03-12-2017, 09:20 PM | #101 |
Pebble Pounder Join Date: Jan 2017 Location: Salt Lake City
| Re: What did you do to/with your Yeti today?
Got the two-speed installed. I was a little annoyed because it kept jamming on the bench but it shifts just perfectly while running. I'm loving it. |
03-14-2017, 05:28 PM | #102 |
Pebble Pounder Join Date: Jan 2016 Location: Newbury Park
| Re: What did you do to/with your Yeti today? |
03-15-2017, 01:13 AM | #103 |
Newbie Join Date: Aug 2016 Location: Los Angeles
Replaced an upper link, steering link and added a fan to the motor. Had a nasty fall and landed awkwardly which caused the breakage. This was on 3s. Can't wait to try 4s. Here is the run. I ran out of battery and was unable to record the breakage. https://youtu.be/_U-af_XNJTs |
03-15-2017, 03:57 AM | #104 |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
Wired some lighting up nice and neat. |
03-15-2017, 07:58 AM | #105 |
Pebble Pounder Join Date: Jan 2017 Location: Maine
I finally got around to getting the Pro-Line PowerStroke shocks.and installing them. The Slash 4x4 rear shocks were long for the front but I had a set of Losi xxx sct rear a arm shock mounts that with a little modification took care of the problem almost like they were made for the job. |
03-15-2017, 11:54 AM | #106 |
RCC Addict Join Date: Jun 2016 Location: Germany
Went out with my little monster, for testing the new CC AUX Mode rockracer/Rock crawler. Melted my Spur So now Change to Steel Spur 56t and 16t. sent by magic_yeti |
03-15-2017, 12:28 PM | #107 | |
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
| Re: What did you do to/with your Yeti today? Quote:
03-15-2017, 12:34 PM | #108 |
03-17-2017, 12:39 PM | #109 |
Pebble Pounder Join Date: Feb 2017 Location: Droning
Installed the CI foams which makes a night and day difference. New foams make the tires very firm that they don't have that slightly deflated look. The performance also improved dramatically almost eliminating rolls. It's a quick, necessary, easy upgrade.
03-19-2017, 02:14 PM | #110 |
Rock Stacker Join Date: Nov 2016 Location: Fenton
| Re: What did you do to/with your Yeti today? Sent from my SM-G920V using Tapatalk |
03-19-2017, 02:14 PM | #111 |
Put on new light bars Sent from my SM-G920V using Tapatalk |
03-20-2017, 12:42 PM | #112 |
Rock Stacker Join Date: Jan 2016 Location: US
Gave my Trophy Truck a little different look. Started like this. The body had taken quite a beating, and pretty much wore the tires down to nothing. So I gave it a little make over. Now it looks like this. Proline Jeep body Proline 1.9 wheels and tires with single stage foams And of course, a couple light bars Also threw on some Proline Powerstroke shocks Sent from my SAMSUNG-SM-G935A using Tapatalk |
03-25-2017, 05:31 AM | #113 |
I had a jump session in front of my house just to see how my new suspension setup would react. Well, I'm pleased to say it was great. The suspension felt and looked plush. Using the 1/8 scale shocks minimised some of the chassis slap. I could see how it just soaked up the jumps. On higher jumps it would slap the ground but not as violently as before. Over all I'm happy this far. I'm still in the tuning phase, but so far so good. |
03-27-2017, 07:28 PM | #114 |
| Re: What did you do to/with your Yeti today? all the electronics are in Sent from my SM-G920V using Tapatalk |
03-27-2017, 10:50 PM | #115 |
Axial Yeti with 1/8 scale suspension setup. After trying out a few different setups. I believe to have found the sweet spot. Suspension Setup: Front- Losi 8ight front buggy shocks with Associated green soft springs and 20w oil. Rear- Associated RC8T rear shocks with 10w oil and medium springs. Soaks up rough terrain real good. Now it's time for a another jump session. Video, Coming Soon. Note: with the Losi buggy shocks I gained 8mm of shock travel from my previous RC8.2e front buggy shocks. It's a noticeable difference. https://youtu.be/qZmnr-yhmq4 Swapped front suspension from AE to Losi. |
04-01-2017, 10:26 PM | #116 |
Rock Stacker Join Date: Apr 2016 Location: Fort McMurray, AB, CAN
Got it muddy. Then broke it . Need to figure out how to get mangled hex pin out of axle shaft .
04-05-2017, 07:30 AM | #117 |
Slash receiver box installed. Just waiting on an extension for the 2 speed servo and lights and a mount for the antenna. Mamba Monster X and Holmes Hobbies Puller Pro XL also installed. |
04-08-2017, 10:06 AM | #118 |
Quarry Creeper Join Date: Dec 2016 Location: Orange County
Installed HR aluminum/graphite rear upper and lower links.
04-08-2017, 02:18 PM | #119 |
Pebble Pounder Join Date: Feb 2015 Location: Bay area
Put a pack through her at the construction site across the street. This was only my 3rd drive since I finished the build, been waiting for the nice weather, which seems to finally be arriving! I don't know why everyone says these things break every time they go out. After many high speed flips, cartwheels, and tumbles, everything is still working great. Hosed her off, charged the battery, back to the shelf until tomorrow! On the down side, at this rate I'll never have a reason to buy any new shiny bits for her |
04-09-2017, 05:33 AM | #120 |
Quarry Creeper Join Date: Feb 2017 Location: frothy river
that construction sight look like Yeti Heaven, nice build~!. As for Yetis breaking.. whenever I go to a bmw track or a place with made jumps I tend to break something, like the roll cage or a body post from landing wrong and wheel bearings will break. I took my yeti to a very open field and there was a metal pipe sticking up in the middle of it.. the ONLY thing to hit.. of course I end up trying to see how well I can do donuts around it like they do in those Hoonigan rally car videos and end up hitting it and breaking half the front bumper off. So basically most of the stuff I break its because of me. Last edited by Mountainsofbeer; 04-09-2017 at 05:44 AM. |
What did you do to/with your Yeti today? - Similar Threads | ||||
Got my Yeti today, not impressed at all so far... | rm25x | Axial Yeti | 309 | 02-10-2016 10:30 PM |
Wait for a Yeti or get a Slash 4x4 Ultimate today? | BIGNASTY | Chit Chat | 19 | 08-30-2014 10:54 PM |
Yeti captured today | im gunna crawl | Axial Yeti | 4 | 08-28-2014 08:58 PM |
I drove a Yeti today. | Dirt51 | Axial Yeti | 1 | 07-12-2014 08:15 PM |
