09-14-2009, 06:38 AM | #1861 |
Great. Thanks. I have a super small 2c alarm I got from maxamps ages ago. Its probably 1"x0.5". And that 2000mah lipo should last forever. Again, Thanks for your help. |
09-14-2009, 06:39 AM | #1862 |
No problem.
09-14-2009, 06:55 AM | #1863 |
Well,one more question. That balancing tap isn't standard (2c alarm is align) so I found another pack that fits but it has ~16AWG wires, as any battery would. Are there any draw backs from soldering on a JST connector with 22AWG wire to fit the react connection? Basically the 16AWG TO 22AWG issue. |
09-14-2009, 07:09 AM | #1864 |
that is what I did on mine. No issues at all.
09-14-2009, 07:21 AM | #1865 |
Ok, thanks once again for the super fast response.
09-14-2009, 07:42 PM | #1866 |
Pebble Pounder Join Date: Oct 2007 Location: Belgium
John, I'm starting a rock racer build and was wondering about the electronics. On my 2.2 crawler I have your 45t, sidewinder and 3s 1600 and the combo is great, love the wheelspeed and the torque snaps CVD pins... I ordered the sidewinder along with your 30t, what would you suggest for a battery size? 2s or 3s? What mah? I would like to keep it light, have some low range torque for crawling along with the wheelspeed, but also some runtime. Not yet sure how much space I will have for the battery so that might restrict the choices also.
09-18-2009, 09:25 AM | #1867 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
John, Im currently runnning a 500 cobalt in my Bronco scaler. I love how it drives, but Im still having heat issues. Any idea when youll have more of these in stock? Id like to have a back up. Do you have any brushes available right now? What would you say if I wanted to replace this motor/esc set up with a Tekin RS brushless combo? Would I have the same crawlability along with plenty of wheelspeed? What turn motor would I want? I just want to be sure Ill be happy with it before I invest $300 in a motor/esc. Can I expect cooler temps and longer run times? How about cogging or slow speed control? I know, lots of questions...thanks in advance. Tim.
09-19-2009, 07:59 PM | #1868 |
RCC Addict Join Date: Feb 2006 Location: ccxc
7t cobalt in an Axial. Just use it for bashing. Can you recommend a lipo?
09-22-2009, 10:23 AM | #1869 |
Rock Crawler Join Date: Nov 2008 Location: SoCal
John, Will the 7T Puller on a 2S in a scale rig kill a Castle Sidewinder sport ESC? Thanks |
09-22-2009, 10:29 AM | #1870 | |||
An RS combo is a great setup. You will have more overall power available, less motor heat, and plenty of control. downside is more weight. In sensored mode there is no cogging. In hybrid mode (last I checked) they will stop pushing if you bind it up. Quote:
A 1/10 sidewinder would be just fine. | |||
09-22-2009, 10:56 PM | #1871 |
| Thanks John. What turn motor would I look for (in the Tekin RS/Redline) if I wanted the same kind of wheelspeed as the 14t cobalt has? 17.5t, 21.5t?
09-23-2009, 05:55 AM | #1872 |
17.5 would be a close match.
09-23-2009, 05:12 PM | #1873 |
RCC Addict Join Date: May 2009 Location: Weston
I'm in the process of building a clod super and I was going to run 2 55t motors on a sidewinder but I just picked up another sidewinder and I was thinking of running brushless. Any suggestions on motors/gearing on 3s lipo's? Thanks |
09-23-2009, 09:07 PM | #1874 |
Quarry Creeper Join Date: Jul 2008 Location: peoria
is the 12t in the link good enough to run in a 2.2 axial on a 3 cell http://www.rccrawler.com/forum/showthread.php?t=200993 Last edited by dunerdude69; 09-23-2009 at 09:17 PM. |
09-28-2009, 08:59 AM | #1875 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
What do I need to balance a Losi 600mah lipo with my EOS606i? I think it's the HP-LB10-TP .... Last edited by Locked Up; 09-28-2009 at 09:35 AM. |
09-29-2009, 07:45 PM | #1876 |
Pebble Pounder Join Date: Jul 2009 Location: southport
| ok i have recieved the 7t pullers and was wondering what pinions fit them??? i am trying to run a moa lcc and couldnt get the ones in the kit to work???
09-30-2009, 06:43 PM | #1877 |
Pebble Pounder Join Date: Apr 2008 Location: greenville
i was just wondering if a mamba 25 could handle a 7t puller for short runs in a comp?
09-30-2009, 07:23 PM | #1878 | ||||
Nope, no way. | ||||
10-01-2009, 08:14 AM | #1879 |
Gold Star Baby! Join Date: Jan 2009 Location: Oroville
John, I sent you an email. Need an answer asap cause im leaving for work soon. I also would need a special invoice made on your sight for payment for overnight shipment. You only have the option for 1-2 days |
10-01-2009, 09:00 AM | #1880 |
I don't see an email regarding this.
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
