Go Back   RCCrawler Forums > Miscellaneous > Formula Offroad
Thread: Project Crossroad Blingmobile Midnight Special First FOFF Build
Old 05-15-2015, 10:30 PM   #21
Default Re: Project Crossroad Blingmobile Midnight Special First FOFF Build
Originally Posted by RockBiter View Post
Its going to be a good looking machine, with all that color I would get some flashier wheels for it though. JM2cts, good lookin rig man.
ya that what I should of done.These are the ones that Pro-line has already glued.Could always try boiling them then get the bling bling rims.
Originally Posted by Bully2RockRomper View Post
I think the wheels look great, i suppose they will hardly be seen when they are churning up sand.
Yes I'm looking forward to that to and I was thinking of painting them,Not sure yet.
rustneversleeps is offline   Reply With Quote
Old 05-16-2015, 08:52 AM   #22
After all trim and cut to size this is what i'm going for...
there is a different in size ......
Now that both side exact time for to drill hole in the homemade extenders...
now I have to fit the sleeve inside the extender so it's time to drill.
as you can see the the hole has to be bigger...
here you can see sleeves inside the extenders..
Here's is the finish product,very happy with the results
now i to reduce them from 14mm hex to 12mm hex...stay tune..
Old 05-16-2015, 09:43 AM   #23
you can see how much has to removed to reduce to 12mm hex...
here' the size different...
here both are 12mm hex
here you can tell the size this is the last for the extenders.on to the next stage...links are next...
here the length there are both at 265mm wide, front and rear..
I went from this .....
to this finish this part now for links..
hope you like it.All of this was done with a file no belt sander here
stay tune for more......
Old 05-20-2015, 11:45 PM   #24
Default Project Crossroad Midnight Special Blingmobile First FOFF Build
well i decided on my chassis and here are the possibilities
Out of all of them i chose the Wraith skid plate and mated it to the SCX10 chassis rails,with te tube chassis.It's a start...and I'll show you how it done next...
Old 05-21-2015, 09:51 AM   #25
well here's how i attach the Wraith skid plate to the SCX10 chassis rails...
pretty simple.
here's the carnage..removal...
once that was done ha a problem with the motor interfering with the chassis rail.Fix that fast..
Old 05-21-2015, 10:29 AM   #26
Here is the bottom wraith skid plate bottom..
well here it is complete now for the rest of the parts..
bottom.
now for the gas tank need a place for electronics and still need a place for battery.now that should be interesting.
another mock up. i always like this...
well better start on the next modification...
Old 05-21-2015, 03:55 PM   #27
Oh yeah...looking mad amigo...keep up the good work!
Bully2RockRomper is offline   Reply With Quote
Old 05-22-2015, 11:19 AM   #28
Looks nice and clean, keep up the good work.
RockBiter is offline   Reply With Quote
Old 05-22-2015, 12:12 PM   #29
Hey thanks Bully2 can't wait to try it out but may be a while...i love fabing up plastic...hint hint....
hey thanks man.i hate it."wait". Who am i fooling,I love it when you have to figure out how this going to work and what pieces to use to fab up,but once you step back and look at it,that's when you find the solution and Bamm that will work...
Old 05-22-2015, 11:24 PM   #30
What kind of body work will you do you think?
Apart from maybe panelling out the cage, what will you do for the rear, just leave it open?
Old 05-22-2015, 11:49 PM   #31
not sure i plan on covering it up somehow to prevent the sand from flying around inside some how. i have some clear lexan sheets about 3 or 4mm thick i may use and i do have a few bodies hanging around.I have a 1/12 scale vw bug I bought in 2011 off Ebay I'm thinking of using.
I'm Just going with the flow.Building this thing it's like trail and error trying different parts to what works.screw unscrew screw unscrew.some times these mod are pain in the ass.....
Old 05-24-2015, 03:08 PM   #32
well this be try #3.Earlier today i try to post some more updates lost all my data with 13 pics and info ..My internet cut out on me and couldn't send just when i was finish to save thread and error come up and said "web can not be found" Cursed with the 13 pics so decided to head to the bmx trail and let out my frustration and took the yeti and exo out for a good run.Good thing is i didn't break anything and video to prove it...now i hope this works...
Old 05-24-2015, 03:49 PM   #33
so i hope this works.I keep my self signed in so may i won't lose anything..
OK let see Ya gas tank from the yeti using the scx10 chassis rails with wraith skid plate and ax10 skid plate.....tube chassis...
here are the parts I'll be using..so when taking apart the tubing to geet at the gas tank i notice something these look like shock hoops ans since i own a yeti and bought to of these i thought i try this..not sure if it's been done i may be the first hope this works
gas tank and straps now i have a place for my electronics..
here you can see what how i want to hoops will work.
compare to the SCX10 chassis braces needs to be cut to 70mm
here's were i ran into a problem would not close the gap...
Old 05-24-2015, 07:42 PM   #34
Well here I had to bend the shock hoops mounts in a S turn to make it fit in the chassis rails.Wasn't sure if it could be done but i tried and i please with the result.i have an old hair blower that i use for shrink tube it releases a lot of heat hot enough to bent but not hot enough to melt.just hope they last.beside it wasn't like a 90* bent just a slit S curve..
here how it came about...
here is the first bend just took my time .get it hot and bend hold the bend and try to cool it down the same time while holding that bend...
here you get the idea that's not moving...
Here's the S curve.
I needed this for spacers along side rails but didn't pan out so i had lots axial spacers i them instead..
over did with the dremmel...
here's the plan seem like it was meant to be there.....I'll make it fit..
here couple small 3mm x 8mm.
so here normal shape...
here's is end result perrrrrfict.
more to come think i'm going to make my own links it will be a first .Stay tune.
Old 05-25-2015, 08:35 PM   #35
Newbie here. just lurking around and found this thread. Im excited to see the results
OffRoaderick is offline   Reply With Quote
Old 05-26-2015, 05:18 AM   #36
Ya me to i can't wait for the results.Trying to see what fits in this build.it's a mix bag of all Axial parts on this build..
thanks for watching....more today
Old 05-27-2015, 08:38 AM   #37
Well did my front upper and lower links last night.I had to calulate how long i wanted my wheel base once that was accomplish i started cutting.I wanted to make sure when i made them that they were the size that i wanted.I wanted to do it once and i like the result first timer doing links.
I made the links longer in front and to make them shorter in the rear...
here are the parts i'll be using...
Traxxas rod ends #5525
I Used electric tape just to tighten it up inside the brake tube..
here is just a comparison of the original links to new ones.
Here you see the different stages of the links being made.
finish product.
couple posers.....
here you can see how foward the front diff will be..
till next time....
Old 05-27-2015, 06:39 PM   #38
Thumbs up Re: Project Crossroad Blingmobile Midnight Special First FOFF Build
Originally Posted by lynxer View Post
Watersport tires?
Well I never thought of that.Might have water proof it though..
Old 05-30-2015, 06:57 PM   #39
Originally Posted by rustneversleeps View Post
Well here is the some of the bling i was talking about.hopefully everything goes the way it was planed but I'm sure i will be cutting and chopping some were in the build.
some of these parts will try to incorporate in the Foff...
Front AR60
Yeti Transmission and the rear cage that's the plan.I need a place to put my electronics so i figure the box would be a good addition to the CBMS
Also going to see if this roll cage will be in the build.looking for something different and extra long Axial drive shafts to get the lenght i want between 13" to 14"
front end in first on the agenda.......stay tune...
What links do u man on running and what length?
michfarmboy is offline   Reply With Quote
Old 05-30-2015, 07:03 PM   #40
bottom.
What mad you go with the wraith gearbox mount? I'm in the process of building my own but just using the scx10 mount?
Project Crossroad Blingmobile Midnight Special First FOFF Build - Similar Threads
project Night Fury-a rock bouncer build. warren 1.9 Scale Rigs 63 08-08-2013 03:30 PM
FOFF Build Project irp racing Formula Offroad 7 11-11-2012 03:45 PM
Mid afternoon to early night crawling at Lone Mountain. nine-ed Nevada 1 02-03-2012 11:58 PM
Mid Night Run - Kcrc comp #2 the DMG Competitions 42 03-30-2008 10:48 AM
