12-27-2013, 04:39 PM | #281 |
| Re: Behind Enemy Lines
Sarge knows if she is safe or not.... he didn't make it this far by being a fool. |
12-29-2013, 04:21 PM | #282 |
Rock Crawler Join Date: Feb 2012 Location: Wisconsin
Got to get the rear lights working so a soldering I will go... (BTW - Heyok did a soldering tutorial on his "All of his stuff on one page" post in the vendor electronics thread that saved my bacon when it comes to understanding how diodes & LED's work with each other to allow us to have lighted rigs. His advice and help on how & what to use has allowed me to properly wire up my Jeep. Thanks Al !!!) Got the brake lights working And the reverse lights too... Last edited by Fumbles; 12-31-2013 at 10:40 PM. |
12-29-2013, 04:25 PM | #283 |
| Re: Behind Enemy Lines |
12-29-2013, 04:28 PM | #284 |
12-29-2013, 04:53 PM | #285 |
| Re: Behind Enemy Lines I'm Soooo interested in seeing how well that winch works, I've been eyeing up one of those for a while myself.
01-05-2014, 04:07 PM | #286 |
Been battling a short in a wire, never could find it so I ripped out the wires running from front to back in the harness and tracked down the short. Then I had a great idea - I added 4 wires into the bundle so that if I run into another problem I can just bypass the trouble wire and swap to one of the 4 unused wires... BOOYAH ! |
01-05-2014, 04:11 PM | #287 |
01-05-2014, 04:14 PM | #288 |
It's so stinking cold in the garage I'll wait until next week to weld up a mount for the winch.
01-06-2014, 04:15 AM | #289 |
Rock Stacker Join Date: May 2013 Location: Brownsburg, IN
01-12-2014, 07:56 PM | #290 |
Well, I've got to figure out how to run the winch line from the rear to the front bumper... Figure I'd bend up some tubing and lay it along the underside of the chassis. No vice around here so I'll just get creative ... Here's what I ended up with... Last edited by Fumbles; 01-12-2014 at 08:21 PM. |
01-12-2014, 08:14 PM | #291 |
Well, well, well... received a package from CrawlerDad and figured I'd check them out to see what it is... What are these little things? Sooo tiny...I could fit them in my pocket. They'd fit into my headlight buckets if I needed them too... But they can't be that bright. Maybe I should test them to see how bright they are... Aaaaannnnnddddd power on... AAAAHHHHHHHHHHHH! I did it again !!! Last edited by Fumbles; 01-12-2014 at 08:26 PM. |
01-12-2014, 08:35 PM | #292 |
01-13-2014, 04:42 PM | #293 |
| Behind Enemy Lines
Gotta get the winch mounted so here's where the winch line will go into the tube that runs along the underside of the chassis. Mounted the winch in a metal bracket... Needed to raise it up for a smooth transition for the line to go into the tube so I'll use this metal plate as a spacer to help line it all up. Last edited by Fumbles; 01-14-2014 at 03:39 AM. |
01-13-2014, 04:54 PM | #294 |
01-13-2014, 04:57 PM | #295 |
01-13-2014, 05:00 PM | #296 |
01-14-2014, 12:17 AM | #297 |
It is always a joy reading this. I even read it to my kids last night and they got a few good laughs out of it.
01-14-2014, 06:45 PM | #298 |
01-14-2014, 06:47 PM | #299 |
01-14-2014, 06:49 PM | #300 |
Behind Enemy Lines - Similar Threads | ||||
Operation Black Ops: "Behind Enemy Lines" Part 2 Axial Jeep Unlimited Rubicon JK | LetsGoMuddin | Scale Videos! | 0 | 06-02-2012 11:28 AM |
Operation Black Ops: "Behind Enemy Lines" Part 1 Axial Jeep Unlimited Rubicon JK | LetsGoMuddin | Scale Videos! | 2 | 06-02-2012 11:27 AM |
door lines and panel lines (sharpie alternative) | heinie_21 | Paint and Body | 10 | 12-23-2011 08:32 AM |
Wolfenstein Enemy Territory (free download)anyone get into it? | TheHeadHunter | Chit Chat | 12 | 06-15-2008 07:41 AM |
