01-21-2014, 12:49 AM | #121 | ||
RCC Addict Join Date: Dec 2009 Location: Newcastle, Australia
| Re: Standalone Axial based Gearbox Quote:
What happens is the CF is VERY hard on tools, on average it wears a $100 diamond coated bit on every 500x500 sheet... so the parts that are cut early have a perfect fit but as the tool starts to loose its edge parts end up ever so slightly undersize, these would fall into that basket... Im getting better at judging how many I can do before needing to change the tool As the builder you need to check clearances and if the bearing doesn't go in nicely (no slop but no forcing it) then you need to take a hair off the inside of the bearing pocket.. What I do is take a hair off with a small round hobby file but be gentle as you'll not be taking much off! If you don't have a file then a bit of fine emery paper wrapped around an old link or something small and round. | ||
01-21-2014, 02:07 AM | #122 | |
RCC Addict Join Date: Oct 2008 Location: Finland
Sorotec - Werkzeuge I have found the exact same thing as Dan stated above. When you cut pockets for bearings you either need to start with a fresh endmill every 5th housing or so, or check the pockets afterwards for a perfect fit. I use a drill bit and wrap a few turns of 400 grit wet paper around it. It usually only takes a few turns in each pocket to make the bearings seat properly. | |
01-21-2014, 02:17 AM | #123 | |
Man at that price i'll be able to change more often if they at as good | |
01-21-2014, 06:53 AM | #124 | |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
But I can press the bearing in with my fingers. If I can press it in with my fingers I figured that was lose enough. I will pull it all apart again and try grinding the cf alittle. I guess one good thing is the second trans I got will be a breeze to set up lol Now to find acouple more 10mm flanged bearings | |
01-21-2014, 07:14 AM | #125 | |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
01-21-2014, 12:08 PM | #126 | |
01-21-2014, 11:54 PM | #127 | |
Ive heard Fast Eddie is quick at getting US guys bearings | |
01-22-2014, 07:21 AM | #128 | |
But i'm in Canada LOl No worries I have found some the local hobby store had some. I don't think it is that, I think it is more along the lines of what Tommy was talking about. With the blade/bit wearing out. Going to pull it apart tonight to see what I find. Another thing how freely should the trans spin if everything is right? | |
01-22-2014, 10:42 AM | #129 | |
01-22-2014, 08:01 PM | #130 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
Theoretically, even more free than that since there's no big drum gear. Fewer gears, less resistance depending on how much backlash Dan built into these. Mine isn't there yet. Waiting for some replacement bearings to show up. |
01-23-2014, 03:02 AM | #131 |
The backlash is designed with less than the XR, being a sporty I wanted as little backlash I could get without having the gears clash... If you rock the gears looking at the mesh you should see a fraction of movement. Every tranny ive built here (and ive done a lot) ive found them to be free moving but not as free as one that has some time on it, they free up friction the more they get used (bed in) and that is in the bearings, Avid use a grease that feels like friction until it beds in the grease. |
01-23-2014, 06:54 AM | #132 |
That's what I kinda figured Terry But thought i'd ask just to make sure. Ok guys So got it all apart last night. I did notice the hole's did not line up like you suggested Dan, But I thoughts it's only a mil or so i'll give it a light sand like you said to make the bearings slide in and to have the shaft slide in the bearing once installed Check got both of that done. Put the trans together and if I don't attach a drive shaft I can barely spin the trans. So I say to myself I got another trans sitting here lets put that one together and see what happens. Lightly sanded the bearing hole to allow them to pop in and the shaft slides super nice. Put the trans together with the same gear and bearing and WOW night and day difference. This one spins nice and free no need to put the drive shaft on to spin the trans and if you spin it hard it will even make another turn or 2 before it stops. With that said the other trans plate are out of wack. Just glade I got it figured out cause this GB is just awesome. I added acouple pic's as well. Last edited by chevotafun; 01-23-2014 at 10:55 AM. |
01-23-2014, 10:27 AM | #133 |
Rock Crawler Join Date: Oct 2010 Location: Switzerland
Any GB left?? Paypal is ready |
01-23-2014, 11:58 PM | #134 | |
I thought I caught all of them before shipping but it looks like one slipped out... Im very sorry about that, but PM me your addy and i'll get two new plates to you I think ive got a couple left, had a bunch of orders come through while I was at work today so i'll got through the numbers after tea and post up | |
01-24-2014, 03:46 AM | #135 |
Hey all a bit of an update Ive been taking in all the feedback you have been kind enough share here in a civil way And im going to make some changes to a couple of things. Now before I get to the changes I'll point out that ive been checking a testing a few more things.. during this I noticed that the ID (inside diameter) of the bearings I was going off was taken from a bearing I bought somewhere other than Avid, I now realise Avid have a fraction smaller ID than the the bearing spec I first took, it was only by a tiny fraction but enough to make it tight. Next I was checking bearings, I cut some test plates undersized and forced the bearings in, the 10mm wasn't too bad but the cage on the 9mm changed shape and when I turned it the dam thing was hard to turn and notchy. First up is the output shaft that I mentioned earlier.. It will be machined down to make for a better fit. And I'll now be prechecking each plate and fitting the bearings myself This ads time to the process but I will sleep better knowing they are all 110% spot on Now for current orders placed recently..... Ive been redoing the outputs and got them all done.. I was about to repack but im going to check all the plates over the weekend, fit the bearings then repack and have the misses send Tuesday (its Friday night here now and Monday is a public holiday for Australia Day) for us... Its a little more time but will make it hassle free for everyone Here is how they will come now (minus the output which was a custom order) |
01-24-2014, 08:13 AM | #136 |
| Re: Standalone Axial based Gearbox for a vendor that knows how to take feedback and use it as the constructive criticism it was intended to be. Wish they were all like that.
01-24-2014, 09:24 AM | #137 |
| Re: Standalone Axial based Gearbox |
01-30-2014, 12:57 AM | #138 |
Hi guys, Life matters got in the way of getting these out on time, I had to do a drawn out Advanced First Aid after hours for my day job, I was hoping they would of made mail Tuesday but the wife got call for extra shifts which left no one to post All bar 2 (Joel & Brian) made mail today... All bearings are checked and fitted, all output shafts were taken down to new spec and repolished.. I was doing 37 GB's and it all took a bit longer than I first thought but we all will be much happier knowing there're all good Now if by chance a bearing happens to vibrate loose in post just check the first post here to make sure it goes back right way in... Happy crawling guys and gals Oh I also kept one GB for the giveaway, just fighting for time but this weekend i'll have the free time to do that! If you have bought one it will be credit, GB or refund Also tomorrow was the last day for the low kick off pricing of the standalone GB.. Ive got some PM sale to follow up tonight which will most likely be the last of the bearings I have in stock... If your happy to wait 2weeks till more bearings arrive from Avid feel free to place and order... After tomorrow night the pricing will go to a retail price of $75 which is still good value seeing you get all the parts outside of XR gears. I hope you all enjoy your tiny GB's, I ran at a loss kicking these off but stuck to my word on pricing, done with love not profit in mind |
01-30-2014, 05:38 PM | #139 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
Just ordered one for the right side. Josh Woodard. Are you still waiting to receive a number of orders before making a batch? Just looking for a guess at when it will arrive. Its the next step in my current build. I have the patience of a 5 year old at Christmas. |
01-30-2014, 11:37 PM | #140 | |
As for any more orders.. Ive got more materials on the way which will be about 2weeks then 1-2weeks to make 30-50 sets BUT ive got the Australian nationals coming up and need to get a bunch of stuff done before that so the next batch might be limited in numbers of 10-20 sets so ive got time for pre-nats work (giveaways and my rig prep) I will post up once materials arrive As normal if you want to pre-order to make sure your in the next lot that's fine but please note it will be 3-4weeks from today before they will be in post, I'll do my best to make ASAP but im at the mercy of postal services while my materials come from the USA Cheers Dan | |
Standalone Axial based Gearbox - Similar Threads | ||||
Standalone axial based Gearbox | Hulksta | Axial AX-10 Scorpion | 42 | 11-19-2013 07:11 AM |
VP gearbox fit on Axial HD motor plate | patoff | Axial XR10 | 3 | 06-21-2013 01:16 AM |
Axial gearbox gear measures | tarmo120 | Axial SCX-10 | 0 | 08-31-2011 11:43 AM |
