti XL
You can change some of the settings on the fly, but not all of them. Read the manual to figure it out what and how Sent from my Sony Xperia Z5 |
06-24-2016, 02:49 AM | #66 |
| Re: Aussie yeti XL
Guys why can't I get the locking ring on the back of rim, it's really tight and I've nearly had to bash it, surely it should slide on reasonably easy? |
06-24-2016, 07:36 AM | #67 |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
| Re: Aussie yeti XL
Tight is right lol the wheel looks to be used.. maybe it's deformed... this is one of the best up grades for the XL!! I'm adding extra slots for my 40 series wheels.. it's only aluminum so material removal is easy.. To remove the ring from the wheels I use a paint lid pry bar lol Works awesome Works awesome !! |
06-25-2016, 01:34 AM | #68 | |
| Re: Aussie yeti XL Quote:
It was the wheel that nearly stripped so yeah could be deformed. Il try another wheel. I used a slightly less stiffer shock set up in the rear today and it went well but, it does drive a tad different, on full squirts it wants to spin around quicker, I rolled it more than any other run today, it behaves like a locked diff so to say, so I'm going to go back to near stock Spring until I put the rear sway bar in. I ordered new lipo's today, team Orion 6000mah 3s. They will not fit yeti trays but I will work something out, they are a perfect fit for my savage flux. | |
06-27-2016, 04:32 AM | #69 |
06-29-2016, 03:46 AM | #70 |
| Re: Aussie yeti XL
I installed the axial soft rear sway bar today and I must say, I like how it handles now, drives in more of a straight line and you still get some torque twist. Although the wild ride before was heaps of fun. |
06-30-2016, 02:58 AM | #71 |
| Aussie yeti XL
Upgrades are in. Last edited by VNEMSS; 07-13-2016 at 02:47 AM. |
07-02-2016, 05:11 AM | #72 |
| Re: Aussie yeti XL
Paddle time!!! There is a fresh pile of sand at my local park begging for it. |
07-02-2016, 07:12 AM | #73 |
| Re: Aussie yeti XL
Nasty XL MAN !! Please get some video!!!!!!!!!!
07-08-2016, 02:58 PM | #74 |
| Re: Aussie yeti XL
Next is to find a pond where it won't sink to bottom if something goes wrong lols https://www.youtube.com/watch?v=jE5S...&feature=share |
07-21-2016, 02:34 AM | #75 |
| Aussie yeti XL
Ok guys It had been raining all day yesterday and I went to the park and found a decent pool of water to drive across... Firstly no video footage (long story) 2nd, your yeti XL with paddle's will easily drive over water!!!! I'd advice on 6s It's pretty cool. I'm going to try it again soon and film it. If I was going to do it regularly I'd gear down for more torque. But il do it once more for camera so I won't be making any changes to gears. If your thinking about trying it, I'd personally have both front and rear swaybar's to help keep all 4 wheels on the water. I only had the rear installed and when the car loose's some momentum the car starts to work hard to stay afloat and your front wheel starts to lift (twist torque), now that means only 3 wheels are doing all the work, which slows you down even more, now it won't stop n sink, it just does it slower and your motor is working harder. It also drained my batteries really fast, I reckon they lasted 10mins compared to 25mins. Pick up new lipo's for a good price. Zippy 5800mah 3s They fit very nice as well. So hopefully a little longer run time. |
07-24-2016, 02:19 AM | #76 |
| Aussie yeti XL
Well my tail shaft gave out today, not too bad considering it twisted a bit not long after i got it, lucky I ordered a new one yesterday. I must have run atleast 20 packs with a twisted shaft. I also got some awesome action shots with the slr. Last edited by VNEMSS; 07-24-2016 at 05:21 AM. |
08-13-2016, 06:43 PM | #77 |
| Aussie yeti XL
New shaft is in and also put a new servo in, I tried someone's else idea I forget who but I bought a JX 6221mg and it works great, I'm sure there is better but for $25 it's great. And Im trying out the xmax esc holder, good mod. |
08-20-2016, 06:40 PM | #78 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
| Re: Aussie yeti XL
The YXL is absolutely its own type of animal.
10-02-2016, 06:08 AM | #79 |
| Re: Aussie yeti XL
Quick up date, haven't looked at my yeti in over a month, life n shit gets in the way. So after replacing the drive shaft I found another problem, I blew the rear diff, so I order new parts which take a month to arrive and then realise I blew the front one as well!!!! Shit Bugger waiting for parts, take out front dog bone pin and wallah!! Rear wheel drive yeti XL Took it for a spin at the beach today, it is just as crazy. Pops wheelies with ease on dry sand and spins heaps on wet.... heaps of fun Then a wire ripped of one of the deans connectors. Damn |
11-02-2016, 01:59 AM | #80 |
| Aussie yeti XL
Finally got the yeti going again today, replaced the diff. I have been struggling to get the front wheels straight, no matter what I adjust or move just couldn't get it right, then I found the front protector guard thingy was bent, that happened months ago when I hit a sandstone slab full speed. Last edited by VNEMSS; 11-02-2016 at 02:03 AM. |
Aussie yeti XL - Similar Threads | ||||
Yeti, Set, GO!!! FastEddy Bearings for the Axial Yeti | FastEddy | Axial Yeti | 13 | 04-21-2015 07:33 AM |
Yeti Located - Axial Yeti bashing | eunique | Scale Videos! | 0 | 02-12-2015 08:42 AM |
Yeti Located - Axial Yeti bashing | eunique | Scale Videos! | 0 | 01-09-2015 02:10 AM |
