05-03-2011, 05:14 AM | #101 |
Rock Crawler Join Date: Feb 2010 Location: Chapin, South Carolina
From a relativly stock ax10, how much work will I need to do beside the chassis and motors?
05-03-2011, 08:11 PM | #102 |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
| what diffs are you guys planning on installing? i was thinking about building a big tired monster truck with axial axles and was thinking HPI MT2 diffs would fit.... |
05-03-2011, 09:54 PM | #103 |
Rock Crawler Join Date: Jun 2007 Location: Arlington
Axial made diffs that came in the RTR version of the AX-10. HPI MT1-MT2 diff internals will fit.
05-09-2011, 06:47 PM | #104 |
RCC Addict Join Date: Mar 2008 Location: SSF
Is there room is this chassis for a Summit trans? |
05-09-2011, 06:58 PM | #105 |
I wanna be Dave Join Date: Jun 2007 Location: Earth
This one is machined specifically for the AX-10 transmission.
05-10-2011, 09:31 PM | #106 |
05-11-2011, 04:49 AM | #107 |
05-11-2011, 05:44 AM | #108 |
I wanna be Dave Join Date: Jan 2006 Location: Iowa, the antirecreation state!
05-12-2011, 09:37 PM | #109 | |
If it'll accept slightly narrower than stock TF axles, 1-1/4 off the long side, you could my name down on one Me too. | |
05-13-2011, 06:59 AM | #110 | |
Rock Crawler Join Date: Sep 2010 Location: Keego Harbor, MI.
If I may..... I believe BWD's Super FOFF using TF axles Is set up for 10 1/2 inch Axles conversion (2 short sides with centered Diff) I have not seen it yet but if its anything like his 1:10 scale FOFF then were in for a treat !!!!! Regards V8 | |
05-13-2011, 07:49 PM | #111 | |
gotta remember, there is a LOT of tunability in TF axles, being that they use buggy diffs, and axles.... so is there a version in the works that uses an 1/8th scale buggy center diff in the drive line??? | |
05-13-2011, 09:12 PM | #112 |
Cart before the horse my friend...shhhh |
05-13-2011, 11:45 PM | #113 |
05-25-2011, 10:29 AM | #114 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
Any update on this.
05-25-2011, 10:39 AM | #115 |
05-25-2011, 10:56 AM | #116 |
N.E.R.C.C Uncle Blinky Join Date: Dec 2008 Location: RUKDNME...
Paypal sent for a 12.5..thankyou Drail
05-25-2011, 12:18 PM | #117 |
Got it...the first batch will be shipping out Friday/Saturday this week...of which I still have a few left unclaimed. One or two special ones are shipping out today I think Here's a few of the parts out of debur so far. Hundreds of links, a bunch of bulkheads, and plenty of skids are still in process out in the shop...but nearly done. BW |
05-25-2011, 12:47 PM | #118 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
In, thanks for the chance!
05-25-2011, 01:01 PM | #119 |
The kits can be found here http://stores.intuitwebsites.com/Bil...StoreFront.bok I am adding components, stretch kits, the 14.5" wheelbase kits, and much more to the store this week. Keep in mind, with a simple swap of the shock towers and links (included in the stretch kit) you can add to/take away from your wheel base, front/rear/both, in half inch increments. My personal favorite shock for this beast is the 4" Traxxas big bores with 5/16-3/8 internal limiters. The kit is designed around 3.5" shocks but if you go to 4" and limit them you have more ride height tuning options. GTR's are tough to get soft enough...but work great if you're into axle snapping 20' plus vertical drops like myself. Our new bomb proof 6mm one piece FOFF spools are just about wrapped up, and should be available late next week. Extended 6mm spools will not work with this chassis kit FYI. I'll also have more pics, and full online build instructions up this weekend. Lastly, if you plan to abuse your's the way I do mine, do yourself a favor and order up some Gunnar beef tubes from KC Jones http://www.rccrawler.com/forum/showthread.php?t=268650 You will need 2 pairs for one rig, and I promise they are well worth it and easy to install! BW Last edited by billet works; 05-25-2011 at 01:21 PM. |
05-27-2011, 10:02 PM | #120 | |
Or is the 14.5" for the TF axles? Last edited by JeepinDoug; 05-27-2011 at 10:05 PM. | |
