04-12-2015, 08:30 PM | #41 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
| Re: Mudbeast's Willies build
I hear ya GST. |
04-13-2015, 05:06 AM | #42 |
Rock Crawler Join Date: Aug 2012 Location: Port St Lucie
| Re: Mudbeast's Willies build Its only fast because other guys figured it out & posted directions. I thank all the previous builders for helping me with mine.
04-13-2015, 09:12 PM | #43 |
Any updates? ?? 😈
04-14-2015, 09:27 AM | #44 |
Yesterday I received my locked up RC slipper delete kit & their mega truck driveshaft 80-100mm. To go between the transmission & transfer case. The slipper kit gives you the room you need to fit the motor & tranny in the engine compartment. The mega truck driveshaft fit like a glove it is perfect for this build. I then measured up for a battery tray & bent up some aluminum. Then I put the rest of the component in the engine compartment & took her for a spin through the house on a 2s battery. The drivetrain sounds great & very smooth! It is slow due to the reduction in the transfer case. But I'll see how it is on 3s. If I can't get the wheel speed I like I may have to up the pinion a little. Mock up is just about done. Once she's completed I'll tear her down & get the metal painted & reassembled. More to come! Sent from my iPhone using Tapatalk |
04-14-2015, 03:48 PM | #45 |
Lookin' GREAT, what gears are you runnig now?
04-14-2015, 03:50 PM | #46 |
16/87 Sent from my iPhone using Tapatalk |
04-14-2015, 04:03 PM | #47 |
What other pinions do you have? Also how much room do you have under the hood between the top of the spur and underside of the hood?
04-14-2015, 05:28 PM | #48 |
I have a 14 & 20 pinion. I have about 3/8 of a inch between the top of the spur & bottom of the hood. Sent from my iPad using Tapatalk |
04-14-2015, 06:26 PM | #49 |
Good to know, i would suggest trying the 20 tooth pinion first and see how the low end torque is. If you lose some torque, go up with the spur.
04-14-2015, 08:11 PM | #50 |
Thanks for the advise John! Here is tonight's update, I tore her down removed the engine compartment tray & battery tray. I also made a bracket for a fuel can. My jeep was missing the fuel can & shovel. So I was able to find some inexpensive replacements on eBay. The shovel is perfect and fits the grove perfectly, the gas can is great until I realized that it was stolen from the Nazi's! Sent from my iPhone using Tapatalk |
04-14-2015, 09:06 PM | #51 |
WOW, your rig is coming along nicely. I'm super jealous, I wish I had the time. 😨 Keep doing a great job. |
04-15-2015, 05:12 PM | #52 |
What gauge sheet metal did you use to make the tray under the hood?
04-16-2015, 05:09 AM | #53 |
I think it was 22 guage steel, but I will double check. I can make one for you if you would like.
04-16-2015, 01:53 PM | #54 |
Thanks for the offer, but I'm going to do something different. |
04-17-2015, 02:56 PM | #55 |
Well I got the engine compartment all back together, the wiring is also done. I then took her for a spin around the yard, everything is surviving as it should. I started to make a winch bumper but didn't get to far. Sent from my iPhone using Tapatalk |
04-17-2015, 07:40 PM | #56 |
Lookin' good mudbeast, great job, great build!
04-17-2015, 08:27 PM | #57 |
Dayummm, looks saweet. |
04-27-2015, 09:03 PM | #58 |
Any updates |
04-27-2015, 10:43 PM | #59 |
Pebble Pounder Join Date: Nov 2014 Location: in a tree home atop a redwood tree on the corner of yonder and timbuktoo
very cool build! how wide is it? im considering using the same rims on some wraith axles for a large scale scratch build.
04-28-2015, 04:52 AM | #60 |
I will measure the rig tonight when I get home.
Mudbeast's Willies build - Similar Threads | ||||
Wild Willies trailing "brothers in arms" | magic2002 | Videos! | 0 | 01-07-2015 05:31 AM |
Jesse Haines Willies Buggy | damohick | 1.9 Scale Rigs | 17 | 11-29-2014 04:10 PM |
Which Disruptor T-case? Motor choice for Willies, what are you running? | Shinjari | Large Scale Rigs | 6 | 02-26-2014 12:24 PM |
Sidehillers; roid raged willies, pocket poor project. | sidehiller | 1.9 Scale Rigs | 15 | 10-04-2013 07:21 PM |
