Go Back   RCCrawler Forums > Miscellaneous > Chit Chat
Thread: PC Sim Racing
Old 05-23-2017, 07:10 AM   #761
~THE SCALE SHOP~
Default Re: PC Sim Racing
i believe those are .rply files or something like that. not a video format YT accepts.
however they do now have there own built in capture software on iracing. but i have not tryied it yet.
Tommy your stuttering your getting, does it only show up live?, or does it show up when you play back the recordings as well?
capture software+running a game is very power intensive on a PC. most everyone will experience a drop in frame rate and or stuttering. and if you PC is borderline powerfull enough as it, it may really struggle to run both.
i do get some mild screen tearing when captureing, but it never shows up in the actual recording itself.
STANG KILLA SS is offline   Reply With Quote
Old 05-23-2017, 07:57 AM   #762
I didn't bother looking at the footage to see if the stuttering was there because the stuttering was too much of a distraction while racing so I knew I wouldn't use it as-is. If there were settings I could change, I would, but not sure that's the case. I've run it before with no issues. Maybe I need to run some driver updates or perhaps there's something running in the background. FWIW, I was seeing 85+ PFS while it was recording. But every second or so there would be a very, very brief hesitation in the video display. I could drive with it, but it was distracting and annoying.
Maybe I can look into how to set up the Win10 capture or use iRacing's?
Tommy R is offline   Reply With Quote
Old 05-23-2017, 08:25 AM   #763
~THE SCALE SHOP~
ahh ok. see i never race with it recording. i only record while playing back the replay.
so the stutter is a non issue. and it doesnt show up in the recording.
Old 05-23-2017, 08:54 AM   #764
OH! I never thought of that. Okay, I'll see if I can make that happen.
And you'd better step it up, Cory!!
Old 05-23-2017, 08:58 AM   #765
~THE SCALE SHOP~
today is the last day for the lap time challenge. season finale!
its worth double points!
and if you post a video its worth quadruple points!
deadline is midnight
Old 05-23-2017, 09:46 AM   #766
I thought we had two weeks? You forget how to count Cory?
hpiguy is offline   Reply With Quote
Old 05-23-2017, 09:46 AM   #767
Okay, finally did a decent lap, played the replay within iRacing while Bandicam recorded it. Couple questions...
Since I use 3 monitors, the format is crazy wide, but short in height. Any way to crop it?
Also, the footage is amazingly choppy in the replay. Not sure what I may be doing wrong. Cory?
Old 05-23-2017, 10:09 AM   #768
Moderator
JatoTheRipper's Avatar
Easy fix. Send two of the monitors to me!
Old 05-23-2017, 11:00 AM   #769
LOLOL!!
Since I'm not sure I'll get a video to work well enough, I guess I should at least just post my time. Shame, too, but I was almost 1.5 seconds up about 1/2 way through on the next lap.....'til I wrecked! HA!
Old 05-24-2017, 04:29 PM   #770
~THE SCALE SHOP~
yeah you have to switch to single monitor output on your pc/vid cardbefore you start recording . one of the pains of triples and recording.
Old 05-24-2017, 04:31 PM   #771
~THE SCALE SHOP~
got a surprise and steve joined us last night!
the HPD/Glen combo was awesome. soo good.
race recap vid. i suck at this car, but had an absolute blast driving it on this combo. im just too slow.
Old 06-08-2017, 02:29 PM   #772
I turned some laps in the new Ferrari today, and it's good, DAMN good. iRacing really nailed it, instantly one of my favorite cars.
Old 06-08-2017, 02:39 PM   #773
~THE SCALE SHOP~
hell yeah its good
heres the CF fun run from Tuesday evening (well the GTE part) the HPD guys were practicing for the 24 hours of lemans
Old 06-11-2017, 03:46 PM   #774
Moderator
I didn't realize the week 13 Legends cars were "official" races. You can't race in those things without getting taken out. I was hauling ass in second, catching first, and got taken out by a lapper. My iRating dropped nearly a point from 2 races. I'm less than happy.
There's a big stink going on about iRacing right now. I'm not sure if you've seen it, but guys are starting to protest. Hopefully iRacing starts addressing the issues instead of releasing new DLC.
Old 06-12-2017, 08:04 AM   #775
Finally got around to running a couple laps in the Ferrari and GT. The download took FOREVER and then I was getting lock-ups when loading LeMans. Finally got it resolved, though....
Both cars felt good, although the GT seemed to push a bit more on corner entry. I only did one very minor set of tuning adjustments for each car, but the Ferrari was WAY faster. I did a mid 3:54 in it versus a 3:58 in the Ford. Are these cars supposed to be in the same class??
Old 06-12-2017, 10:09 AM   #776
It seems there's always some kind of stink going on about iRacing, what's the latest one about?
Old 06-12-2017, 10:16 AM   #777
Moderator
Something about bad connection issues and some of the top drivers/teams sitting out the latest 24 hour race (I believe it's LeMans) as a protest.
Old 06-12-2017, 12:10 PM   #778
~THE SCALE SHOP~
could you do a test, what were your speeds at the braking point at "L'arche Chicane" in each?
seems like it would be hard to have a 4 second difference in the corners, im wondering if the top speeds, or acceleration to top speed is the difference. ie difference in baseline tune.
while racing it was a good even mix of the two. no obvious huge advantage.
Old 06-12-2017, 12:20 PM   #779
I know I saw 180 MPH in the Ferrari, not sure what I saw from the Ford other than "less than that", but I should be able to find out today. FYI, in both cars I started with the base tune and then tweaked the aero (reduced wing) and the gearing since both seemed to be pretty gear limited in stock trim.
Old 06-12-2017, 01:19 PM   #780
I've had some connection issues recently, but here in podunk, it could always be my connection. I know Tommy mentioned the latest update took him forever, and it did for me as well. The download speeds from their servers were atrocious. Plenty of stuff I play for free all have better download speeds.
PC Sim Racing - Similar Threads
PROJECT CARS sim game slowlearner Chit Chat 14 08-07-2013 11:51 AM
Any sim racers on here? Hellbilly Chit Chat 30 07-10-2008 10:12 AM
Flight Sim in Google Earth SlinkySam Chit Chat 2 09-03-2007 02:02 PM
rock crawling sim or game? Thorsteenster Chit Chat 2 11-20-2006 10:10 PM
