Thread: Futaba 4PL Setup, Tips, Tricks & Help
Old 10-27-2010, 02:22 PM   #1
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Exclamation Futaba 4PL Setup, Tips, Tricks & Help
Finally, after so many months of development it finally arrived today.
I will be using this thread to help you all get the most out of the new addition from Futaba. I will be posting step by step instructions including video guides as well as wiring help to get your crawlers running with the new system.
Differences between the 4PL and 4PK
  • The digs are actuated different (with or without an update).
  • Response time on the FHSS system is slower than the FASST system.
  • 4PL only has one program mix (not including the 4WS or Dual ESC).
  • Wheel and buttons are non-adjustable and you can't use a drop down like the 4PK.
  • 4PL uses 4AA's as opposed to the 4PK requiring 5 cells.
  • RX cost is about half the cost for the 4PL.
Links to Important Posts:
Video Showing Basics of the 4PL
4PL Dual ESC Programming <--Updated 12/09/2010
How to program a 3 position switch
Super Class Crawler
Compatible RX's and Voltages
Picture comparison of RX's
Differences in compatible RX's
How to have your radio updated - For those who do not have the latest dual ESC programming
Range Comparison test by Killer RC
Harley is offline   Reply With Quote
Old 10-27-2010, 04:17 PM   #2
Awesome! My XR just showed up today....When will this be shipping?!?!?
73bronco is offline   Reply With Quote
Old 10-27-2010, 04:26 PM   #3
Can we get a list of RX that work with the 4PL?
Old 10-27-2010, 04:43 PM   #4
Full list of features?
SMR 510RR is offline   Reply With Quote
Old 10-27-2010, 04:45 PM   #5
I like that my 3PK's can work with a spectrum module. It would be great if these would too.
Look forward to the write up on this one Josh, I"ve been wanting a new system that'll run the crawlers AND the summit with some more control.
Krakker is offline   Reply With Quote
Old 10-27-2010, 06:12 PM   #6
sim
The 4PL doesn't use modules.
sim is offline   Reply With Quote
Old 10-27-2010, 06:36 PM   #7
20K Club
Harley's Avatar
Old 10-27-2010, 08:15 PM   #8
if they would make a 4pk or 4pl that took a module i think alot of guys who have say 10+ specktrum rxs like me in all their cars would snatch up a new TX in a heartbeat .
but i gotta say that 4pl looks good!
Rootar is offline   Reply With Quote
Old 10-27-2010, 08:17 PM   #9
Originally Posted by Harley0706 View Post
Show Off
KBrog is offline   Reply With Quote
Old 10-27-2010, 10:56 PM   #10
same reason why im still keeping my 3pk .... maybe someday
strawb is offline   Reply With Quote
Old 10-27-2010, 11:27 PM   #11
20K Club
Harley's Avatar
I have never had problems with losing bind on a Futaba RX and had it happen countless times with the spektrum stuff. I know lots of drivers that switched for that reason alone. There is never a single thing I miss about running Spektrum
Old 10-27-2010, 11:28 PM   #12
20K Club
Harley's Avatar
Originally Posted by KBrog View Post
Show Off
How about this one
Old 10-28-2010, 12:22 AM   #13
Yes! When will they hit the shelves, my money is literally leaping out of my wallet in anticipation...
dragrcr is offline   Reply With Quote
Old 10-28-2010, 12:48 AM   #14
How about this one
Lucky bastard
Those ssz-9's look sick Harley seriously wanting this tx
boosted4lyf is offline   Reply With Quote
Old 10-28-2010, 02:34 AM   #15
Location: You will never find a more wretched hive of scum and villainy
guess its time for my boy to get my old radio
DeweyCJ5 is offline   Reply With Quote
Old 10-28-2010, 08:42 AM   #16
The receiver that comes with the 4PL is a "high voltage" receiver. It will safely handle up to 8.5V.
J
jdawg53 is offline   Reply With Quote
Old 10-28-2010, 04:45 PM   #17
Just a few question, if you answer yes to all 3 of these futaba will be getting my business.
1. Please, please futaba fix the dig switch bug
2. Harley, can you adjust the mix percentage for dual ESC with out going into the menu, like on a rocker switch or dial or something?
3. Can you have dual ESC AND rear steer mixes activated at the same time (super?)?
Thanks
Kieren
Aussie Nerd is offline   Reply With Quote
Old 10-28-2010, 04:49 PM   #18
20K Club
Harley's Avatar
Thanks
Kieren
#1 - I hope so too.
#2 - Yes you can assign any DT button to adjust the percentage. You can even set the amount you want it to adjust per click, any where from 2%-20% (or more but any more adjustment at a time then that is way too much).
#3 - You can't use the Futaba 4WS mixing but most people that run a super want independant control of the rear which this is still capable of doing (exactly like a 4PK).
Old 10-28-2010, 04:56 PM   #19
1. Awesome
2. Even more Awesome
3. Sounds good, just how do you control it though, is it on a rocker switch somewhere? And can you set it in steps?
Thanks
Kieren
Old 10-28-2010, 04:59 PM   #20
Yeah, I've been competing in Super for 3 years now, and early on, when I thought I needed steering mix, all it ever did was screw me on the course. Rear steer mix is totally unnecessary.
My question. Does it use seperate dig switches like the 4pk or is it a single switch? I thought I saw something about a single button that toggles through. I'm curious how effective that would be. I can see that it would be simple, but not sure if it would get confusing or be really really easy to use.
EvilTwin v2 is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html
Posted By For Type Date
Futaba 4PL - Modelbouwforum.nl This thread Refback 11-08-2011 05:06 AM
Scaler Radio Help - Radios & Servos @ URC Forums This thread Refback 11-02-2011 02:46 PM
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL This thread Refback 10-27-2011 03:41 PM
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby This thread Refback 10-24-2011 03:51 AM
Futaba T4PL - Elektronik - rockcrawler.de This thread Refback 10-11-2011 04:01 AM
4PL Dual ESC - YouTube This thread Refback 10-09-2011 08:27 AM
ZONACRAWLING &bull; Ver Tema - emisora 4pl This thread Refback 10-05-2011 04:42 PM
