02-04-2015, 11:15 AM | #341 | |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
| Re: TorqueMaster BR Mini Packs the Power! Quote:
Just had one of my mini's kick the bucket, guess i'm going to have to go back the sidewinders till/if the new mini's come out So we're looking around April? | |
02-04-2015, 11:22 AM | #342 |
RCC Addict Join Date: Jun 2007 Location: Finland
| Re: TorqueMaster BR Mini Packs the Power! Mike, I got some from LockedupRC. I think there's still few left. |
02-04-2015, 11:23 AM | #343 |
We have them in stock now, got them on Monday!
02-04-2015, 11:25 AM | #344 |
RCC Addict Join Date: Aug 2013 Location: Calgary - in the Great White North
Wow, six weeks sure flies!
02-04-2015, 11:39 AM | #345 |
Fortunately it was not the full 6 weeks! We were preparing for a possible interrupt by the chinese new year since some of the components are sourced from China.
02-04-2015, 11:41 AM | #346 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: TorqueMaster BR Mini Packs the Power! |
02-04-2015, 01:30 PM | #347 |
Rock Crawler Join Date: May 2007 Location: Norwich
Ok so I couldn't get the dual sec setup from Holmes (out of stock) so I picked two up and went about wiring them up. can someone tell me how to link them to a airtronics Mt-4? all they do is flash red and green led's. Is there a set up button I'm not seeing? any help would be greatly appreciated -Curt |
02-04-2015, 01:43 PM | #348 | |
Quarry Creeper Join Date: Apr 2012 Location: france
02-04-2015, 01:44 PM | #349 | |
Turn on tx, hold full throttle, then plug battery in.. I calibrate mine separately with the use of the lever.. Roll it up, calibrate one.. Unplug truck.. Roll lever down, hold full throttle, plug truck in.. Calibration is.. Full throttle, beep.. Full reverse, beep.. Neutral, beep.. Calibrated! | |
02-04-2015, 01:53 PM | #350 |
That's what I did in the first place. It chimes, then beeps with both led's flashing?
02-04-2015, 02:13 PM | #351 |
Ok I was able to get one bound but not the other. I'm leaving the red wire connected and am using the esc to power the rx
02-04-2015, 02:16 PM | #352 |
02-04-2015, 02:45 PM | #353 |
I do both at the same time, dig switch at the middle |
02-04-2015, 03:53 PM | #354 |
#1 loose positive on the hh bec so I don't think the Rx was powered up - fixed #2 not being patient enough to let the br's do their thing - fixed Success! Now get everything neat and tidy Thank you gentlemen |
02-04-2015, 07:49 PM | #355 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
02-05-2015, 09:30 AM | #356 |
02-05-2015, 07:12 PM | #357 |
Thanks, Mike. Hopefully JRH has a version number imprinted on them to distinguish from the first edition. |
02-05-2015, 07:35 PM | #358 |
They have serial numbers and manufacturing dates on the RX wire. If it's not late 2014 or newer it is from the first batch. I'll add a mark to the PCB silkscreen for the next batch as a backup against people hacking off the RX wire. It took over a year to sell half of the first batch. It took about a week to sell half of the second batch These things work great as a winch controller! |
02-13-2015, 10:26 AM | #359 |
Quick question ...... MT4 takes 7.4 right into the RX. Two of these mashed together .... Red wire pulled from RX on both ESC's BEC set at 7.4 running into RX to power servo 4S packs ..... Safe?? |
02-16-2015, 06:12 PM | #360 |
Rock Stacker Join Date: Mar 2014 Location: Portsmouth
Quick question i hope First crawler..... With the be mini are the should it light up green going forward and red when backing up? Don't know if it maters but I didn't ever connect it to castle link or anything. Just wired it up and tested. Also I'm using a FM dual stick heli tx... Thanks |
Tags |
bad ass |
TorqueMaster BR Mini Packs the Power! - Similar Threads | ||||
TorqueMaster BR-XL Big Brushed Power! | JohnRobHolmes | Holmes Hobbies | 1351 | 05-13-2020 03:52 PM |
Mini torquemaster ???? | Mrblue | Losi Mini-Rock Crawler | 80 | 05-01-2010 08:59 PM |
