05-15-2016, 12:15 PM | #341 |
Quarry Creeper Join Date: Jan 2015 Location: Alcoa
| Re: RC4WDs New Micro Crawler |
05-17-2016, 07:16 PM | #342 | |
| Re: RC4WDs New Micro Crawler Quote: | |
05-18-2016, 04:22 AM | #343 |
Rock Stacker Join Date: Apr 2016 Location: U.K.
Anyone has the stock pinion out of the car? Is it possible to check the overall diameter of the pinion? Thanks...
05-20-2016, 03:36 PM | #344 |
Swapped stock links to redcat sumo balls and rod ends. The balls have m2 threads so they screw right into the axle brackets. They are a hair short going through the chassis plates- they don't make it to the nylon locking part of the nut, so I used loctite. If one comes loose, I'll grind the chassis a hair by the holes. Just as much as my Specter: Behind axle steering link. 2mm threaded rod with rod ends mounted above rear knuckle mount. The short link was replaced as well with rod ends that move more. The shocks are losi mini desert truck front shocks with the spring perch removed. 10wt oil and about 10mm of a trekker/micro t spring inside. They are relatively inexpensive at $10/pr. |
05-22-2016, 05:00 AM | #345 |
Newbie Join Date: Mar 2016 Location: Rockville
Why did you go with the trekker t spring vs the stock spring? Isn't the stock spring about 10mm? You cut the trekker spring, is that correct?
05-22-2016, 08:31 AM | #346 | |
I'll make a thread for this thing, I've got some pics I need to add that would be helpful if anyone wants to try this, and I don't want to clog up this thread too much. Last edited by TownsendTdi; 05-22-2016 at 08:42 AM. | |
05-24-2016, 05:31 AM | #347 |
05-24-2016, 08:48 AM | #348 |
05-24-2016, 03:40 PM | #349 |
Pebble Pounder Join Date: Jun 2012 Location: Derby, UK
Nice work! What advantage is there in moving the steering link? I don't have that option any more as my knuckles are shaved.
05-24-2016, 06:41 PM | #350 |
05-29-2016, 09:36 AM | #351 |
05-29-2016, 01:27 PM | #352 |
| Re: RC4WDs New Micro Crawler Looking very good!! Colour is striking... Do the tires catch the body?
06-13-2016, 02:20 PM | #353 |
Newbie Join Date: Mar 2012 Location: derbyshire, england
| Re: RC4WDs New Micro Crawler Quote: Would you make me one? Obviously I would pay. Not too far away from you either (Chesterfield) Thanks for your time |
06-13-2016, 04:25 PM | #354 |
Hi Gaz Not too far away at all I'm not sure I can pull it off a second time mate. I bought all the bits to make a slightly improved version so I can try a few different pinions, but kinda lost momentum with it. Cutting and drilling the plates accurately is a ballache. Also, until I strip this one down again I'm not sure I have the right pitch pinion for the transfer case - I used the one out of the stock motor originally and I only have one of those ;) It is definitely a coarser pitch than the 0.3 mod losi gears - I've bought a 0.4 mod 10T which I think is about the right dia but haven't tested it yet. If I get it built I might be willing to part with this one though - and you're first in the queue |
06-17-2016, 06:16 PM | #355 |
No worries mate, Along with that I have a little update, as already known the stock motor is pants! So reading this thread and winging it I set about modding mine. I've managed to squeeze in a 180 sized motor now but I think it's a duffer. Also ruined the original pinion so.... What's a good torquey 180 motor and any ideas where I can get some pinion from? Thanks, gaz. |
06-17-2016, 08:12 PM | #356 |
These are about the best you can get: Xtreme ESL506 180 PRO Motor (B) Gen 3 BLADE CX2 / CX3 / Esky Lama / Hunter / KOB | eBay Pinions from here: kkpmo - M0.4 Zahnräder für Modellbauer bis 26mm aus Messing und Pom I think it is a 0.4m 10T but not certain. Good luck - any pics of where you got to? |
06-28-2016, 05:15 PM | #357 |
Not got any further yet, decorating and being moved to a cupboard to work on the rc doesn't help... I'll get something thrown together before long though and put some pictures up. |
07-09-2016, 07:19 AM | #358 |
Pebble Pounder Join Date: Oct 2006 Location: Leaving black marks on Hwy 200
Well its too bad this thing needs 20 hours of labor and hundreds in parts to be usable. They clearly subbed it out to China without making sure it was a good product before selling. I've been waiting a long time for a decent micro scale rig and it looks I'll be waiting longer. I've had a Trail Trekker for years that I don't do anything with because of how pathetic it is. don't have the time or need to put excessive amounts of money and labor into a micro toy.
07-09-2016, 09:17 PM | #359 | |
Rock Crawler Join Date: Mar 2009 Location: Parker, CO
Why are you on this thread? Why are you even involved in this hobby? Do you even know what a screwdriver is? Perhaps stamp collecting would be more to your liking. | |
07-10-2016, 10:04 AM | #360 | |
RC4WDs New Micro Crawler - Similar Threads | ||||
BWD Micro Wheel Weight System for the new Losi Micro Crawler! | billet works | Vendors Market | 19 | 10-18-2010 05:42 PM |
~Petition for RC4WDs next 1.9, 3.7" tall tire~ | STANG KILLA SS | Tires and Wheels | 105 | 02-03-2008 02:17 AM |
RC4WDs Aluminum 2.2 Hilux wheels | SuperSancho | Tires and Wheels | 5 | 04-29-2006 12:42 PM |
