07-24-2011, 01:21 PM | #141 | |
Quarry Creeper Join Date: May 2011 Location: USA
07-24-2011, 01:27 PM | #142 | |
Rock Crawler Join Date: Jul 2009 Location: greeley
| Quote: | |
07-24-2011, 01:30 PM | #143 |
07-24-2011, 01:34 PM | #144 |
07-24-2011, 01:42 PM | #145 | |
I see you admit there is 2 different motors. Nice break thru. You still might wanna join Spoo on his cropcircle journey. You oughta include your state on your profile. A new person on here might be from the same area. | |
07-24-2011, 01:45 PM | #146 | |
07-24-2011, 01:45 PM | #147 |
Picture time! What do all these pictures have in common!? (Hint - LOSB1751) Any ideas on what's the same? (Hint - LOSB1751) There is something in common all these motors share, any guess? (Hint - LOSB1751) No guesses? (Hint - LOSB1751) No guesses, alright I'll tell you then, they are all part number LOSB1751. Wanna know what they are all from!? Do yeah? You sure? Oh snap... |
07-24-2011, 02:19 PM | #148 | |
07-24-2011, 02:24 PM | #149 | |
only physical differentence between a 55turn and a 35 turn is the label. but they have diierent part number to. GENIOUS I rpeated this a few times also. I have the memory problem | |
07-24-2011, 02:30 PM | #150 | ||
Guess which motor came from the Trekker, I'll give you a hint, the Trekker uses black pinions! If you guessed the bottom one, you are correct sir! Take a picture of yours and prove me wrong. Do it! DO IT! But you won't, because I'm not wrong... You did swap the same motor for the same motor! You call this me being quite? WOW, you should talk to my ex-wife! Quote:
Yeah, well, Jake did say that the Trekker shared the same motor as the Rock Crawler, and the Rock Crawler uses part number LOSB1751... so yes I do believe the developer! | ||
07-24-2011, 02:33 PM | #151 | ||
Wait, are you arguing with yourself now? My bad for interrupting, carry on, argue away... | ||
07-24-2011, 02:43 PM | #152 | |
07-24-2011, 02:46 PM | #153 | |
07-24-2011, 02:47 PM | #154 | |
PS They are the same motor. | |
07-24-2011, 02:48 PM | #155 |
| Yer saying two motors that look the same are the same. Using your logic here. Seee how stupid it sounds?
07-24-2011, 02:49 PM | #156 | |
PS They are the same motor. PPS The cheaper motor (LOSB0833) came in the Micro T/DT/B, that's it. | |
07-24-2011, 02:53 PM | #157 | |
Ok, again, the two motors that you "claim" you have WOULD look different, but they don't because they are the same. These are the motors you are claiming they are, LOSB0833; Those two motors are from my Micro T and Micro DT. These are the motors that come with the Trekker, LOSB1751; "SEE" the difference!?!?!? A big giant hole cut into both sides of the motor-can on the Trekker motor part number LOSB1751, and two little nick vents on only one side of the motor-can on part number LOSB0833. So, if your motor has a big giant vent hole cut in the side, then it is part number LOSB1751... if it does not, then it is part number LOSB0833. So take a picture of your two motors and prove me wrong! | |
07-24-2011, 02:59 PM | #158 | |
Don't believe you at all. I believe LOSI's explode view. Untill I see a correction to LOSI's exploded view you arguement is lost to me. Even if they are the same worst I did was use My SCT motor when I made it brushless. Original arguement was they were the same motor. Made by me. Now you admit they are different. | |
07-24-2011, 03:02 PM | #159 | |
Why did you turn these motors over to sho the part numbers? You practicin to be a Polatician? | |
07-24-2011, 03:19 PM | #160 | ||
| Then call them! End of story! You also believe you gained more speed and torque... Quote:
No again, you said you gain more speed and torque. That is your first comment, and that is wrong. You did not gain both speed and torque for swapping a Micro SCT motor into you Trekker. That is the original argument you have with me! Don't get it twisted with your conversations with other people... | ||
