01-06-2011, 03:57 PM | #1341 |
RCC Addict Join Date: Jun 2005 Location: Prosser
01-06-2011, 04:24 PM | #1342 |
My 4pks just arrived! Thank you very much for this thread Harley. I have read it countless times over the past couple years and finally can relate to it rather than scratch my head. It's going to sit in a box until after Saturday's local comp though. I am the current points series leader and don't want to make any changes to the rig that I can't get some wheel time on before hand. |
01-06-2011, 04:33 PM | #1343 |
Good deal man! After you dig into it let me know if you need anything.
01-07-2011, 11:52 AM | #1344 |
Rock Crawler Join Date: Feb 2008 Location: Golden Corral getting Fat
| Harley You are the GURU of 4pkNess can you let me know how to set-up 3 pos switch for m2 dig on a 4pk and assign it to a switch? Thanks Bob C |
01-07-2011, 11:53 AM | #1345 | |
4PK Setups, Tips, Tricks and Help Thanks Bob | |
01-07-2011, 04:02 PM | #1346 | |
| Quote: Thank you | |
01-09-2011, 03:23 PM | #1347 | |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
On MY 4pk it does not do that. For instance I hit front dig button and then rear dig button, when I want to turn either back on the buttons REMAIN THE SAME so I dont get lost. I can hit the rear button 10 times and it ONLY controls the rear. Can someone else chime in and check their radio for us to see which is correct and WHY it is this way? I can see where turning both off and then not knowing which is which could be very detrimental to your run. Thanks | |
01-09-2011, 06:20 PM | #1348 | |
There is no way for the buttons to "switch" what they are doing. | |
01-09-2011, 07:24 PM | #1349 |
so is this the correct operation: Hit ps1 and rear motor turns off. Hit ps1 again rear motor turns back on Hit grip button and front motor turns off, Hit grip again front motor back on Now here is where his gets weird (to me): Hit ps1 AND grip button both motors off, now hit grip and the REAR motor comes back on and not the original front motor. Now is that correct or should the grip button ONLY control the FRONT motor and never the rear? |
01-09-2011, 07:26 PM | #1350 |
No just like before that button will only control one mix and will not switch. But if you hit both buttons so that both motors are off then hit the front dig button again it will seem like it is in rear dig. There is no way that his button is "switching" what motor it is controlling.
01-10-2011, 09:12 PM | #1351 |
Rock Stacker Join Date: Aug 2010 Location: Houston
Hello, I'm running dual FX-R's with my 4pm. I set it up per your diagram and video. I did a "break in" run in my driveway for the first pack and my rig will randomly go to front or rear dig from stop. Not all the time, it just randomly happens when I was doing "stop and go" driving. I'm guessing it's some sort of glitching where one esc responds faster than the other to the throttle?
01-10-2011, 09:20 PM | #1352 | |
I would start by making sure all your wires have a good connection and also calibrate both ESC's at the same time. | |
01-11-2011, 05:04 PM | #1353 | |
Everyhing is brand new. The graphs on the radio are fine. My wires look fine, I disconnected the red wire from both ESCS. And my motors (tekin 45t handwounds) are connected with deans plugs. | |
01-11-2011, 05:11 PM | #1354 |
Are you running FXR pros by chance?
01-11-2011, 05:46 PM | #1355 | |
Moderator Join Date: Jul 2007 Location: Texas baby!
01-11-2011, 05:50 PM | #1356 |
01-11-2011, 05:56 PM | #1357 |
01-11-2011, 06:22 PM | #1358 |
01-11-2011, 06:24 PM | #1359 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
Can't remember the color off the top of my head but it's the middle one.
01-11-2011, 06:26 PM | #1360 |
Now that I think back and you say that you have to pause before you can drive, I think you may have the throttle mode set incorrectly. The BEC signal wire is yellow. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html | ||||
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? | This thread | Refback | 10-05-2011 06:51 AM | |
• Afficher le sujet - Mon nouveau joujou | This thread | Refback | 10-05-2011 06:04 AM |
