11-16-2009, 07:02 PM | #541 | |
11-16-2009, 09:28 PM | #542 |
THE Y-TOWN OG Join Date: Aug 2008 Location: yuma
sorry to bug u on this but is there anyway that i can start over from square 1 my car is doing some crazy stuff right now
11-16-2009, 09:29 PM | #543 |
11-16-2009, 09:48 PM | #544 |
got it working but now when i push the ps1 it goes in to a crab walk. is there any way to reverse the rear servo so when i push the ps1 it turns correctly |
11-16-2009, 09:54 PM | #545 |
i think i got it insted of having it on th i have it on steering YOU ARE THE MAN |
11-17-2009, 06:56 AM | #546 |
11-17-2009, 09:03 AM | #547 |
Pebble Pounder Join Date: Mar 2008 Location: K-ville
I just got the 4pk and wow. I'm coming from a modded tq3 and this thing is crazy. I hope I can figure it all out. I can see that just 1 battery is not going to do it, so what is the best and longest lasting battery to go with--link please. And is it ok to work it with the charger plugged up to it? Anymore word on the skins for it and how has them? Thanks |
11-17-2009, 09:21 AM | #548 | |
RCC Addict Join Date: Aug 2008 Location: Charlotte, NC
I use the Trinity 2100mah LiFe pack (TRI20231) and charge it with my 0606i charger. That is the pack I would recommend. They do not make the old 2100mah LiPo pack anymore....... Matt at Anderson can get the pack for you at a good price if you want to get it local. That is where I got mine from. | |
11-17-2009, 09:34 AM | #549 |
Quarry Creeper Join Date: Jun 2008 Location: Central KY
I heard you can cycle the stock battery a few times and it'll help a little. For those that have, what discharge and charge rate are you guys cycling yours?
11-17-2009, 11:24 AM | #550 | |
Thanks | |
11-17-2009, 11:26 AM | #551 | |
Give me a shout. I will work you a deal on the stock pack I have so i can get another 2100 if you want...... | |
11-19-2009, 12:16 PM | #552 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
For anyone that is on the fence with this radio, let me tell you this thing is the real deal. I have it setup on my berg 2.2 rig and the control that it allows me to have is just awesome, I love being able to just dial the motors exactly where I want them. I've also set this radio up with my Shortcourse HPI Blitz, and have been playing with the ABS setup. At last nights race with the ABS setup dialed in I was able to pick up 2 more full laps per heat over my old setup. I also got an email this morning from Corey at RPP Hobby letting me know they have the 4pk's in stock and ready to ship for a crazy low price! I think with his low price we're going to see a lot more of these radios showing up at comps. http://www.rpphobby.com/ProductDetai...tCode=FUTK4900 You have to add it to your cart to see the price. |
11-19-2009, 12:25 PM | #553 | |
11-19-2009, 12:31 PM | #554 | |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
I use the brake travel adjustment on the course with my slash to make adjustments for changing track conditions. The throttle accel function is great for blasting out of corners too. I adjust the amount of mixing on the fly for my 51" gas powered boat to counteract propwalk. It keeps it going straight at idle or at 47mph. This radio really does make me look like a better driver than I am. | |
11-20-2009, 09:20 PM | #555 |
Rock Stacker Join Date: Oct 2009 Location: Irondale
Okay, getting close on mine. Here are the specs and issues: 4PK set up to Harleys Ultimate MOA settings dual FX-R CC-BEC HS-7950TH About every third time I pull the throttle in forward, it does nothing, I pull it again, works perfect. When I roll the dial for more front wheel speed, I get more rear wheel speed. On this same wheel, I would like it to stop at 0 rather than go into negative numbers, when it goes negative very strange things happen! Do the wheels have to be locked in dig, or is there a freewheel I have not figured out yet. I am reading the forum and the books looking for my answers, but I figured someone online may can point me in the right direction. |
11-20-2009, 10:26 PM | #556 | |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
11-20-2009, 10:30 PM | #557 | |
The setup is done to adjust rear motor speed not front motor. Like wrights said, there is really never any benefit to go below 50 or 60 percent. Varing the amount of rear wheel power is what you do to simulate a freewheel. Reduce the power so that it isn't overpowering and trying to turn you over. The slight power is even better than shafty freewheel | |
11-21-2009, 07:23 AM | #558 | |
My dial is adjusting the FRONT wheel speed, not the rear. But, my buttons are controlling the correct axles. FYI and maybe it will help. When I first hooked everything up the front axle turned backwards and the rear turned forward. So, I reversed the front motor leads by re-sordering them. I read on the FX-R, that there is a set up: LED:5 Brake/reverse type, where is talks about locking out reverse for one second. Is it possible I have something wrong whre my forward is reverse, even though my trigger is operating properly. Edit: I have verified it is running in reverse. I cured my stall in forward by removing the one second delay for reverse. Now, I jsut have tofigure out how to fix it. This thing is a blast, just finished running a battery pack threw it. Charging and reading now. Last edited by John Galbreath Jr.; 11-21-2009 at 08:31 AM. | |
11-21-2009, 09:41 AM | #559 |
So you have the dials doing the front and the DT button doing the rear? Although you can do this I don't suggest it. It just makes getting the front and rear axles to an even point twice the work. Not quite sure what advantage you are trying to achieve unless it is to get more overdrive out of the rear motors.
11-21-2009, 10:41 AM | #560 | |
I am not trying to do anything different than your instructions. I have the dials DL1 and DL2 and the DT3 (You did DT1, but I left that one for steering trim) all doing the same thing. These are the settings: DL1: PM2-B: 10 / NOR DL2: PM2-B: 10 / NOR DT3: PM2-B: 10 / NOR However. My settings are controlling the wrong axle. I think I have the motors running on the reverse side as changing the reverse delay in the FX-R fixed my front stalling problem. Is there a way to change is so reverse is forward, and forward is reverse? Then I can re-sorder both motors and see where I am then. I am new at this, so sorry if I am not making sense, I got the 1:1 stuff down!! Also, just lost a small part off the Newage axle. It is the brass bushing out of the knuckle, guess I'll head to the hobby shop. Hopefully that is a common part. Otherwise, guess I am down. No, I did not have it lock-tighted. Guess I need to go back and do that to all the bolts!!!!!! Thanks again for your assistance. | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html | ||||
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? | This thread | Refback | 10-05-2011 06:51 AM | |
• Afficher le sujet - Mon nouveau joujou | This thread | Refback | 10-05-2011 06:04 AM |
