07-24-2011, 12:08 PM | #121 | |
Rock Crawler Join Date: Jul 2009 Location: greeley
07-24-2011, 12:11 PM | #122 | |
Quarry Creeper Join Date: May 2011 Location: USA
And yes the battery is different, so is the wheelbase, the chassis, and blah blah blah... are any of those the issue of this topic? Nope! | |
07-24-2011, 12:13 PM | #123 | |
[QUOTE=Evilinside;3200517] Quote: | |
07-24-2011, 12:14 PM | #124 | |
Refer to post; project help... | |
07-24-2011, 12:16 PM | #125 | |
Pictures do show it all. engineers only use things like part numbers and exploded views to confuse us. It apparently works. | |
07-24-2011, 12:17 PM | #126 |
07-24-2011, 12:25 PM | #127 | |
If say IdIOT enough times it makes it right why dont you try a different put down than IDIOT or havent you any imagination. Someone posted that the arm looks the same so you thought you are smart enough to look. Kinda overlooked the fact the enginners might have changed the GAUSS in the motor. and changed the case. | |
07-24-2011, 12:27 PM | #128 | |
| Quote: | |
07-24-2011, 12:30 PM | #129 |
07-24-2011, 12:37 PM | #130 | |
| Quote: typing (refer to post) when its something you typed means nothin at all. You already lied to me alot of times. Look at the exploded views. Repost them here. Promise I'll look. Posting a parts list again and again. Only proves their is listing for 2 motors. Promise not to call you dumb again when you see the view put their by engineers. | |
07-24-2011, 12:42 PM | #131 | |
YOU SAID ITS NOT THE SAME MOTOR? OF COURSE NOT. OF ALL THe Backhanded Backstabbing ways to steal my arguement. I hope a Gator eats your crawler. WHAT A BUTTHEAD | |
07-24-2011, 12:47 PM | #132 | |
You call Losi yet? No? OH, ok. You going to call Losi? No? OH, ok. So, seeing how you won't call Losi and argue with them about their exploded view, you'd rather argue with people that can't do anything about the mistake...? Brilliant. Ok, let's say everyone I spoke with was wrong. Let's say that the exploded parts view is accurate. Let's say your not an idiot. So, because you fail to call Losi and talk to them and hear from them that they made a mistake, that means you fail to correct your ignorance, in which case it is now a dead topic and we can all just thank ourselves that we are not you. So I'll move on. Being that you read that you had a different part number motor in your SCT than what was in your Trekker, you swapped motors and gained both speed and torque. However LOSB0833 is only a less winding version of LOSB1751, so it would be impossible to gain BOTH speed AND torque. You would have to have changed other things, which you were asked if you did and you said no. Moving past you being an idiot for; 1) Not calling Losi to learn first hand 2) Not listening to everyone here that's stated you were incorrect 3) Not taking a picture of both your motors to prove they are different 4) Thinking I'm from Florida when I actually live on the exact opposite side of the country 5) All of your responses But, moving past all that, let's just look at the gain you made in both speed AND torque. So you took out Part number LOSB0833 from your Trekker, as you say, and replaced it with part number LOSB1751. The difference between the two motors being that LOSB1751 has more windings then LOSB0833 and bigger holes for venting... that's it. So LOSB1751 has more torque then LOSB0833, that's it. But somehow you got more speed AND more torque by swapping the motors. What started out as an education lesson for you has no become a lost cause... As Ron White said "you can't fix stupid", this means you will always be broken... sorry dude. | |
07-24-2011, 12:48 PM | #133 |
| THe Trekker also does not have the SCT motor. Thought I'd repost it so you don't tell ppl. your saying what I'm saying again.
07-24-2011, 12:51 PM | #134 | |
Let me try to break it down, I'm not a special-ed instructor so I don't know if I'll be able to convey it to you. Trekker motor = Micro SCT motor Micro T motor <> Trekker motor The two motors you have are identical. The motor you "think" it is, has less windings and therefore less torque but more speed. I think that's probably the 30th or 40th time I've said that. Congrats, you've proven your skills once again... | |
07-24-2011, 12:51 PM | #135 |
07-24-2011, 01:01 PM | #136 | |
Jake helped build it So I'm sure he is right. If others think like you well on this they are wrong to. You won't say where you from. You just say U.S.A. so apperently you are ashamed. thinking you can't increase speed and torque by inceasing watt outputt tells me yo either are still. in Jr. HIGH, have the education of a Fr. High. Or almost non-existant electical knowledge. Earlier you agree with SPOO about them being Exactly the same electridally and there is no difference between the two. Wer you hoping I would notice? I almost bet 10 posts from now when I state my facts again you are gonna say, "thats what I said." | |
07-24-2011, 01:12 PM | #137 |
07-24-2011, 01:17 PM | #138 | |||
| I'm sure he is right, and he says the motor is the same. SO.... Quote:
1+1=? I thought you just said that Jake, the developer, was right... now you're saying he's wrong? Weird. Quote:
Again, what is exactly the same were the two motors you swapped! What was stated was not different was the higher speed! Because you can't get more speed from a higher torque motor without using different gears, and you said you did NOT use different gears. So again, congrats! Last edited by Evilinside; 07-24-2011 at 01:20 PM. | |||
07-24-2011, 01:18 PM | #139 |
07-24-2011, 01:20 PM | #140 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
Not here to get int this again but I think the Me being in FL is the mix up. I think when i looked before EvilInside was from Michigan or somewhere BTW the gators here don't eat crawlers but there have been times where they have eaten small dogs. a few years ago one even tried to take a bite out of an old lady jogging with her dog ... she fought back with a broom handle and no i dont know why she was jogging with a broom handle but thats what the news report said |
