03-11-2017, 11:02 AM | #141 |
Pebble Pounder Join Date: Sep 2016 Location: Conowingo
| Re: Hobbywing Quicrun Waterproof 1080 Brushed Crawling ESC
26° out today but I got an hour run time in. Couldn't be happier for a $40 ESC Sent from my Nexus 6P using Tapatalk |
03-11-2017, 03:59 PM | #142 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
To be clear, the turn ratings on these are all based off a 540 3 segment arm....a 16t 3 segment arm is going to make a LOT more RPM than a 550 16t or a 16t 5 segment (CVR under the my brand, crawlmaster line from HH)....... For further reference... 5 segment arms typically are equal to double the winds in a 3 segment...16t 5 segment=32t 3 segment, etc. There is no real ratio for 550 arms to a 540 arm... Long and the short of it, these ESCs will work with just about any brushed crawler based motor on the market.... Later EddieO |
03-11-2017, 04:58 PM | #143 |
Quarry Creeper Join Date: May 2009 Location: Scotland, UK
I set my start up power up from 0% to 6% now and it pulls off a lot better. Before there would be a slight whine and no movement. Likewise with resolution up to 16k With the motor i'm running the ESC is almost silent as well. Shame the motor is so loud! |
03-11-2017, 08:58 PM | #144 |
Pebble Pounder Join Date: Dec 2015 Location: Edmonton
My order arrived this am and 2 1080 WP are in. Nice and compact compared to the SW3. Finally had some "quiet" time this evening to install / solder Deans plugs etc. Sunday I will read up on the setting's. The 1080's will be going on a Vaterra Ascender and a TF2, both running HH Crawlmaster Expert 13T w/ 3S. Last edited by northern hooligan; 03-11-2017 at 09:00 PM. Reason: Add Battery info |
03-12-2017, 12:31 AM | #145 |
Pebble Pounder Join Date: Jan 2017 Location: Boone
I installed this esc in my ascender a few days ago, and have adjusted the settings a few times to get it dialed in. I am very impressed with how well it works, and how it made my truck so much more controllable. Couldn't be happier with how it works.
03-12-2017, 10:39 AM | #146 |
RCC Addict Join Date: Apr 2015 Location: New Brunswick,Canada
| Re: Hobbywing Quicrun Waterproof 1080 Brushed Crawling ESC that is a great feature no more loud whinny motors....
03-12-2017, 11:56 AM | #147 |
Newbie Join Date: Feb 2009 Location: Affligem [BE]
Is the internal bec rated at max 3A or 6A? I want to run this in my Gelande II without bec and wonder if it will hold up well. Will attach a winch, 6 x leds and of course the steering servo (savox SW-1210SG).
03-12-2017, 01:13 PM | #148 |
Pebble Pounder Join Date: Jun 2014 Location: North California
| Re: Hobbywing Quicrun Waterproof 1080 Brushed Crawling ESC 3a/6-7.4v. I'm assuming 3a is a conservative rating and the max is close to 5a. I have about 20 packs through mine and the bec has been very reliable. The bec easily handles my 1230sg @500oz. |
03-12-2017, 06:57 PM | #149 |
| Re: Hobbywing Quicrun Waterproof 1080 Brushed Crawling ESC |
03-12-2017, 09:50 PM | #150 |
Pebble Pounder Join Date: Dec 2014 Location: Tip of the Mit
Took my scx10 2 out today with the freshly fitted 1080 and hh trail master 21t 550 and I'm super impressed for a $62 combo. Internal Bec seems good to me, I run a savox 1258 and it has plenty of grunt for my 6lb truck. |
03-12-2017, 11:47 PM | #151 |
03-13-2017, 03:13 PM | #152 |
03-15-2017, 07:03 PM | #153 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
I've been running this ESC a lot for a couple weeks now in my budget TF2 build and I'm very happy with it. Mine is paired with e Titan 21T and its pretty smooth and even after a couple hours on that heavy thing it doesnt get warm. I'm sure a quality motor would be much smoother, but for now the cheapo Titan is staying in. I dont think you can beat this ESC for the price. |
03-16-2017, 06:47 PM | #154 |
Quarry Creeper Join Date: Sep 2015 Location: Bakersfield
| Re: Hobbywing Quicrun Waterproof 1080 Brushed Crawling ESC I emailed them because it says 3a everywhere, but one part of the website says 6a. It's a 3a with a 6a peak for around 10 seconds.
03-17-2017, 02:51 AM | #155 |
RCC Addict Join Date: Jun 2016 Location: Germany
The savöx specs say it could draw up to 5A. Add the draw of the Winch motor and u are easyly above 6A. I would use a bec. Or u could even steer or winch but not both in the same time. To be save not frying the ESC bec. The LEDs doesn't consume much. sent by magic_yeti |
03-17-2017, 11:41 AM | #156 | |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
| Re: Hobbywing Quicrun Waterproof 1080 Brushed Crawling ESC Quote:
03-17-2017, 01:08 PM | #157 |
Newbie Join Date: Oct 2012 Location: Everett
Would you guys recommend that i would go this route or should i go with HH TorqueMaster Waterproofed? I am running 2S battery, Tekin 35T, and a Hitec 7950 servo. Oh also this is for a Wraith. |
03-17-2017, 01:13 PM | #158 |
| Re: Hobbywing Quicrun Waterproof 1080 Brushed Crawling ESC Go with the HobbyWing 1080 unless you want to spend more money for no reason...
03-18-2017, 08:14 AM | #159 |
I have the esc set up as follows, but I still do not have 100% hold on a incline / decline, rig still rolls. settings: 3 - 1 - 3 - 9 - 4 - 4 - 9 - 1 - 9 - 1 - 6 - 5 - 4 - 1 - 2 |
03-18-2017, 08:25 AM | #160 |
Quarry Creeper Join Date: Dec 2016 Location: westlerly
That tekin 55t doesn't have strong enough magnets to hold the truck still. Sent from my SAMSUNG-SM-G920A using Tapatalk |
Hobbywing Quicrun Waterproof 1080 Brushed Crawling ESC - Similar Threads | ||||
Anyone using the Hobbywing QUICRun WP 1080 ESC? | CoolRunning | Electronics | 143 | 04-28-2020 08:48 AM |
QUICRUN WP 1080 brushed ESC (2-3S) With castle Bec | Vwsb74 | Electronics | 14 | 04-07-2017 10:43 AM |
Hobbywing Quicrun 860 Brushed Dual Motor ESC questions | 4drmopar | Electronics | 4 | 02-13-2016 11:28 AM |
Dynamite 60A Brushed ESC or Hobbywing Quicrun WP1060? | MaX-D | Electronics | 1 | 09-12-2014 11:22 PM |
