Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: What did you do to/with your Yeti today?
Old 04-11-2017, 08:03 PM   #121
Default Re: What did you do to/with your Yeti today?
Originally Posted by RCWERKZ View Post
Axial Yeti with 1/8 scale suspension setup. After trying out a few different setups. I believe to have found the sweet spot.
Suspension Setup:
Front- Losi 8ight front buggy shocks with Associated green soft springs and 20w oil.
Rear- Associated RC8T rear shocks with 10w oil and medium springs.
Soaks up rough terrain real good. Now it's time for a another jump session. Video, Coming Soon.
Note: with the Losi buggy shocks I gained 8mm of shock travel from my previous RC8.2e front buggy shocks. It's a noticeable difference.
https://youtu.be/qZmnr-yhmq4
Swapped front suspension from AE to Losi.
RCWERKZ Im liking your setup and think Im gonna take the plunge and get those shocks. It looks like a simple replacement with no modifications to make them fit? Any changes to the suspension since your video or have you pretty much finished tuning it?
Does this look about right for the front shock:
https://www.dollarhobbyz.com/product...nt=10907307841
And rear shock:
https://www.dollarhobbyz.com/product...rear-rc8-89047
mtr1514 is offline   Reply With Quote
Old 04-14-2017, 12:49 PM   #122
What did I do to my Yeti today? Landed on the roof, might need a new one. Time to make a new Baja bug
Sent fra min SM-G930F via Tapatalk
kristee is offline   Reply With Quote
Old 04-14-2017, 01:04 PM   #123
^^^ The roof rack looks good on the bug, but I'm thinking the body might flex a bit better without, and be less likely to break. Just a thought!
MiteyF is offline   Reply With Quote
Old 04-14-2017, 01:41 PM   #124
^^^OUCH!!! I did some parts research to get ready for a yeti rebirth into a bug. Hope I don't destroy my new body when I finally get it out. How big of a crash was this from?
shiftauto is offline   Reply With Quote
Old 04-14-2017, 02:37 PM   #125
Have swept my mind too. But the Proline body don't have that much flex in it comparing to other brands. I'll see what I do.
Old 04-14-2017, 02:45 PM   #126
Not that high, but had good speed, a bit heavy yeti and temperature around 2 °C. There was some damage to the body from last winter that has weakened it and causing the extra damage. Have a new Baja body ready for cutting at my shop and thinking of another cage so I can run the original body when I'm out for some real bashing
Old 04-14-2017, 05:46 PM   #127
Getting started on a few upgrades
172
Cheez is offline   Reply With Quote
Old 04-14-2017, 06:20 PM   #128
I did two things..
First I ran over something at full speed in a field next to my house, since it was nearly dark and my trophy truck is kitted out with some lights it looked like a flying saucer spinning in the air.
Then I had probably my longest walk of shame ever.. I'm calling it an honest 400ft. or 350, it was out there lol
Mountainsofbeer is offline   Reply With Quote
Old 04-15-2017, 11:04 AM   #129
Installed new Losi front shocks. Havent tuned them yet but right off I have full extension. Front end always sagged some but now I have full height and it feels plush. Definitely a whole lot better.
Old 04-15-2017, 03:57 PM   #130
New bulkhead installed
magic_yeti is offline   Reply With Quote
Old 04-16-2017, 12:21 AM   #131
Originally Posted by vipers28 View Post
Who makes that?
It's from GPM, more pics in my little monster Thread.
Gesendet von meinem Nexus 5 mit Tapatalk
Old 04-21-2017, 08:25 PM   #132
Got myself some Proline Dual Stage 2.2 foams for my Yeti.
Left 1 hole open in the stock beadlocks. From super squishy to nice and firm.
Handles so much better!
Have some Proline Powerstrokes and supplies for the Yeti hinge pin mod coming next.
Sent from my SM-G935V using Tapatalk
JimmytheBarrel is offline   Reply With Quote
Old 04-22-2017, 07:10 AM   #133
I glued my first tires ever following URCs old video instructions and it worked!
Here is my first bash video, check out the HobbyWing MAX10 SCT esc working with the stock vanguard motor, its a good combo feels smoother and more responsive than the stock castle plus it doesn't get hot. (the motor still can though).
https://www.youtube.com/watch?v=evw7USoUvWE
Old 04-22-2017, 07:30 AM   #134
The HW MAX10 SCT is awesome. I love mine. Cool, responsive and cheap.
I just started gluing the stock bead locks and tyres myself...I got sick of putting them back on the beads every third lipo.
CoolRunning is offline   Reply With Quote
Old 04-22-2017, 09:13 AM   #135
Cool man, it took me at least 45minutes to glue all four tires gluing the underside of the bead and then the sides (following URC instructions here), so it was basically like gluing each one twice
So HW makes a matching brushless (and sensorless) motor in 3200kv that they say works well with the max10 and enables you to use the temperature limits in the esc/motor. They call it 3660 G2..
If I somehow break the stock Castle (vanguard) motor my plan is to replace it with that.
I thought I wanted to upgrade it make it faster, but as I soon found out when you get into any sort of real terrain going 40mph is fairly useless. So staying around the same KV rating keeps all my pinions and spur options relevant still. I've got 16,17,19,and a 20 tooth pinion now lol.
Old 04-22-2017, 10:35 PM   #136
33m
I swapped in a 23T pinion with 60T spur. Cracked all my kit wheels. Then broke and lost front right axle. Then the stock yeti rear driveshaft disassembled itself. Also had this nice ratchet sound. Rear diff ground some teeth into a different shape. I had an oillite bushing back there that one of my shims bored itself into. Also bent both rear axle shafts. I need to get new foams, wheels, and front shafts.
33m is offline   Reply With Quote
Old 04-23-2017, 04:31 AM   #137
Holy mother of god.
Is this on the Yeti RR?
Old 04-23-2017, 11:45 AM   #138
33m
Kit. I just wanted to see what it was like. Too fast with the stock foams. I learnt how to handle it eventually. I have a set of CREEPERBOB's titanium axles for the rear and a MIP driveshaft for the rear. I ordered DLUX's front axles for the front. I wanted to order new front and rear diff housings that have been bored for a bigger bearing but they were out of stock. I need to order those foams everyone's talking about and some new wheels. Motor is a HH 3500XL on 3S, the car covered 300 feet pretty quick, I turned the steering down to 60% of travel otherwise it would just flip like crazy.
Old 04-23-2017, 04:30 PM   #139
Added new Losi rear shocks. Heres how it measures up to the stock shock on the right.
And here it is mounted.
Old 04-25-2017, 10:38 PM   #140
Added some RC4WD Interco IROK 2.2 Superswampers with CI Deuce tall foams. Side by side comparison with stock tires.
Top view
What did you do to/with your Yeti today? - Similar Threads
Got my Yeti today, not impressed at all so far... rm25x Axial Yeti 309 02-10-2016 10:30 PM
Wait for a Yeti or get a Slash 4x4 Ultimate today? BIGNASTY Chit Chat 19 08-30-2014 10:54 PM
Yeti captured today im gunna crawl Axial Yeti 4 08-28-2014 08:58 PM
I drove a Yeti today. Dirt51 Axial Yeti 1 07-12-2014 08:15 PM
