11-22-2015, 11:48 AM | #121 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
| Re: How to wire LEDs
Yes this is true the nominal volts is 7.4 while charged up is 8.4, I am pretty sure when you set your bec to 7.4 that's what the receiver will put out and not the 8.4 volts. Thanks for the help and sorry for asking questions that were already answered here. I was reading this on the fly at work. Thanks again! Sent from my iPhone using Tapatalk |
11-22-2015, 11:53 AM | #122 |
Welcome!
11-22-2015, 05:34 PM | #123 |
One other question is why does each led need a resistor? instead can't u just wire up the leds in parallel with one resistor? Thanks. Sent from my iPhone using Tapatalk |
11-22-2015, 05:59 PM | #124 |
Quarry Creeper Join Date: May 2011 Location: Battle Ground WA
| Re: How to wire LEDs You will need a higher wattage resistor depending on the amount of LEDs, not quite as readily available. Also if you happen to have LEDs of different forward voltages (such as using a blue LED in a rear U4 style light bar) I believe that would also cause a problem.
11-22-2015, 06:31 PM | #125 |
Right. Different colour LEDs have a different forward voltage. For example, some red ones are 1.7 volts. Put that in parallel with a blue or white (which are often about 3 volts), and the blue or white won't light up. The red will have clamped the voltage to 1.7 volts. |
11-22-2015, 09:18 PM | #126 |
How about if I wire up 10 whites do I NEED 10 resistors? Sent from my iPhone using Tapatalk |
11-22-2015, 09:43 PM | #127 |
Yes
11-23-2015, 01:24 PM | #128 |
Pebble Pounder Join Date: Sep 2013 Location: Portugal/Lisboa
Heyok can you tell me if I need to waterproof the leds? And how can I waterproof the resistors could I use silicon on leds and resistors? |
11-23-2015, 01:48 PM | #129 |
Yes, you can use silicone. I don't bother with it... actually, I guess I do. Usually I coat the connection with Plasti Dip. Probably just covering with heat shrink is enough, but if you like to turn your rig into a submarine, then doing more to waterproof the connections really can't hurt. Clean water won't hurt anything though. It might lead to corrosion, but the lights will still light up if the connection is wet because we are dealing with such a low voltage. |
11-23-2015, 01:53 PM | #130 | |
| Re: How to wire LEDs Quote:
Thanks for always been here for the help | |
11-24-2015, 05:29 PM | #131 |
Here are four red leds I wired up in a light bar as a brake light for the back of my wraith. Sent from my iPhone using Tapatalk |
11-07-2017, 03:52 PM | #132 |
Just a note that I have fixed the images in the tutorial that Photobucket had chosen to hide. Hope this is still a helpful guide. Al |
11-07-2017, 08:15 PM | #133 |
RCC Addict Join Date: Apr 2009 Location: LA
| Re: How to wire LEDs |
11-07-2017, 08:17 PM | #134 |
11-08-2017, 02:05 AM | #135 |
Quarry Creeper Join Date: Nov 2016 Location: Switzerland
I ordered leds and resistors yesterday because I want to do it myself and I prefer warm white for head lights. And now I found this. Thanks a lot. Great tutorial! |
11-08-2017, 04:58 AM | #136 | |
Please post up a picture of your lights to help show others what you are able to make. | |
11-15-2017, 03:28 PM | #137 |
Newbie Join Date: Oct 2016 Location: Mesa
Thanks for fixing the pictures Al!
12-30-2017, 12:45 PM | #138 | |
I finally had time to do some soldering. 4x 3mm warm white in the front, 5x 5mm cold white on the roof and 2x 3 mm red in the back. All soldered to one connector. I have a switch for the roof lights and hide it in a box. The rear lights are a bit too bright for my taste. Looks like I am on the breaks the whole time. Can I just add one more resistor to reduce the brightness? I use 150 ohm resistors in the front and 470 in the back. 6 V from reciever and the leds run with 3.2 V @ 20 mA. (8'000 to 18'000 mcd, 20°) Last edited by GrimmTheTourist; 12-30-2017 at 01:00 PM. | |
12-30-2017, 12:53 PM | #139 | |
Nice looking rig! Congrats on your wiring. Quote:
12-30-2017, 12:57 PM | #140 |
Rock Crawler Join Date: May 2016 Location: SoWIs
Yes, the resistor will drop voltage. You'll have to play with values since our eyes don't perceive light decrease linearly. 1/2 the light output only seems 20% dimmer.
Tags |
led, tutorial, wiring |
How to wire LEDs - Similar Threads | ||||
Wire for LEDs. | Mirage | Electronics | 3 | 03-16-2012 07:59 PM |
Easiest way to wire LEDs in body | AdverseCity | General Crawlers | 3 | 01-22-2012 09:03 PM |
little help with leds please!!! | lordjasper1988 | Losi Micro-Rock Crawler | 5 | 03-09-2011 05:14 PM |
Lipo wire smaller than ESC wire..problem? | solomon7 | Electronics | 3 | 03-27-2008 08:45 PM |
how do I wire red LEDs so it will light up during braking? | ussprinceton2004 | Newbie General | 0 | 03-07-2008 05:33 PM |
