Go Back   RCCrawler Forums > Vendors > Holmes Hobbies
Thread: TorqueMaster BR Mini Packs the Power!
Old 02-13-2014, 12:46 PM   #301
Default Re: TorqueMaster BR Mini Packs the Power!
Sent you guys a msg yesterday 2-12-14 through your "Contact" section on your site.
Waiting for reply. Thank You.
gdb85 is offline   Reply With Quote
Old 02-19-2014, 06:34 PM   #302
Looking for an update on my esc's. Let me know I have emailed twice now. Thanks
mammoth is offline   Reply With Quote
Old 02-25-2014, 02:47 PM   #303
Originally Posted by Hulksta View Post
Any news on that guide yet? Got these sitting on desk waiting for a while but want to do the mod before using them.
Originally Posted by JohnRobHolmes View Post
I'm not going to publish it now. The zener mod fulfills the same need without hacking into the ESC. The overall response has been a lack of understanding and more dense material isn't the answer I would suggest you install a Zener to power your ESC brain in a cooler way, or just run them as you would normally wire an ESC.
but if you really want to hack, I'll send you an email
John can you send this email to me on esc hack?
tapped-out is offline   Reply With Quote
Old 02-25-2014, 04:19 PM   #304
JRH installed my BR minis last week. They are awesome. They have become the beauty which has tamed my savage beast motors.
Curcal is offline   Reply With Quote
Old 03-09-2014, 12:52 PM   #305
I see these available as "BR mini dual" ESCs pre smashed with smaller motor leads. Is it possible to order them with 13g wire?
picklewagon is offline   Reply With Quote
Old 04-06-2014, 06:30 PM   #306
John, i am having trouble calibrating the minis.... The instructions says hold full throttle on transmitter before the esc arms... I am holding the full throttle before i plug in the battery...then the esc arms and changes from green to red flashing with beeping. Then placed om full reverse, changes to green with beeping. Then on neutral changes to red with beeping. Am i doimg the calibration right? I am doing it one esc at a time...
xabs1582 is offline   Reply With Quote
Old 04-15-2014, 06:57 AM   #307
What kind of radio are you using xabs?
The process is...
hold full forward
plug in battery
wait for tones and flashing green to change to flashing red
hold full reverse
wait for tones and flashing yellow
return to neutral
wait for arming sequence to finish
should be ready to go
Just a recommendation...I take a rubber band and put it around the grip of my radio and use it to hold the throttle in full forward while I plug in the battery. Then slide the band off and continue the process...
ittybitty is offline   Reply With Quote
Old 04-15-2014, 10:09 AM   #308
i am using a futaba 4pl. i will try that out. Thanks
Old 04-15-2014, 12:55 PM   #309
Do you have the throttle channel "reversed" on your radio? If not...you need to.
Old 04-15-2014, 01:44 PM   #310
No, I did not. That could probably be the answer. I was doing the same process over and over with no luck. I'll try reversing the throttle channel and redo the calibration and see how it goes.
Old 04-16-2014, 10:14 AM   #311
I tried out what you suggested ittybitty and got the esc calibrated. Now everything is all fired up. Thanks for the help.
Old 04-30-2014, 06:48 PM   #312
Location: Taylors Falls just hanging with the MNRCRC crew.
Just drove my new BR Mini in my Sporty and without question it's the best ESC i've ever owned. I followed the number one Cool Wiring method and the BR Mini had no heat issues what so ever. My testing session of steady abuse was for a total of forty five minutes and it never got beyond warm.
Great product John now I'm going to have to get a Mini Stack for my Pro rig.
Stormin2u is offline   Reply With Quote
Old 05-01-2014, 07:21 AM   #313
No problem...glad it worked out for you
Old 05-20-2014, 04:32 PM   #314
I am switching from a brxl to the mini on my shafty, I used to have the castle bec set at 7.4v to give current to rx and servo (both support that voltage) and the red wire disconnected from the esc plug. Battery is 3s. Can I adopt the same setup with the mini or it is required to have the red wire connected to the esc?
Thanks!
musta is offline   Reply With Quote
Old 05-21-2014, 03:47 AM   #315
You can use the same setup.
winnerone23 is offline   Reply With Quote
Old 05-21-2014, 04:34 AM   #316
Thanks!
Old 08-25-2014, 02:00 PM   #317
Anyone tried the mini in a Super with 4s lipo?
Motors are 45T
For now i have the BRXL inside but will switch to the Minis
fritzthefly is offline   Reply With Quote
Old 08-31-2014, 09:06 PM   #318
Ty
Motors are 45T
That's what I run in my super. 45t Brood stubbys on 4s. Works great! Ty
Ty is offline   Reply With Quote
Old 10-09-2014, 06:34 PM   #319
Installed new duel Torquemaster BR minis- Also a new radio MT-4. Does the throttle need to be reversed? The speed controls did program ok.
I took the old motors out of my XR10(one year old 16t 5 segment). Installed the motors in Bully 2. They went backwards. So I swapped the motors front to rear.
It's faster in reverse then forward. Do I need to adjust the timing on the motors?
There are much smoother then the FXR's they replaced.
Does this mean the motors are the same rotation as a Berg?
Thanks
Matt
SDheavymetal is offline   Reply With Quote
Old 10-09-2014, 06:52 PM   #320
Nah, the throttle is correct. Ur motors either need the timing retarded or put them back where they where, front and rear, and rotate ur end bell 180.
It's easiest to loosen the screw's and retard ur timing..
Any other MT-4 questions, I'm up on that as well. Love that tx!
By far my favorite!
Tags
bad ass
TorqueMaster BR Mini Packs the Power! - Similar Threads
TorqueMaster BR-XL Big Brushed Power! JohnRobHolmes Holmes Hobbies 1351 05-13-2020 03:52 PM
Mini torquemaster ???? Mrblue Losi Mini-Rock Crawler 80 05-01-2010 08:59 PM
You may edit your posts
