01-25-2017, 12:26 PM | #421 |
RCC Addict Join Date: Jan 2011 Location: Forest Floor
| Re: RC4WDs New Micro Crawler
Use 2mm instead of 2-56, they screw on easier. Hobbyking has stainless steel rods with threads on the ends and are cheap. Much nicer than all-thread. Last edited by Fungi; 01-25-2017 at 12:26 PM. Reason: typo |
01-25-2017, 12:32 PM | #422 |
You're welcome surfinstud! Has anyone taken pictures of the process of improving the steering throw? I have a new axle set and they're pretty rough. So bad I tossed them aside and forgot about them. I read this from the beginning and saw a post about modifying a servo for the motor and gear, but the pics don't show up. Anyone have copies they can post? |
01-25-2017, 12:44 PM | #423 | |
Newbie Join Date: Dec 2013 Location: 909
| Re: RC4WDs New Micro Crawler Quote:
Sent from my HTC6545LVW using Tapatalk | |
01-25-2017, 03:44 PM | #424 |
| Re: RC4WDs New Micro Crawler Wiha drivers are very nice. https://www.wihatools.com/screwdrivers/nut-drivers Fungi, great find on the 2mm threaded rods, thanks! |
01-25-2017, 10:44 PM | #425 | |
Pebble Pounder Join Date: Oct 2015 Location: Fraggle Rock, CO
I got a new stock motor to run through the 1060esc. So underpowered, but total throttle control and mild drag brake is nice! Cant do inclines, but anything realistic in his path, he climbs right over. (Firewood, rocks, grass etc.) If this motor lasts more than 5 hours, Thatd be great; after it fries ill go back to the servo motor. Way torquier. Ill bet, down the road, ill go brushless esc and then the micro outrunner like you have. I am following that setup closely, would like to see it last a long time!! Sent from my VS987 using Tapatalk Last edited by SurfinStud; 01-25-2017 at 10:46 PM. | |
01-25-2017, 10:53 PM | #426 |
Not much time as I've been busy as of late. Maybe an hour total time on it. The joys of brushes are the lack of wearable parts other than bearings. I've been running an outrunner on my trailfinder for almost a year through mud, water, and sand and it's still just as strong as the day I installed it. Sent from my HTC6545LVW using Tapatalk |
01-26-2017, 03:53 PM | #427 | |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
01-26-2017, 03:55 PM | #428 | |
Bronco Beast........no, this is no Ambush! | |
01-26-2017, 11:19 PM | #429 | |
Rock Stacker Join Date: Apr 2016 Location: U.K.
01-27-2017, 07:56 AM | #430 | |
01-27-2017, 10:28 AM | #431 |
Pebble Pounder Join Date: Jun 2012 Location: Derby, UK
Wow that's an amazing improvement. Looks like I need to shave a bit more off my knuckles. Can you show a pic of the dogbone, I'm not sure I've grasped that bit. Also have you run it like this or is it untested?
01-27-2017, 10:49 AM | #432 | |
And yes, I've put several lipos through it like this, so I know it works and is still plenty strong enough. I also moved the lower links (just in front) to the inside of the axle mounts so they would clear the huge Scrambler tires. | |
01-27-2017, 11:43 AM | #433 |
Cool cheers that's good to know. I see what you mean re the dogbones - I thought you were talking about the bones not the cups hence my confusion |
01-28-2017, 01:57 PM | #434 |
| Re: RC4WDs New Micro Crawler Amazing! Did you do anything to the dog bone and bit where the dog bone slotted into? I shaved mine but couldn't get as much angle as your photo. Looks like it's limited by the dog bone and the slotted bit maximum alloweable angle not the knuckles ...
01-28-2017, 08:55 PM | #435 |
| Re: RC4WDs New Micro Crawler Yes, I put a cone shaped bit in my Dremel and opened up the cups a bit.
01-28-2017, 09:03 PM | #436 |
| Re: RC4WDs New Micro Crawler |
01-28-2017, 09:15 PM | #437 |
I had a go at mine today. I'd already shaved my knuckles without much improvement, but combined with opening up the cups my truck now has a turning circle of approx 3ft, and I've been a bit more cautious than papabash. Full credit for trailblazing this The steering angle was a major issue that I thought could only be solved by a CVD / steering knuckle upgrade from rc4wd. Fingers crossed I haven't removed too much material, I guess time will tell! |
01-29-2017, 12:34 AM | #438 |
01-29-2017, 05:21 AM | #439 |
| Re: RC4WDs New Micro Crawler I really don't know how far I went. If you hold the cup upright, you will see that there is a flat area around the rim. I removed enough material to make that edge almost sharp, if that makes sense.
01-29-2017, 06:30 AM | #440 |
| Re: RC4WDs New Micro Crawler Emm... anyone? Bit confused now. I originally thought to widen the throw I deepen the two slots?
RC4WDs New Micro Crawler - Similar Threads | ||||
BWD Micro Wheel Weight System for the new Losi Micro Crawler! | billet works | Vendors Market | 19 | 10-18-2010 05:42 PM |
~Petition for RC4WDs next 1.9, 3.7" tall tire~ | STANG KILLA SS | Tires and Wheels | 105 | 02-03-2008 02:17 AM |
RC4WDs Aluminum 2.2 Hilux wheels | SuperSancho | Tires and Wheels | 5 | 04-29-2006 12:42 PM |
