12-04-2007, 08:12 PM | #141 |
12-04-2007, 08:17 PM | #142 |
Use the middle two, shoulda just told me which one it was! Lol!
12-04-2007, 08:53 PM | #143 |
12-04-2007, 08:57 PM | #144 |
Totally fine, you wont be passing many watts.
12-05-2007, 11:39 AM | #145 |
Hi JRH, when are you getting any more cool becs in stock? i just hooked up one i got from you a couple months ago, and it's simple and it works great, i did however order the castle bec from you today, i would still like to get a couple of the cool bec to have around.
12-05-2007, 11:50 AM | #146 |
I have them right now, actually updated the inventory before you had placed your orders.
12-05-2007, 12:21 PM | #147 |
Can we combine shipping on the previous order if i get 2 cool becs?
12-05-2007, 06:07 PM | #148 |
12-05-2007, 10:04 PM | #149 |
JRH, is it ok to run my Mamba Max at 6.6 volts? How about with a 5700 motor?
12-05-2007, 11:22 PM | #150 | |
Yeah, it will be ok. The MM will work fine, but the motor will be kinda sluggish unless you run two parallel a123 packs to allow it to have some amp draw to work with. I would run 4s a123 instead. | |
12-06-2007, 01:08 PM | #151 |
Next question? Can I take apart A123 packs and solder them back together? Or do I need to do something special? I ran the 5700 at 6.6 this morning, more than enough for my needs right now! |
12-06-2007, 06:35 PM | #152 |
Im sure you can take it apart, I don't know if the cells will be solderable though. I have read that they damage easy with direct soldering.
12-08-2007, 09:56 AM | #153 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
John, I'm looking to upgrade my Hustler Super for next season and I'd appreciate hearing your thoughts on this. I currently run a Novak Super Duty, Hi Tec 5645's, Integy 55's, and a TQ3 mod all powered by a Max Amps 2s3p 3300 lipo. I'm looking to upgrade to this, running the same Max Amps lipo: Mamba Max ESC Integy V11 55's or 65's w/ 8 tooth pinions Hi Tec 5955TG's Older DX3 Tx or TQ3 mod Will my lipo power this set up efficiently, and might you have any suggestions for me? I am limited by budget to run only 1 ESC and I really dig the Integy brushed motors. Thanks for your time. |
12-08-2007, 11:50 AM | #154 |
Your lipo should do the task no problem. I would suggest the v11 55t. I would also suggest a Castle BEC for your steering duty.
12-09-2007, 08:16 PM | #155 |
Rock Crawler Join Date: May 2007 Location: Salt Lake City
So if the 0606I does not come with output leads then what all do you need to buy with it to charge lipos and cells? I would like to buy all of it at once..
12-10-2007, 02:20 PM | #156 |
| 4mm bullit plugs, wire, and your choice of battery connector. I'm just gonna throw that stuff in for anybody who buys the charger anyway, so don't sweat it at this point. Somebody would look over that point and be very dissapointed when they got the charger.
12-10-2007, 06:22 PM | #157 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
is it bad to run 7.2 volts through my airtronics 92836 receiver? it says" DO NOT use more than 6 volts to power receiver.anything higher will burn up and destroy receiver."
12-10-2007, 06:31 PM | #158 | |
RCC Addict Join Date: Jun 2007 Location: Indian Village Pontiac
Now See!!! Thats customer service!!! Support the Vendors!!!! | |
12-10-2007, 06:50 PM | #159 |
Mr. Holmes, what wires go where on the balance plug on A123 cells on a 3 cell?
12-10-2007, 10:51 PM | #160 | ||
Which balance plug? A factory a123? | ||
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
