01-02-2018, 11:39 AM | #561 | |
Rock Crawler Join Date: May 2016 Location: SoWIs
| Re: ProModeler Servo: 420oz, billet case, o-ringed, $79 Quote:
Also any case stating a ubec doesn't provide enouge amps is forgetting the fact the dupont-style connectors are barely sufficient for 5A. | |
01-02-2018, 11:41 AM | #562 | |
Quarry Creeper Join Date: May 2017 Location: Devon
Sent from my Pixel using Tapatalk | |
01-04-2018, 09:03 AM | #563 |
Quarry Creeper Join Date: Sep 2005 Location: Chico, CA
I ended up pulling the trigger on the brushless servo. I have the older 420oz in my son's Wraith and it's held up so well that I had to buy another one. |
01-04-2018, 10:33 AM | #564 | |
01-04-2018, 11:32 AM | #565 |
| Re: ProModeler Servo: 420oz, billet case, o-ringed, $79 I went with the brushless for my TF2 http://www.promodeler.com/DS345BLHV Sent from my SM-G950U1 using Tapatalk |
01-04-2018, 11:39 AM | #566 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
That's just stupid fast and decent torque for the price. I wonder how it compares to something like the ProTek 170SBL in a class 2 comp rig being almost half the price.
01-09-2018, 07:07 PM | #567 |
Thanks for the cozy John! Nice freebie with the new servo. |
01-11-2018, 10:38 PM | #568 | |
RCC Addict Join Date: Aug 2012 Location: Philippines
What about adding capacitors on the output circuit of a BEC to smooth out and cleanup the regulated voltage? Should help with high load demand scenarios as well right? Quote:
01-15-2018, 12:35 AM | #569 |
Rock Crawler Join Date: Aug 2015 Location: Fort Knox, Kentucky
So the DS360 is a waterproof, 360oz servo for $50? Sent from my Pixel XL using Tapatalk |
01-15-2018, 12:50 AM | #570 | |
It's a very good deal. Quite good for general crawlers - it's just a tad slow compared to some more expensive servos, but still as fast or faster than RTR servos with a fraction of the torque... but engineered & built way better and it's rebuildable, they sell the parts. | |
01-15-2018, 07:59 AM | #571 |
Running the DS470BLHV servo with the HW 1080WP ESC, (internal BEC @6v, turned down for my TF2), runs absolutely perfect.
01-15-2018, 09:19 AM | #572 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
I had a weird issue that when my rig was turned off I couldn't turn the servo manually. Then it had trouble centering, so I fiddled with it, and noticed that I could get it to center by doing a certain thing with the steering wheel. So then I turned rapidly from left to right, over and over for about 2 minutes, and now both problems are fixed. Any idea why that solved it? Sent from my Nexus 5 using Tapatalk |
01-15-2018, 09:45 AM | #573 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
I run these servos, straight off a HW 1080, CC 10A bec amd heyok bec's and habe zero issues that require any type of change. I have also run these at 5.5v and still have not seen an issue? Certainly if something needs a fix, lets discuss it(that is the point of a forum). I kind of feel like this is a good solid servo that doesnt have 20 years of gushing reviews so people are doubtful that it works well. | |
01-15-2018, 09:49 AM | #574 | |
Wouldn't worry about it to much, im sure they would make it right if its a defect. | |
01-15-2018, 09:55 AM | #575 | |
Edit: misread ditchrat's post Sent from my Nexus 5 using Tapatalk | |
01-15-2018, 10:16 AM | #576 | |
Running an external bec? When you turn it off, switch or unplug batt? I had a strange issue that Holmes and Castle fixed Hang up and Drive | |
01-15-2018, 10:21 AM | #577 | |
01-15-2018, 01:13 PM | #578 | |
I have never had a problem powering any servo with a 10A CC BEC. Sent from my SM-G935P using Tapatalk | |
01-16-2018, 07:01 AM | #579 | |
At one point I unplug the battery, then proceeded to start unplugging things. Just so you can visualize. My pos/neg from my servo go directly to my CC BEC, my signal to the receiver. I disconnected my servo from the BEC circuit and plugged it into the receiver circuit, and mind you the battery is unplugged. Wouldn't you know it the dam servo jumped and turned the wheels. I am wondering if the Mamba X has some caps in it that discharged. I just got the esc last week so I know nothing about it past liking it. I don't think I would have even noticed it, if it hadn't been for your post. | |
02-24-2018, 10:31 AM | #580 |
| Re: ProModeler Servo: 420oz, billet case, o-ringed, $79 Very disappointed in my V2 and V3. There is simply nothing wrong with them that would let me justify replacing them with the V4, nor have they even hiccuped. Mostly because I need me some stickers Last edited by Ditchrat; 02-24-2018 at 10:37 AM. |
ProModeler Servo: 420oz, billet case, o-ringed, $79 - Similar Threads | ||||
Billet Motorola Droid Razr Case | JFAB | Vendors Miscellaneous | 2 | 01-14-2013 08:24 PM |
Angry Apple Ipod billet case | motoworx | Vendors Miscellaneous | 31 | 08-15-2012 06:12 PM |
metal gears , billet case , coreless motor servo CHEAP | BL-4x4 | Electronics | 2 | 01-04-2012 09:21 PM |
