Thread: Futaba 4PL Setup, Tips, Tricks & Help
Old 11-07-2010, 12:56 PM   #101
Any updates on the update?
dragrcr is offline   Reply With Quote
Old 11-07-2010, 04:51 PM   #102
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
As soon as we know anything we will post it up.
Harley is offline   Reply With Quote
Old 11-07-2010, 05:40 PM   #103
Got mine 3 minutes ago Opinions soon!
Kieren
Aussie Nerd is offline   Reply With Quote
Old 11-07-2010, 06:00 PM   #104
Harley how do you get the variable rear to work? Since there is only 2 switches to use can I use both the rear steer and the rear rate?
Thanks
Kieren
Old 11-07-2010, 06:09 PM   #105
I hate you guys on the other side
Old 11-07-2010, 06:13 PM   #106
Never mind I found it I think
Kieren
Old 11-07-2010, 06:25 PM   #107
I found a 'hack' to get front dig on a DT, but the problem is each time you dig you also reset the rate back to 100. Simply set a D/T to ESC rate and to 100 steps. From further trials it is actually easier to use the push button than the DT 'hack'
Kieren
Old 11-07-2010, 06:44 PM   #108
So you can have 2 DTs controlling the same mix?
Old 11-07-2010, 06:53 PM   #109
I want one. Im selling my 3pm first
rockn is offline   Reply With Quote
Old 11-07-2010, 07:14 PM   #110
Alright short review
Pros
-Relativity easy to set up
-Manual is quite good
-Comfort is quite good
-Receiver comes bound
Negs
-The dual esc mixing part of the manual needs to mention the DT rate function.
-Receiver wire length (I'm hoping I can coil it inside the case but I'm not betting on it)
-Receiver size, yes I know every radio I get a whinge that the receivers are too big, but after getting used to spektrum parkflyer RX everything is too big
Oh and the push button dig isn't that hard to use, I can push it twice just as quick as I could move an ordinary toggle.
All up definitely a nice radio for those that don't want to spend half their budget on a radio alone. For me it does everything a rock crawling radio should and plenty more.
Also I got mine from dinball/rcmart and their 'standard' shipping was VERY quick for shipping from HK.
Kieren
Old 11-07-2010, 09:27 PM   #111
So can you use 2dt for esc bias??
Old 11-07-2010, 09:35 PM   #112
You can use any of DT1 through to DT4 and the scroll wheel.
Kieren
Old 11-07-2010, 09:49 PM   #113
So your "hack" is using one DT set for 100% steps for dig, and another DT at 10% for bias control?
Old 11-07-2010, 09:53 PM   #114
Yeah but the problem is setting it too 100 it resets the percentage each time your dig. Also if you click it twice in the one direction you can get some funny things happening, I'd still recommend just clicking the push button twice.
Kieren
Old 11-07-2010, 09:56 PM   #115
So you mean if you are running at say 90/100 and the dig with the DT when you get back into 4wd you will be 100/100 ?
Old 11-07-2010, 10:13 PM   #116
Pardon my ignorance. What is "dt"
dusty sweep is offline   Reply With Quote
Old 11-07-2010, 10:14 PM   #117
20K Club
Harley's Avatar
The Digital Trim buttons (rocker switches) around the wheel and near the trigger.
Old 11-07-2010, 10:23 PM   #118
Correct, but if you knock the DT again you will end up with 120, which can be a mild pain.
Kieren
Old 11-07-2010, 11:10 PM   #119
120? Guess I'm still missing something...
Old 11-07-2010, 11:34 PM   #120
120% travel on the rear throttle, sorry that wasn't very clear.
Kieren
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html
Posted By For Type Date
Futaba 4PL - Modelbouwforum.nl This thread Refback 11-08-2011 05:06 AM
Scaler Radio Help - Radios & Servos @ URC Forums This thread Refback 11-02-2011 02:46 PM
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL This thread Refback 10-27-2011 03:41 PM
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby This thread Refback 10-24-2011 03:51 AM
Futaba T4PL - Elektronik - rockcrawler.de This thread Refback 10-11-2011 04:01 AM
4PL Dual ESC - YouTube This thread Refback 10-09-2011 08:27 AM
ZONACRAWLING • Ver Tema - emisora 4pl This thread Refback 10-05-2011 04:42 PM
