08-14-2009, 07:16 AM | #1821 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
I was looking up specs on the Hyp Z3025 I got from you a ways back, and have no idea what turn they were, do you remember? Looks like they came in 6, 8, 10, and 12T varieties. Thanks! Huh, imagine that, it's stamped on the motor, 8T. Last edited by Thorsteenster; 08-14-2009 at 06:48 PM. |
08-15-2009, 01:26 AM | #1822 |
Newbie Join Date: Aug 2009 Location: Waynesville,Ohio
I want a ax10 rtc and it says it requires a 7.2v 6cell w/standard connector well what is standard? Soory for such an elementry ? But i just don't know
08-16-2009, 09:48 AM | #1823 |
RCC Addict Join Date: Apr 2007 Location: RAMBLIN
thanks for the info on the esc's. i got my button finger ready for paypal. will you have a few availible?
08-16-2009, 01:22 PM | #1824 | |
I wanna be Dave Join Date: Sep 2006 Location: Stuck on a Rig in the middle of nowhere Utah.
I am running 2 FXRs on my Hustler with 8t pinions and 2 hs5955tg servos with one CC BEC. It runs great with a 2200mah 3s. The wheel speed is perfect and tons of torque. I am getting about 45min of hard crawl time out of the batteries. Also that is with 55t motors. Just wanted to let you know. I do have a couple of vids that show it working if you want. I was running 2 7cell 4500mah nuckle packs, but made the switch to lipo, WOW, I will never run Nimh again. | |
08-19-2009, 02:23 PM | #1825 | |||||||
The FXR will take the 454s, not sure about the novak. I don't recommend 3s use with them, as they will heat up fast. You would use the adapter plate that comes with the motors, and the thundertech plate for pinion adjustment. I would just bend the lower links Quote:
There was a firmware glitch on the first batch. I should have just under 100 ESCs in the first batch once it is fixed. | |||||||
08-20-2009, 10:43 PM | #1826 |
Rock Stacker Join Date: Apr 2009 Location: Brownsburg, Indiana
thanks |
08-25-2009, 01:36 PM | #1827 |
Sent you an email about 454's on the berg. I couldnt find much tech in my search. Any pros/cons suggestions?
08-26-2009, 01:10 PM | #1828 |
email back at you.
08-27-2009, 03:58 PM | #1829 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
hey john! i was wondering if you could help me out. oh great guru of the elec motors! i want a brushless setup for my mini mrc. im looking at the novak mongoose or mamba micro pro w/4200kv?? what would be best? i will be running a 2s lipo on it. thank you sir! i await your ruling. |
08-27-2009, 05:12 PM | #1830 |
I dont' have any experience with the brushless in the losi mini. I do know that the sensored motor should be more controllable at zero rpm, but one of my drivers said the Castle system worked extremely well for him. I can't really give good guidance on that particular selection. |
08-28-2009, 11:50 AM | #1831 |
Rock Crawler Join Date: Aug 2007 Location: mesa az
Hey John i need to see if i can get a replacement end bell for a torque master pro just the grey plastic bearing holder portion or complete what ever is easier. I sent you an email asking this same question. I also looked through your website but did not see an option for the end bell. paypal is ready and waiting. thanks matt
08-29-2009, 02:27 PM | #1832 |
Pebble Pounder Join Date: Oct 2005 Location: Rocklin / Ukiah, CA
Hello Mr. Holmes, I am on your website and I need to order the Castle BEC. I see that the most common voltage setting it 6V. I just want to make sure I order the correct voltage for my setup. I am running a ax10 with the following: Tekin pro 45t Tekin FRX Hitec HS-7955TG servo 3S 1500mah 25c lipo Do you still suggest the 6v setting? Thank you for all your help. I will send the order once I know what to get. Thank you, Steve |
09-03-2009, 06:10 PM | #1833 |
Rock Stacker Join Date: Nov 2008 Location: Wheatland
Mr. holmes, i have an ax10 comp rig, it currently has a rooster on 2s lipo and a 35t integy. my q is im gonna put the rooster on my super maxx rig so i need a new esc for my ax10. im gonna keep the 35t motor on it for now but eventualy i wanna go to a puller motor on 3s, so what esc is best for my situation. thanks im sure you've had this ? asked a bunch of times |
09-04-2009, 02:55 PM | #1834 |
Newbie Join Date: Dec 2008 Location: northern ca
| zapping magnets
ZAPPING MAGNETS HI John kinda new to this hobby, but just woundering what the term zapping magnets meant? Someone told me that it increase the magnet strenght. If so then how is this done and what would I need to do it. I'm using a stock 550 can motor in one of my boats and there are no timing adjustments to improve the performance of this motor basically a throw away motor please elaborate on this thanks.
09-04-2009, 03:15 PM | #1835 |
| Zapping magnets
Hi John I'm new to this hobby and heard a term used the other day. Zapping magnets, it's suppose to increase the strenght of the magnets. Is this possible and what is it? Can this be done? What is needed to do it? I am currently using a 12t 550 silver can motor in my boat and looking to improve the performance. I know it is basically a throw away motor but any tips you have to improve the performance would be much appreciated thanks
09-04-2009, 03:50 PM | #1836 | |||
09-04-2009, 04:04 PM | #1837 |
ok what discharge rate lipo are you using with your 454's ? also , what pinions are you using for them on your berg? i love them so fsr but with the lipo's i have it stalls the motors a little . any suggestions?
09-04-2009, 04:07 PM | #1838 |
I will use my 1300 3s 25c for comp use (the lipo warms up) or 2200 2s lipos for playing around. 3s makes the motors get very warm to hot. The 454's will stall out more than a stout 540, as they are smaller and do not have as much power. |
09-04-2009, 07:17 PM | #1839 |
DAAAANZ, You have to be able to take the motor apart to zap the magnets correctly, because a steel slug has to go in place of the armature to get the full effect of the zap. Since that motor can't be taken apart (easily), it pretty much can't be done. I know of people that have zapped motors with the arm still in the can, and it doesn't work so well. Don't ask me how I know......
09-04-2009, 08:18 PM | #1840 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
What ya got that would be good for a rj drag car? How would a 7t puller do? I have a 500 puller and love it in the crawler. |
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
