08-12-2014, 07:17 PM | #61 |
RCC Addict Join Date: Aug 2009 Location: Earth?
| Re: I'm building a Berg. |
08-13-2014, 08:11 PM | #62 |
RCC Addict Join Date: Aug 2013 Location: South East
08-14-2014, 06:35 AM | #63 |
08-14-2014, 06:52 PM | #64 |
Got the chassis put together after looking at pics of other Mutt builds I figured out how to assemble it. Through some links together to get a basic mock up started. I like this chassis even more now that I have it on my desk. There is some interference with the lower link rod ends at the chassis but nothing anyone in this hobby can't handle with a Dremel. When time permits I will work on it more. Any advice is welcome |
08-14-2014, 07:00 PM | #65 |
Looking good there Karl. I suggest that the front lowers have a slight kink to keep the rod ends straight coming forward of the skid. Like you said there is always the Dremel and the corner can be rounded or the rod ends can be carved on a bit. I am glad to see it looks good up close and personal. Just make sure you are 3" at the rear of the cab supports...... At least that is what I planned. Anywhere else and the flex is too much on the cab.
08-14-2014, 07:08 PM | #66 |
Looks dam goooood! I took the dremel to the chassis and rounded it where the link ends rubbed.. Plenty of meat left when done.. Any advice... Get that bad boy built already! :thumbsup: |
08-15-2014, 12:41 PM | #67 | |
| Re: I'm building a Berg. Quote:
I think I'll follow your lead on rounding the chassis. I saw that in your thread when I was checking out pics to figure out how to assemble the chassis. | |
08-16-2014, 09:51 AM | #68 |
Rock Crawler Join Date: Mar 2008 Location: Not painting
Progress? (praw-grēss)
08-19-2014, 06:43 PM | #69 |
08-19-2014, 07:36 PM | #70 |
Is that Hustis!?
08-19-2014, 07:40 PM | #71 |
08-19-2014, 07:43 PM | #72 |
I doubt you'll be saying that about This dog! |
08-19-2014, 08:00 PM | #73 |
08-19-2014, 08:52 PM | #74 |
Quarry Creeper Join Date: Jan 2012 Location: on the other side of the tracks from baldy
Looking good for sure u guys r making me wanting to swap to the mutt...
08-20-2014, 12:44 PM | #75 |
08-20-2014, 01:01 PM | #76 |
I'm running the pitbull which is great the mutt has a better look the wide to narrow is just a good look u r going to be very happy with ur build....
08-20-2014, 07:35 PM | #77 |
08-20-2014, 08:22 PM | #78 |
That is perfectly fine..... You should be able to still keep it tight. Really they just stop rotation and don't hold it tight. If they are snug and don't rotate your golden
08-21-2014, 01:50 PM | #79 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
For added insurance you can use socket cap M3 hardward, chuck the screws up in a drill (via the socket cap end) and dremmel disc grind sharp points on the screw ends that touch the delrin axle. Make the points long enough to extend deep into the delrin. This may reduce rotation under impact. You could also fabricate some kind of plate to connect the chub to your battery mount/shock link mount for added rotational resistance. J |
08-21-2014, 02:00 PM | #80 | |
I'm building a Berg. - Similar Threads | ||||
slow1 building a Berg | slow1 | EnRoute Berg | 3 | 03-19-2011 04:50 PM |
building a berg!! | imbler2 | EnRoute Berg | 23 | 03-12-2010 06:58 PM |
building a berg......need ideas..... | flapjack | Colorado | 3 | 12-07-2009 03:13 PM |
building berg rig? | cavie98 | EnRoute Berg | 3 | 03-18-2009 12:46 PM |
