12-05-2010, 07:59 AM | #1241 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
| 70/30 is a racing thing where reverse isn't needed. It gives a little bit more control of throttle speeds. With crawlers we typically like the trucks feeling the same in reverse as we do in forward so we will use 50/50.
12-05-2010, 08:50 AM | #1242 |
| Yeah I am aware if the uses, but was just refering to never hearing of anyone using it on a crawler.
12-05-2010, 03:55 PM | #1243 |
Rock Crawler Join Date: Apr 2008 Location: Highlands Ranch, Co.
12-05-2010, 04:42 PM | #1244 |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
This is one of the most informative threads on this entire forum, why is it not a sticky again? Just wanted to say thanks again to Harley and everyone who helps out on here this thread is priceless. |
12-05-2010, 06:39 PM | #1245 |
Newbie Join Date: Apr 2005 Location: Blue Springs
| A member had asked for a picture of the Program Mix screens for the workaround for the 4PKS described in Post 1204. The majority of the setup is the same as Harley shows in his video the only difference is to swap which channels are mixed as illustrated in the pics below. Below is the screen for the setup of Program Mix 1: Below is the screen for the setup of Program Mix 2: Please note the (On / Off) in parenthesis after the mode was a result of which mix was active at the time the menu was accessed and the pictures were taken. . |
12-05-2010, 07:29 PM | #1246 |
Pebble Pounder Join Date: Nov 2008 Location: tacoma
i dont think that its a fix i could be wrong |
12-05-2010, 08:13 PM | #1247 |
Rock Stacker Join Date: Aug 2010 Location: Houston
Another vote to have this thread stickied! I couldn't pass up a 4pk for $369 from superiorhobbies.com. My LHS is insane, they still have it priced at $499. Can't support my LHS like that.
12-05-2010, 08:20 PM | #1248 |
i just hope i did not f-up by buying the 4pks maybe i sould have just got the 4pk and would have saved myself a little bit of money BTW i got the 4pks from my LHS for 469.00 so thats not all that bad |
12-05-2010, 08:49 PM | #1249 |
The 4PKS is almost no different. If there is a want to have the display updated just send it in.
12-05-2010, 08:51 PM | #1250 |
I just set up the 4PKS with dual mamba micros, bec direct to the servo and following Harley's video for 4pk(s) setup. Everything works great. Thanks for the information in the thread and video's Harley. I'll try bbeaty's work around for the mixes asap. Thanks I should have gotten a 4pks along time ago. |
12-05-2010, 08:53 PM | #1251 | |
12-06-2010, 12:00 AM | #1252 |
Rock Stacker Join Date: Sep 2010 Location: Mission Viejo
Harley, can you please describe what the "Adjuster / ADJST" function does and how (and when) it's used? I've read the manual and can't quite get a grasp on it's purpose.
12-06-2010, 08:09 AM | #1253 |
Quarry Creeper Join Date: Sep 2008 Location: tucson
I was told that the 3pk could have a button for momentary dig when i let go its back in 4wd can it do this and how
12-06-2010, 08:13 AM | #1254 |
12-06-2010, 08:21 AM | #1255 |
I have sidewinder esc punk dig moa hr axles
12-06-2010, 11:10 AM | #1256 |
12-06-2010, 11:13 AM | #1257 | |
Moderator Join Date: Jul 2007 Location: Texas baby!
I'm not 100% certain how the Punk operates, but if it is similar to a servo, you can indeed mix it. | |
12-06-2010, 11:14 AM | #1258 |
| But will that make it momentary?
12-06-2010, 11:15 AM | #1259 |
12-06-2010, 11:17 AM | #1260 |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html | ||||
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? | This thread | Refback | 10-05-2011 06:51 AM | |
• Afficher le sujet - Mon nouveau joujou | This thread | Refback | 10-05-2011 06:04 AM |
