12-29-2016, 11:07 PM | #381 | |
Pebble Pounder Join Date: Oct 2015 Location: Fraggle Rock, CO
| Re: RC4WDs New Micro Crawler Quote:
So 2000Kv micro brushless outrunner, got it. Think this will be the route ill go, rather than the mods others have dealt with | |
12-29-2016, 11:09 PM | #382 |
Newbie Join Date: Dec 2013 Location: 909
Exactly my thoughts. Simple and cheap with the same result. A useable micro crawler that looks great Sent from my HTC6545LVW using Tapatalk |
01-03-2017, 03:34 PM | #383 |
Newbie Join Date: Dec 2016 Location: Mustang, OK
This just in: don't waste your time with the dual N20 motor setup. Absolute garbage, from my experience. It would get one of the 2 motors bound up WAY too often trying to climb over stuff (sometimes both at once), which would of course force you to back up and abandon the obstacle. No torque at all. And yet somehow, it managed to strip the gear reduction boxes on 2 different motors. First was one of the motors it came with (300/600 RPM@6/12V), then I replaced those with 600/1200 RPM@6/12V motors, and it stripped a reduction box out even quicker (less than 15 minutes), and of course, still no torque. Maybe for mild stuff with stock suspension it could almost be doable, but even then, my stock setup was MUCH more usable, just without the low speed control and smoothness of the tiny N20 motors. With all of the additional flex and 3S power I have to take advantage of, they just weren't even close to good enough. I'm going to try the Sumo Crawler motor/transmission, which seems to be a well-received swap, with videos of it actually doing some good crawling. We'll see how that goes! |
01-03-2017, 04:13 PM | #384 |
Pebble Pounder Join Date: Jun 2012 Location: Derby, UK
Interesting to hear - that's at least four people I've heard with a similar experience of the twin motors. If you can use a drill and a hacksaw I'd highly recommend going the 180 route, it's well worth the effort. If you're going the sumo direction I'd recommend the larger motor and metal gears from the HBX/FTX
01-03-2017, 04:30 PM | #385 | |
I'll definitely look into the gears and motor, though. Thanks for the recommendation! I'm hoping that this Sumo setup will have the makings of everything I'm looking for, but if not, I guess it'll be time to get a little more wild with it. | |
01-05-2017, 01:32 AM | #386 |
Rock Stacker Join Date: Apr 2016 Location: U.K.
| Re: RC4WDs New Micro Crawler Hi, the hobbyking 10A ESC to go with the above brushless motor, can it be used with the stock receiver?
01-05-2017, 02:06 AM | #387 |
| Re: RC4WDs New Micro Crawler This is the one I'm running. Small enough to sit right on top of the servo with some mounting tape. https://hobbyking.com/en_us/hobbykin...w-reverse.html Sent from my HTC6545LVW using Tapatalk |
01-05-2017, 07:21 AM | #388 | |
01-05-2017, 08:55 AM | #389 |
You will have to use a standard receiver and transmitter Sent from my HTC6545LVW using Tapatalk |
01-13-2017, 11:50 PM | #390 |
| Re: RC4WDs New Micro Crawler Quote: Sent from my VS987 using Tapatalk |
01-14-2017, 09:38 AM | #391 |
Newbie Join Date: Jan 2017 Location: SF
Very helpful thread guys! Looking into getting a G2 and modding it. I was wondering about your using the micro outrunner, what was the solution for the pinion? And what about using a bigger ESC to handle 3S? Will it fit? I already have two LiFe 3S batteries (a max amp 3S/950 mAh and a intellect volt 3S /1450 mAh.) Any thoughts? Thanks! |
01-14-2017, 05:06 PM | #392 | |
For your esc question. I am currently using a HobbyWing 1060(brushed) suggested by another member. It is installed and so far I like it. Has a drag brake but thats about it. Also waterproof and has a switch on a 3" or so lead. the switch I have Velcro'd to the rear bumper for easy access. I made a plexiglass structure to extend the switch higher into the body than the bumper and simpler mounted that between the bumper and frame using the bumpers hardware, if you were interested. I believe for brushless, correct me otherwise; some are using the Tekin B1r or the Sidewinder2 micro. Also, there was talk about the HobbyKing 10a esc Last edited by SurfinStud; 01-14-2017 at 05:09 PM. | |
01-14-2017, 10:55 PM | #393 |
Nice setup! Thanks for sharing the mod info. What are you using for the brushed motor? I was thinking of thr micro brushless to increase the torque. It seems though that a bigger ESC like the 1060 fits well, suggesting that a bigger brushless would fit as well ... |
01-15-2017, 12:04 AM | #394 | |
I am using a motor from a savox servo. The original crapped out within afew hours of running. TGreer has a Bronco build on this chassis and he is using a similar, Servo motor for replacement; it is where I got the idea. Good luck on your endeavor. Keep us posted what you find works and does not. | |
01-15-2017, 12:34 AM | #395 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
The Tekin B1R is brushed only. The Castle Micro ESCs are both brushed and brushless. The XYS-BL20A is very cheap, tiny and brushed only. FWIW xys also has a 10amp ESC that's a little smaller,a little cheaper, and more than enough for the micro Crawlers. Sent from my Nexus 6P using Tapatalk |
01-15-2017, 12:42 AM | #396 | |
Good information! Thanks for speaking up | |
01-16-2017, 09:25 AM | #397 |
Hey guys, Pinion question: when you replace the motor with either a servo motor or a micro outrunner, do you use the stock pinion? Can it be removed and installed on the new motor shaft? Thanks! |
01-16-2017, 10:04 AM | #398 |
And one more thing: are people here selling their gigs? I used to hang out at rc tech.net and there was a section for selling, but I cannot find it here. Anyway, if someone is bored of their G2, let me know, it can go to a nice home (mine) and keep company to a heavily modded mini inferno and a G6 scx10. Thanks! |
01-16-2017, 10:13 AM | #399 | |
Quarry Creeper Join Date: Jan 2015 Location: Alcoa
Classifieds?? edit. ah- here's the rules: Classifieds You cannot see the entire classifieds section until you meet these qualifications: Be a member of the site for at least 30 days. and Have a minimum of 30 posts. or Purchase a star to support the site. See below. If you try to get your 30 posts in one day with saying "cool truck" in 30 different threads we will notice it, delete your posts, and give you an infraction. Do not put for sale or want ads in your signature. Do not put for sale or want ads in the tech sections. There are stickies describing the rules of for sale and wanted posts, read them or your ad will be deleted. Chit chatting in the Feedback section will result in a permanent removal form the classifieds. | |
01-16-2017, 02:52 PM | #400 | |
The adjustable bolt on the tranny is mounted to the motor; as long as the pinion and gear mate well, there should be no issues. Take this for what its worth, I am no expert to this hobby. | |
RC4WDs New Micro Crawler - Similar Threads | ||||
BWD Micro Wheel Weight System for the new Losi Micro Crawler! | billet works | Vendors Market | 19 | 10-18-2010 05:42 PM |
~Petition for RC4WDs next 1.9, 3.7" tall tire~ | STANG KILLA SS | Tires and Wheels | 105 | 02-03-2008 02:17 AM |
RC4WDs Aluminum 2.2 Hilux wheels | SuperSancho | Tires and Wheels | 5 | 04-29-2006 12:42 PM |
