02-05-2008, 03:40 AM | #381 |
Rock Crawler Join Date: Aug 2007 Location: Nelson NewZealand Team RC4WD
Hi John, I am looking to upgrade the motor&esc in my fj45, its a 1/8 heavy beast of a thing and is currently running on a old rooster with a 550 motor. (probably came from a drill) I want to keep the rig on 6 cells, but the current setup stalls to easily. Its already geared pretty low (highlift axles, buggy trans and rc4wd 2:1 reduction) but I could lower the gearing if needed. Is something like a crawlmaster/sidewinder combo going to have more torque than a 550 or is my only hope to raise voltage and gear down? currently the rig just cant get out of a bind, and the motor gets fairly hot. can you ship to nz? Thanks Leo oh, I am kinda on a budget. Last edited by Fracture; 02-05-2008 at 03:42 AM. |
02-05-2008, 07:57 AM | #382 |
I do ship to NZ. If you want to keep with 6 cells, you will have to gear down to get more torque from the average system. One option would be a 35t motor at zero timing. It might be a bit slower that what you run, but it would produce a bit more torque. Since you already run a 550 can motor, you should be able to run a Cobalt Puller motor. That would certainly give you more torque. The third option would be an outrunner like the Crawlmaster. On 6 cells you wont have much wheelspeed at all, it would be slow compared to the current motor you have. But, the torque would be a class above. What is your budget? |
02-06-2008, 05:18 PM | #383 |
John I'm building a super,would setup for electronics be alright ? vislero 2100 siderwinder 7t puller cc bec jr8711 servos |
02-06-2008, 05:30 PM | #384 |
I would use the 10t Puller and more battery if this is a shafty. What axles and tranny?
02-06-2008, 05:40 PM | #385 |
| tf axles, either pede or emaxx locked in 1st haven't made up mind yet. I was thinking the 7t for happy medium.But if a 10t will push this rig around better. what lipo then ? 4cell and up ? If so, then what esc since the max and sidewinder only go up to a 3cell.Also what should I be looking for on the continuous bust for this rig?
02-07-2008, 03:23 PM | #386 |
Quarry Creeper Join Date: Jul 2006 Location: PDX
Ok, here's the specs: Twin axles with XL's Hyperion Z3013-16 thru a T4 stealth with a Mamba 25 and CC BEC 2 HT 5955's Vislero 2100 3S Seems to work great but I am new to the brushless game. What is the max temps I should watch for on the motor, and the ESC? I ran it for the first time last night and while nothing drastic happened the ESC did get a little warm to the touch, NOT hot, just warm. I just got a IR temp gun to verify the difference between warm and hot but want to know what to look for. Any thing else I should pay attention to? |
02-10-2008, 10:01 PM | #387 |
Hey John, did you get my email regarding an order? Should I resend it? I just wanna get a sidewinder/crawlmastersport combo, it wont let me buy through your site as I am in nz. Will a sidewinder handle haulin a heavy, low geared rig with a crawlmaster, or do I really need a Mamba Max? Thanks Leo Last edited by Fracture; 02-11-2008 at 01:28 AM. |
02-11-2008, 01:42 AM | #388 |
Newbie Join Date: Sep 2007 Location: La Jolla
| Lipo charger/balancer.
Hello John, Quick question bout' a Lipo charger/balancer you carry, as I recall it's the hyperion EOSO606I....i think. Anyway, need to know if the balancing port has a hyperion/apache connection? I know it has a multi-port adaptor but, just want to make sure. Also, do I need to make my own charger to battery output plugs....and if so what or which one can I use?..gonna use it w/traxxas hi-current plugs. Can this be shipped UPS? thanks |
02-11-2008, 04:45 PM | #389 |
Rock Crawler Join Date: Jul 2007 Location: Portland,OR
I may be getting a side winder in trade for a bad MM form castle. They wanna send me the 4600 KV combo. That's waay too much for crawling right? It'll be my first BL so I'm in the dark. Still reading and searching. Any suggestions?? |
02-13-2008, 11:51 AM | #390 |
Rock Crawler Join Date: Aug 2006 Location: Pinedale, WY
Im converting my J2-TT rig to Brushless/LiPO. Im running a MM and wanting to know if Scorpion 2215-22 is the motor for me. I want to run a 3C Lipo. Hyperion EOS0606I is the charger i want to use will it charge the Vislero 1300 3s lipo battery you sell? Do i need a BEC if im only running a HiTEC 645MG?
02-13-2008, 12:12 PM | #391 | ||||||
A 10t would push a heavy vehicle around with less heat. I wouldn't go beyond a 3 cell lipo. The continuous will vary on your gearing and rig weight. I would want to use minimum a 2100 15C lipo, maybe larger. | ||||||
02-13-2008, 12:59 PM | #392 |
Quarry Creeper Join Date: Apr 2007 Location: YAKIMA
hey jrh i was wondering what is a good power supply for the eos1210i charger i am looking at the ofna but not sure if it would work thanks chad |
02-13-2008, 01:10 PM | #393 |
Anything with 12-15v and at least 10 amps depending on battery that you are charging will work. I have not gotten into the power supply market yet, as the major suppliers sell at wholesale to the public. The best power supplies will be expensive. You might try to search RCgroups to see what they have to say.
02-13-2008, 01:17 PM | #394 |
thanks for the info jrh i appreciate it
02-14-2008, 09:23 AM | #395 |
Newbie Join Date: Jan 2008 Location: So.Cal
| How longs the back order for Colbat puller 10t?
My rig is ready to go, less the motor, ESC and batteries. How long is the wait? If it too long I may go in another direction. Thanks.
02-14-2008, 10:10 AM | #396 |
02-14-2008, 11:35 AM | #397 |
| Thanks, Can you set me up with some
lipo batteries and a charger for my rig. Let me know the $ and I'll paypal the funds, thanks again John
02-16-2008, 11:20 AM | #398 |
| adaptor for lipo balancer.............
JRH, Does the Thunder power balancing adaptor (on your site) plug-in directly to the Hyperion EOSO606I. I just realized that my balancing adaptor is a TP plug not a Hyperion......................Thanks |
02-16-2008, 11:55 AM | #399 |
Rock Crawler Join Date: Sep 2007 Location: University City
Holmes- im looking at going brushless in my tuber. Right now im runnning an 55t lathe with 8 cells and a telkin esc, this is going through a 14t pinion and an axial tranny to TLT axles. Im looking to get either a sidewinder or mamba max esc and some sort of small brushless. the problem is space is at a premium in my buggy and the 540 JUST fits (and actually is a little too close to the chassis for comfort). ive been looking at the BM9, eflight park 400, and your Scorpion 2215-22. How does the scorpion compare to the other two as well as a 55t lathe? |
02-16-2008, 12:41 PM | #400 |
this is a real stupid question but hey jrh on your hyperion eos1210i is it the hyperion eos1210i 30n charger on your site |
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
