Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: bigger than 2.2
Old 06-09-2014, 05:29 AM   #1
Default bigger than 2.2
What rims are people using that are bigger than 2.2 but dont run a traxxas bead??
im looking for some 2.5 - 2.8 size rims. and dont specifically have to be beadlock.
ive searched google and found the proline 2.8 rims but they have the traxxas bead, and everywhere else is discontinued.
any ideas?
klampykixx is offline   Reply With Quote
Old 06-09-2014, 01:59 PM   #2
Default Re: bigger than 2.2
The question is what kind of tires do you want to run and why?
67mustang is offline   Reply With Quote
Old 06-09-2014, 03:21 PM   #3
Motoworx 2.8 beadlocks. Cost an arm and a leg but best ones I've seen yet. You can backorder and he will build for you...
joelrobbo is offline   Reply With Quote
Old 06-09-2014, 04:55 PM   #4
yes i saw those, just a little above my budget unfortunately. and im not really a fan of the design.
Old 06-09-2014, 05:21 PM   #5
heres my build for those wondering why i want them.
Klampyz F350
basically, 2.2 rims just look too small. i have ordered 2.2 baja claws for the 5.8inch height. i tried fitting up 40 series tires but i feel theyre just a little on the large side.
i tried asking Duuuuuude if he could make me some non beadlock 2.5 inch rims but hes not happy with how the glue groove comes out so knocked me back there.
heres a set of 40 series i glued 2.2 sidewalls into.
compared to the 2.2 treps.
i feel like the new Baja claws will be just the right size, but its still the rims that look a little too small as theyd scale out to 13inch which is truly a bit small for this truck.
Old 06-09-2014, 08:08 PM   #6
So you want it to "scale out"? Or do you want big exagerrated wheels? Are you dead set on 2.8s? Check out rc planet...they have hundreds of wheels.
Old 06-09-2014, 08:11 PM   #7
Yeh close to true scale size. Doesnt have to be "2.8" but def bigger than 2.2
I have no fear on stretching tires a little, i just feel the 2.2s get lost under such a large truck.
Unless you all think it looks ok with the 2.2s
Old 06-09-2014, 08:11 PM   #8
Double post
Old 06-09-2014, 08:33 PM   #9
Nah. Go 2.8. 2.2s are too small. I would cut n shut the tires to 6.5 or so...but thats just me.
Old 06-09-2014, 08:47 PM   #10
thats actually not a bad idea. i may consider doing this if theyre still too small once they arrive. i was considering running 17mm hex buggy rims at 3.0 but reversing out the dish. could work. hmmmm
ill wait and see how the the claws look once they get here.
thanks for all the input so far.
Old 06-11-2014, 07:36 AM   #11
I use the 2.2 RC4WD Baja Claws with the Gmade gt 2.2 air wheels ($21).
The stock baja claws are 145mm height and 52,5 width and when inflated to 35mmHg (0.67psi / 0,05bar) they become 160mm height and 60mm width, which is 6,3inches. Also they look very cool, they have a nice round sidewall!
Here is a picture of them mounted on my prototype 1:6 Jeep Wrangler TJ:
OneSixthScaleRC is offline   Reply With Quote
Old 06-11-2014, 07:44 AM   #12
that actually looks pretty good, where did you get the rims for $21?? o_0 everywhere i look theyre up in the $100+ range??? the 2.2 rims still look a little small, but maybe thats just gonna have to be accepted.. im not paying for the metal 2.8 beadlocks.
here is my post in the other thread i started in the wheel n tire section.
Originally Posted by klampy
im personally not a fan of the style ive seen of motorworx 2.8 beadlocks, plus theyre just a tad above my budget.
i found that 1/10 size monster truck wheels are 3.0 with a 12mm hex, and a lip on the outer edge instead of the "traxxas bead" so i should be able to confortably stretch on a set of tall 2.2 tires and have it be somewhat ok.
here is a 3.0 buggy rim with the traxxas bead, i managed to cut a 1.9 trepador tire and add a couple sections in to make the tire have a 2.8 size bead. measures 140mm on the O.D
what im going to try is to buy some cheap car tire valves, and glue them into the rim and pump them up to make them a bit bigger, plus have pressure to attempt to hold up the truck. i estimate it will end up around the 10kg mark when its all finished up and full of fuel and batteries servos axles etc.
this tire (on its way to me across the pond) @ 148mm tall. just a little taller than the enlarged 1.9 trep^^
on these rims>
any other suggestions on rims before i pull the trigger on those ones^^^ ??
Old 06-11-2014, 07:50 AM   #13
is the GT air system just a needle valve style fitting? im sure i can retrofit something similar into some bigger rims, as i was already considering trying to glue in car valves....
Old 06-11-2014, 08:36 AM   #14
Gmade Gt air wheels:
2.2 GT Air system beadlock wheels (2) [GM70081] : JunFac.com
Yes, they are needle valve configuration, I use a manual blood pressure meter (sphygmomanometer) to inflate them to accurate pressure.
Here are some pictures of the valve:
GMade/Junfac Pneumatic wheel system - Forums
Old 06-11-2014, 04:19 PM   #15
I have the same thoughts about the 2.2's under my 1/6th Willys Jeep, the wheel scales out to a 13" wheel. A 2.5 wheel would give a 15" scale wheel, a 2.8 gives a 17" scale wheel which wouldn't really be out of place by today's standards for aftermarket wheels. My personal issue would be making a set of tires. I absolutely suck at "cut and shut" modifying tires.
Since the large scale segment of off-road RC is such a tiny market, I wouldn't expect any manufacturers to be making wheels/tires for us.
BigSki is offline   Reply With Quote
Old 06-11-2014, 07:10 PM   #16
yeh, the thing about 2.8 rims is they were common at one point. some of the monster trucks from HPI and others back in the day all ran nice deep dished, wide offset 2.8 size rims.
these days they seem to have stepped up to 3.0 instead.. which makes a 6th scale vehicle run 18inch rims. also not out of the question, but not exactly common place either. oh well. ill be placing my order for the 3.0 rims i put up^^ tonight so will see how they fit up when i get them .
i am very much a fan of the inflated tires tho. and do strongly believe ill be going that way about it. ill have to find some cheap valves ..
Old 06-12-2014, 07:49 AM   #17
If you find valves or anything else related to air tires please post it here. Apart from the air wheels, I have a couple of non-air wheels that I am willing to convert to air.
I tried contacting gmade to request replacement rubber valves for their wheels but after more than a week still no response. I will try to contact Junfac, the principal gmade distributor.
Also as an idea you maybe could use sport ball valves (basketball/football/volleyball....). I don't know if you can find anything smaller than that apart from in a specialty shop or from some chinese supplier.
Old 06-12-2014, 08:38 AM   #18
I found some short car style valves on ebay for $1 each that in considering but for a 2.2 rim theyll be a bit bulky.
So beyond that ill search for the rubber style ones and see how i go. Will definitely post up what i find.
Old 06-18-2014, 03:49 AM   #19
Found some aquarium check valves. Ill set one up in a donor rim and see how it goes first. Ill put up pics once they get here from china.
Old 06-27-2014, 10:16 PM   #20
my tires arrived
and i also scored a set of the Exceed 2.8 beadlocks, and slipped one on.
problem is, when i blow air into the tire it balloons out like a big round donut.
i figure if i put tape inside the tread then it wont expand the way i want it to. and as the tread is SUPER SUPER soft, stretchy and sticky, its going to make it very thin and id be nervous about it puncturing/ tearing
im thinking i might just run with the exceed tires as theyre a much stiffer rubber and just keep the claws for another build.
id love to slip in a small inner tube, coz then i can slip in a tougher inner ring to support the tread, just not sure what tubes id buy for a 2.8 inch rim size? any suggestions?
bigger than 2.2 - Similar Threads
2.2 or bigger? fstrnu Tamiya Clod Buster 7 12-28-2009 09:27 AM
bigger motors themichavo Duratrax Cliff Climber 17 09-30-2009 01:56 PM
need to go bigger ax-10 victor Axial AX-10 Scorpion 23 02-07-2009 12:59 AM
Bigger Tires on WK RockRider HPI Wheely King 20 06-15-2008 06:46 AM
i want bigger tyres!!! kiwi trasher Tires and Wheels 0 09-28-2007 02:58 AM
