04-27-2017, 11:31 AM | #141 |
RCC Addict Join Date: Mar 2011 Location: easton
| What did you do to/with your Yeti today?
I got tired of looking at it sitting there, still brand new never run, everything is there but it needs stuff. So I decided to do something about it, I ordered a ssd wide axle, slw hubs, vp castor blocks, ssd steering blocks, vp steering posts, vp steering rack, vp shock adjuster, vp shock tower, vp bell cranks, vp motor plate, and vp cam. I already have ssd beadlocks with ci foams and voodoo u4s waiting to go on it. Sent from my iPhone using Tapatalk |
05-02-2017, 07:18 PM | #142 |
Quarry Creeper Join Date: Dec 2016 Location: Orange County
| Re: What did you do to/with your Yeti today?
Installed hot racing shock upgrade. When compressed oil squirts out the pinhole. What's up with that? http://www.rccrawler.com/forum/attac...1&d=1493774264 |
05-03-2017, 07:29 PM | #143 |
Pebble Pounder Join Date: Jan 2017 Location: Kalispell
My DLUX's front axle cups? grub screws were loose, I might try some red loctite eventually. That was a poorly written sentence! Went out bashing today(5/4/17) and kept checking the set screws on the DLUX drive cups and all was well. I think they came loose the first time due to grease or CorrosionX getting into the threads. I lost my front body clips going off of a jump, and think I need to refill my shocks with oil, maybe change weights in the rear. The car keeps kicking like a mule. I stopped playing after the end of the rear upper control arm snapped. Right where the upper control arms connect to the rear axle. I finally ordered new foams and they are on the way. Double Deuce 6.0” Standard Inner / Medium Outer. Last edited by 33m; 05-05-2017 at 09:36 AM. |
05-09-2017, 07:46 PM | #144 | |
Rock Stacker Join Date: May 2015 Location: central PA
| Re: What did you do to/with your Yeti today? Quote:
05-10-2017, 12:19 AM | #145 |
RCC Addict Join Date: Jun 2016 Location: Germany
Cracking the methods on 3s, driving on sticky surface is an common issue. I still use them but i upgraded them with an alloy Part from gpm. U can find Info about in my little monster build thread. Gesendet von meinem Nexus 5 mit Tapatalk |
05-12-2017, 04:12 PM | #146 |
Magic Yeti- Yeah I need to order some. Ruined my kit stock tires. Received my tires,Scorpios, and new foams and cut my old tires out because I super glued them. Well there was still tire around the wheel. So got a jar and filled it with acetone a little bit. This morning the rubber/tire came right off. aagghhh, damn my impatience! Also the bottom of the jar was warm, must be some chemical reaction. The jar was on a tile floor all night, about 60F. I just got home from Home Depot and forgot to purchase more acetone, aghgh. |
05-14-2017, 08:51 AM | #147 |
Chasing the right suspension setup has been a long process (for me anyway). Most of the time I change one thing and run that setup for weeks at a time. Finally decided to loose the spare tire, and went back to stock rear shock pistons. Poured some 35 wt oil in the shocks, again, and feels about right for my driving style/conditions. I finally settled on white rear springs. They were used in order to have springs compressed slightly while the suspension was at maximum extension.
05-14-2017, 08:56 AM | #148 |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
Installed a mamba monster X esc in the score. |
05-15-2017, 01:29 PM | #149 |
| Re: What did you do to/with your Yeti today? |
05-15-2017, 02:00 PM | #150 |
| Re: What did you do to/with your Yeti today? Last edited by 33m; 05-15-2017 at 02:23 PM. Reason: Bigger pictures. |
05-20-2017, 07:13 PM | #151 |
After having it for 2 months and throwing in just about every part vp makes for it, I finally put a receiver in it! I'm slow lol Sent from my iPhone using Tapatalk |
05-23-2017, 08:16 AM | #152 |
Quarry Creeper Join Date: Aug 2016 Location: Christiansburg
Did a little gender modification... Bought a Yeti from a guy on here. Converted it to a Score. Still need a wider rear, spare, and interior. Last edited by slowmethinks; 05-23-2017 at 08:35 AM. |
05-24-2017, 10:28 AM | #153 |
Took the mmp/pro4 4000kv out for a team Orion vortex8 2000kv Sent from my iPhone using Tapatalk |
05-28-2017, 12:42 PM | #154 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
Did more testing with shock oil in proline xt setup. Front still sags with 45wt. Going to try stiffer springs, then see if i need thicker oil. I suspect springs though. Handles great over whoops. Just cant take hard landings with the sag and 45wt. Rears are near perfect with 15wt, but i have 25 that will try just for poops and laughs. But as of right now its great for high speed over bumpy stuff. Just glad i got it stop popping dogbones and shredding c hubs and knuckles. |
05-29-2017, 04:35 PM | #155 |
Bashed the snot out of it! Then painted battery compartment http://www.rccrawler.com/forum/attac...1&d=1496097295 |
05-29-2017, 05:24 PM | #156 |
Newbie Join Date: Sep 2015 Location: Baltimore County
Flipped my RTR and broke a lower link in resulting tumble. Now trying to decide whether to replace with stock or upgrade to aluminum. Also which sway bar to install to tame squatting. Sent from my SM-N910V using Tapatalk |
05-29-2017, 05:25 PM | #157 |
Rock Stacker Join Date: Jul 2014 Location: Brasil
| Re: What did you do to/with your Yeti today? Last edited by ACR; 05-30-2017 at 09:18 AM. |
06-03-2017, 05:42 AM | #158 |
Quarry Creeper Join Date: Feb 2017 Location: frothy river
genius |
06-03-2017, 01:50 PM | #159 |
Pebble Pounder Join Date: Sep 2016 Location: SE Mo
Found some new trails. Sent from my Nexus 6P using Tapatalk |
06-03-2017, 09:24 PM | #160 |
Got a chance to run the yeti again, this time with the 2000kv 1/8 scale motor on 3s. It's still to slow and sounded like the slipper was a little loose. Also the damn kingpins fell out again! Now time to replace them again and find a smaller spur Sent from my iPhone using Tapatalk |
What did you do to/with your Yeti today? - Similar Threads | ||||
Got my Yeti today, not impressed at all so far... | rm25x | Axial Yeti | 309 | 02-10-2016 10:30 PM |
Wait for a Yeti or get a Slash 4x4 Ultimate today? | BIGNASTY | Chit Chat | 19 | 08-30-2014 10:54 PM |
Yeti captured today | im gunna crawl | Axial Yeti | 4 | 08-28-2014 08:58 PM |
I drove a Yeti today. | Dirt51 | Axial Yeti | 1 | 07-12-2014 08:15 PM |
