11-06-2014, 12:31 PM | #1 |
Rock Crawler Join Date: Apr 2010 Location: Eastridge Tn.
| Dasco's Yeti 2.0 lol
Ok so after my upload debacle a fellow user helped me figure it out (sorry I deleted the old thread on accident)! This is also my build/ log so I will explain a little about the mod or changes as they are made. Edit : things marked with ** are mods I have changed What I have VP lower rear links VP upper rear links VP shear pins VP knuckles VP steering rack VP Slw hubs 600 & 850 for the mw rims VP truss VP lower link mounts Strc knuckle carrier Strc lockouts Traxxas tie rods Traxxas camber links Traxxas rear links (sway bar)# 5497 Axial green springs in the rear Axial 25t servo arm Axial front locker** Not sure where the front came from..lol Blitzrc aluminum a arms Cc blower ** Cc bec Cc esc fan (sidewinder)** Savox digit waterproof Tuneable bec for lights Locked front end (silly putty)** Fast eddy bearings RRP 11 tooth 32p. pinion extra hard** RRP 14 tooth 32p. pinion extra hard** RRP 18 tooth 32p. pinion extra hard Rc4wd super swampers Carter Fab quick disconnects Carter Fab drive cups CI duces wild tall foam Moroworx Rc 2.2 8 spoke slw wheels (raw) Coustom Yeti stickers ebay** Dascos coustom made body** Mamba max pro Tekin pro4 HD 3000kv HR front/rear spiral HD gears 38/13 Team associated 30wt oil f/r shocks Proline for bronco EB body with removable doors Dlux fab front end kit Dlux weights 300&100 Dlux ofna hex Dlux wheel spacers (forgot the size) Bluemonkey locker Integy scale winch 10a esc for winch controller from ebay Latest setup Last edited by dasco; 05-20-2015 at 07:15 PM. |
11-06-2014, 12:33 PM | #2 |
| Re: Dasco's Yeti 2.0 lol
Oh and these are the wheels I want to use |
11-06-2014, 05:26 PM | #3 |
Quarry Creeper Join Date: Oct 2011 Location: liberty
Wow, those are nice wheels. What are they?
11-06-2014, 06:26 PM | #4 |
Quarry Creeper Join Date: Mar 2008 Location: San Diego, Ca.
Motoworxs rims I believe, and they use slw hubs which is the best thing
11-06-2014, 07:58 PM | #5 |
Thx luckster Mr Hyde is right
11-07-2014, 07:10 AM | #6 |
Newbie Join Date: Sep 2014 Location: SLC
What is your rear driveshaft? Doesn't look familiar to me...
11-07-2014, 02:34 PM | #7 |
| Re: Dasco's Yeti 2.0 lol Picked em up from integy a few years ago ..they still sell them though. I noticed them as I was browsing their site. You can get 2 in a set they are green or blue.. I polished mine a tad You will need to use both to make the shaft up..pretty easy too. Just take about a half inch off one of the sides with a hack saw and file the burs off. Slips righn on. Last edited by dasco; 11-07-2014 at 02:38 PM. |
11-07-2014, 07:28 PM | #8 |
Silly Putty in the front diff is Freakin awesome..if you want this thing to crawl try it..hurts the steering a little on asphalt but works great Last edited by dasco; 12-02-2014 at 05:47 PM. |
11-07-2014, 07:51 PM | #9 |
Me and my buddies yeti Next mod |
11-10-2014, 05:51 PM | #10 |
Quick update if anyone is interested..hehehe. installed the axial Yeti cvd's and man they are smooth also wanted a different look so I added some boots to the cvd's. Part# RBD0230104 RB productions diff outdrive boot from amain hobby |
11-10-2014, 05:53 PM | #11 |
| Re: Dasco's Yeti 2.0 lol |
11-10-2014, 05:54 PM | #12 |
In the above pic I didn't have the lower boot slid over the cvd end. It fits the vanquish hub just fine.
11-10-2014, 06:15 PM | #13 |
Rock Crawler Join Date: Oct 2011 Location: Fairfield
Where do you find silly putty!? I haven't seen any in years!
11-10-2014, 06:18 PM | #14 |
Lol..I ended up finding it the toy section at the family dollar..or dollar General...Wal-Mart may have it as well. It isn't called silly Putty anymore but it's still in the egg.
11-11-2014, 08:08 PM | #15 |
Added Traxxas links in the rear on the sway bar and a 12 tooth pinion. Most off the clogging is gone but it is no replacement for a sensored system. So that's my next stop. I will say it made a big difference in its crawling abilities tho.
11-12-2014, 06:07 AM | #16 | |
| Re: Dasco's Yeti 2.0 lol Quote:
This is a 5mm shaft correct? | |
11-12-2014, 06:44 AM | #17 |
11-12-2014, 06:47 AM | #18 |
Also installed the sidewinder esc fan . .pics later today!!!
11-12-2014, 07:07 AM | #19 |
Castle esc fan . I cut the center grill out because it was so noisy and it moves a lot more air now Traxxas sway bar links. Didn't get the number I'll try to find it later Last edited by dasco; 12-02-2014 at 05:49 PM. |
11-12-2014, 08:03 AM | #20 |
Thank you sir.,I seen it somewhere else and thought the same thing. They will work with either the stock dog bones or cvd's...I'd venture to say they will work on any drive shaft that is similar.
Dasco's Yeti 2.0 lol - Similar Threads | ||||
Yeti, Set, GO!!! FastEddy Bearings for the Axial Yeti | FastEddy | Axial Yeti | 13 | 04-21-2015 07:33 AM |
water yeti.. calling all yeti owners | going2fast | Axial Yeti | 11 | 11-02-2014 05:43 PM |
Wheel Chinamans..lol had Carnage..lol | UPNOVER | General Crawlers | 0 | 02-27-2006 08:03 AM |
