Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > EnRoute Berg
Thread: Beerman's RcBros Berg build (update on page 7)
Old 01-22-2014, 06:37 PM   #181
Default Re: Beerman's RcBros Berg build (update on page 7)
And the new light weight electronics!
Holmes Hobbies BR mini ESC's
Caste BEC
Futaba R2106GF Rx
More pictures tonight after the silicone dries!
sourdojack is offline   Reply With Quote
Old 01-22-2014, 06:54 PM   #182
Originally Posted by sourdojack View Post
I keep forgetting to post the updates to Jaybe's Berg. So here ya go!
Chris the Battery Man made up that shortened Delrin skid plate, so I modded the chassis to fit it. By the way, I HIGHLY recommend wearing gloves and a dust mask when working with carbon!
Thanks for all the nice work on the chassis, I really like having my upper and lower links the same length.
Beerman Crawler is offline   Reply With Quote
Old 01-29-2014, 11:57 AM   #183
Electronics are all wrapped up. Now we are just waiting for the new motors from Holmes to show up. Hopefully Friday!!!
Old 02-01-2014, 12:18 AM   #184
Sweet little upgrade, Puller 500 Crawl Crawler 13T motors.
Old 02-01-2014, 03:04 AM   #185
Try to Bend it
Highlucks's Avatar
Awesome thread with killer tech. Definitely a reference point for me.
Thanks for the informative updates.
Highlucks is offline   Reply With Quote
Old 02-03-2014, 05:31 PM   #186
This is the RTR weight minus hood, haha
3 lbs 13.7 oz.
The ESC for the rear motor is acting up. So I have to tear into that tonight and see what's wrong...
Old 02-03-2014, 06:56 PM   #187
Total knuckle weight is 6.2 ounces
Old 02-03-2014, 07:09 PM   #188
Try to Bend it
Highlucks's Avatar
Any plans to machine the SLW's?
Old 02-03-2014, 09:19 PM   #189
I have no plans on machining my SLW's. I want to get some carbon fiber wheels and there is some in the works, it's just going to take time.
Old 02-03-2014, 09:48 PM   #190
Try to Bend it
Highlucks's Avatar
Fair call, if they are 1" wheels it is easy to do with a 13mm Drill bit and a dremel or angle grinder. No fancy machines required.
Old 02-17-2014, 05:55 PM   #191
I've had a streak of bad luck so I haven't had a crawler up and running since December. The nice part is I have the crawler itself built. It's all ready to slip the electronics in. Electronics are all soldered up and have been coated to waterproof them. So tonight we should cover the electronics up in some shrinkwrap and solder up to the motors. Should have a working crawler this evening.
Old 02-27-2014, 01:20 PM   #192
Default Beerman's RcBros Berg build (update on page 7)
The demons have finally left so I can give a good update. I got the new homes mini ESC's and the 13 turn 500 pullers. Wow is really the best way to describe it. The wheel speed of those motors is absolutely insane along with the punch. The one difference I noticed coming for my 540 16 turn motors is there is less torque, but you don't miss it. The crawler is faster then my 16t motors on 4s.
I was super excited to try out my new hitec 9830 servo. The first thing you notice right off the bat is the servo is silent. There's absolutely no humming or buzzing, it's dead silent. When the crawler is plugged in, it makes absolutely no noise at all. The overall feel of the servos it does feel more powerful,but maybe not stronger kind of hard to describe. Another great up side is that servo doesn't get tired or fade off. You could wiggle the steering wheel back and fourth as much as you want and you will always have the exact same amount of power. Like I said no fade off at all
The other parts I picked up are some RcBro shock caps. The machining, fit and finish all looks great. They made the overall length of the shock longer which I did prefer. I moved the shock forward two holes on the chassis. I really like the shock angle that I currently have. It really allows the rear of the crawler to flex nicely. I did drill 1/16 hole into the shock cap to bleed the shock oil. I also put on some angle rode ends. The reason I did this is to have the shock angles that I prefer.
Here are some pictures of the crawler, all I need are some body panels
Minus the body panels this is my ready to run competition weight
Old 02-27-2014, 01:56 PM   #193
Does the frt wheel rub/bind agenst the battery during full lock? Rig looks good.
saniel68 is offline   Reply With Quote
Old 02-27-2014, 02:01 PM   #194
I do make contact with my battery. I've never had my battery come off or doesn't seem to interfere with anything, but it does touch ever so slightly.
Old 02-27-2014, 10:45 PM   #195
Tight fit. I like how the placement gets the battery low on the axle. Nice.
Old 02-27-2014, 11:38 PM   #196
I have been so happy with this battery mount. We had some carbon fiber in the garage so we cut that and with one screw, screwed it on. The only drawback is you do need to use a short battery. The ones I found that work are the Max amps and the cheap battery packs which are hard-to-find these days. Here is a picture of the mount
Old 02-28-2014, 01:06 AM   #197
What did you ever find out about the servo programming? I did not follow up on it after our pm.
I still think it's the best servo I have ever bought
TEDROCKZ is offline   Reply With Quote
Old 02-28-2014, 01:16 AM   #198
I never did look more into it, i pluged it in and had a great time. I cant say enough good things about this servo, I feel lucky to get my hands on one, it was hard to find. I love that it doesnt make any noise, I guess I got use to all the buzzing noise that the 7950 makes. Im so glad I took your advice to picke me up one.
Old 02-28-2014, 01:33 AM   #199
I am so happy to see your pics and your post! That is a great guy and you are great too.
adele is offline   Reply With Quote
Old 03-17-2014, 09:52 AM   #200
Here is a picture from yesterday's comp
Beerman's RcBros Berg build (update on page 7) - Similar Threads
Wraith Kit Build - Page by Page Video Series. FastEddy Axial Wraith 60 06-09-2015 11:11 AM
SCX10 Honcho Video Build. Page By Page (Great For the New People) FastEddy Axial SCX-10 33 04-22-2011 07:47 PM
RcBros Berg Build RcBro EnRoute Berg 176 08-15-2010 04:36 PM
iPhonewizz Berg build Update 3! iphonewizz EnRoute Berg 8 05-27-2009 03:01 AM
iPhonewizz - Berg Build - ******UPDATE ****** iphonewizz EnRoute Berg 5 05-23-2009 10:20 PM
