01-29-2013, 10:41 AM | #41 |
| Re: How to wire LEDs |
01-29-2013, 11:11 AM | #42 |
Rock Stacker Join Date: Feb 2012 Location: Flinthills
This is a great write up. Can I just wire up the resistors and LEDs to the wires I already have on my Wraith RTR and use the existing plug at the ESC?
01-29-2013, 12:26 PM | #43 |
01-29-2013, 03:57 PM | #44 |
Sorry, the lighting on my wraith is the stock simple axial lighting. I wondering if could just wire in a few extra lights and resistors on the wires that lead to the other lights. And since the BR-XL that I have installed has all the channels full right now, I don't have anywhere to plug another strand of lights in anyways. thanks |
01-29-2013, 04:05 PM | #45 | |
| Re: How to wire LEDs Quote:
You could solder onto the red and black wires that go to the receiver and wire your LEDs into there, using the proper resistors, of course. If you are worried that you have used up all your connections on your receiver, you could also get yourself a Y cable. | |
01-29-2013, 06:08 PM | #46 |
Pebble Pounder Join Date: Dec 2010 Location: Fresno
Heyok, could you use one fat resistor to run all of the leds of the same color? Say like a 1/2 or 1w resister (if those are even a common size) for 5+ white leds? Or does the parallel'ing of the leds change something?
01-29-2013, 06:12 PM | #47 |
Thats what i've got. Hadn't thought of the Y cable til you mentioned it. Probably the way i'll go. Thanks for the input and again, great info.
01-29-2013, 06:20 PM | #48 | ||
The LED is a semiconductor junction that has a certain "forward voltage". It is also has a maximum current it can use or it will have a shorter life. I was going to go on, but did a google search instead and found a great answer. I want to quote from: LED center » Why do I need a resistor with an LED? Quote:
Hope that answers you | ||
01-29-2013, 06:20 PM | #49 |
01-29-2013, 09:00 PM | #50 |
Wow that's a h3ll of an explanation. Thanks for the info, sounds like I should just stick with plan A.
01-29-2013, 09:36 PM | #51 |
Rock Crawler Join Date: Oct 2012 Location: Casper
Meh, I still wired two additional white LEDs in parallel to the white side of one of those axial kits. Robbed 'em from the kit I used to light my son's truck. I'm running 6 white, he's got 2 white. No reds connected to either. About 3 months now and neither of them have had any issues, yet. They're cheap enough (to me) that I'm not too worried about it, though.
01-30-2013, 10:21 PM | #52 |
Quarry Creeper Join Date: Feb 2010 Location: New London, PA
Got everything to do this!
01-31-2013, 12:10 PM | #53 |
03-06-2013, 04:12 PM | #54 |
Quarry Creeper Join Date: Oct 2011 Location: Shirley
this was linked into a thread i started on another forum. handy little widget for designing LED systems LED series parallel array wizard didnt realise this link was already provided earlier in the thread. i missed it on my read through. Last edited by dieselmudder; 03-06-2013 at 06:36 PM. |
03-06-2013, 04:28 PM | #55 | |
03-06-2013, 06:20 PM | #56 |
Moderator Join Date: Jan 2004 Location: chicago
maybe its been discussed... is there any way to have just one resistor and run the leds in series after it? it'd be awesome to cut down on the amount of resistors and wiring. |
03-06-2013, 06:31 PM | #57 |
i actually just pm'd heyok about that this past weekend. in series the voltage necessary adds up. heres the original message and subsequent replies. Quote: Originally Posted by dieselmudder Quote: Originally Posted by heyok Quote: Originally Posted by dieselmudder need a little help here. wanting to try some LED wiring in series, tried to research but still coming up a little confused. wanting to run a 7 LED setup on my exo terra, either 2 or 3 S. ive figured out 7 LED's divided by 7 volts is 1 volt drop per LED so will i need (7) 1 volt LED's? everything i see uses a resistor, just not sure how to determine what size resistor to use. ive tried searching some LED calculators but its not helping much. hoping you can give me a simple equation to make the figureing easier. Hi, First, I have to ask what colour LEDs you are going to run? The reason is that different colours have a different voltage drop. White and Blue are about 3 volts, red is about 1.7 volts. Let's say you have 7 white LEDs. 7 x 3 volts = 21 volts .... 3S lipo is only about 12 volts so we are out of luck there. We need to exceed the LED voltage by at least a couple of volts because white LEDs are actually 3.?? volts. I meant that they are sometimes slightly higher than 3 volts. Let's try 3 white LEDs: 3 x 3 volts = 9 volts We want to feed them 20 mA, so we need to find the resistor value, but to do that we need to know how much voltage is across the resistor. We know that we have 3 of 3 volt LEDs and the they are being fed by about 12 volts. The voltages of the LEDs add together and will be the "Load Voltage": Resistor Voltage = Source Voltage - Load Voltage Resistor Voltage = 12 volts - 9 volts = 3 volts Now we really get to calculate the resistor value: Resistor value = Volts / Amps Resistor value = 3 volts / 0.02 amps = 150 ohms I hope I didn't leave anything out here. So, on with my sermon... Why not just plug into the receiver and get 6 volts to run your lights? The lights really don't use much power and the power from the receiver is regulated and protected. By protected, I mean that most likely it comes from a BEC with a Lipo Cutoff so it will help keep you from over discharging your battery. Then you just connect all you lights in parallel. That's just my feeling - hook them up in series if you want instead. Good for you for making your own lighting! Hope you post up for others so that they might give it a try too! Cheers, Al okay thank you! that helps clarify a lot. my reasoning behind series was to try and keep the wiring simple. i also didnt make the connection that the colors were different voltages.shopping around last night i could build basically a plug in system from axial factory parts but it was going to be expensive. thought maybe trying to build my own personal set would be a fun project. youre welcome to use my question in your LED wiring post to help others grasp it if its not already there. and if it is and i missed it i apologise for the redundancy. thank you again You're welcome. I hope I didn't discourage you. Maybe I should do an addition to the LED page and show three white LEDs in series running from a 3S lipo for those that want to try it. |
03-06-2013, 11:55 PM | #58 |
Hey Diesel, I sent those pics you asked for over on RCSC.
03-07-2013, 06:02 AM | #59 | |
Provided that a) the voltage feed is higher than the combined voltage drop of all LEDs and b) all LEDs do well with the same amount of current. The LEDs on my rig all want (no more than) 30mA, so in theory I could couple them all i series as long as I feed them more than 5x3.1V + 4x2,8V = 26.7V through one resistor limiting the current to <30mA. (An 8S LiPo setup with 20ohms resistor should do the trick, with built-in cutoff at 3.3V/cell!) Last edited by Olle P; 03-07-2013 at 06:05 AM. | |
04-02-2013, 07:53 PM | #60 |
Newbie Join Date: Mar 2013 Location: manila
Im planning to run 2 white led and 2 red led, and i have a bunch of 1/4w 1k resistor, is 1k to high for a 6v power source? Or can i use 1 resistor to run my 2 headlight in parallel?
Tags |
led, tutorial, wiring |
How to wire LEDs - Similar Threads | ||||
Wire for LEDs. | Mirage | Electronics | 3 | 03-16-2012 07:59 PM |
Easiest way to wire LEDs in body | AdverseCity | General Crawlers | 3 | 01-22-2012 09:03 PM |
little help with leds please!!! | lordjasper1988 | Losi Micro-Rock Crawler | 5 | 03-09-2011 05:14 PM |
Lipo wire smaller than ESC wire..problem? | solomon7 | Electronics | 3 | 03-27-2008 08:45 PM |
how do I wire red LEDs so it will light up during braking? | ussprinceton2004 | Newbie General | 0 | 03-07-2008 05:33 PM |
