Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Bigworm’s SCX24 Build
Old 12-03-2019, 09:40 AM   #81
Default Re: Bigworm’s SCX24 Build
Question... Where did you source the balls to mount the shocks?
GChambers is offline   Reply With Quote
Old 12-03-2019, 02:49 PM   #82
I beleive I am using the ones that came with the carisma oily shocks. I have so many micro shock sets. That they might be from HR micro shocks or the carisma oil shocks now that I think about it. Heck they might be from some losi micro shocks. But I think am using the ones the carisma shocks came with. I think...
Mine are more of a barrel design. They are like coke can with a hole at top and bottom for pass through. These are not screw in balls ends.
BIGW0RM is offline   Reply With Quote
Old 12-05-2019, 02:19 PM   #83
I bought a set. They didn't come with ball ends. That's the reason I ask.
Old 12-06-2019, 07:44 AM   #84
Well, I would be lying if I said I didn’t pretty much just copy your whole build other than the 4WS... I have way to many parts coming in the mail.... nowwwww I get to sit and wait and keep checking the tracking numbers lol. Very nice build I’m hoping to see the same flex!! Quick questions I have the RGT shock mounts coming along with the carisma shocks, did the front shock towers bolt right up?? Seems to easy and unlikely that the holes would line up. Any hardware I need to be searching for to mount the shocks front or rear? Thanks for this thread!! Can’t wait to see what I get to copy next hahaha. At least I adjust it right? That’s got to make it at least some better.
shhuskins is offline   Reply With Quote
Old 12-07-2019, 06:17 PM   #85
The rgt front shock mounts fit, but I had to squeeze them some to fit.
Old 12-07-2019, 06:47 PM   #86
Sweeeeet!!!!! Thanks man!
Old 01-22-2020, 07:32 AM   #87
Great build man!
Do you recommend the SKU: LOSB1722 shocks over the stock ones? No extra parts needed to get these to fit?
waqr is offline   Reply With Quote
Old 01-22-2020, 01:59 PM   #88
Originally Posted by waqr View Post
Great build man!
Sorry, just saw this. Um, I think they plugged right in. I only used them in the back and I had different springs on mine that I had laying around. I also had them mounted to the FRAME. Not the stock location in the rear.
I have since changed this again to Carisma Oil shocks. Those are by far the best yet. BUT they have a much bigger eye hole so I used other hardware to mount mine. What I used, I dont know. Mostly just left over 1/24th ball ends stuff I had laying around.
But the losi shocks in rear mounted how I had mine are a cheap way to get HUGE articulation even with the front STOCK shocks still being used like normal.
So if you want a quick and easy mod, the Losi shocks in rear worked for me. But going to the Carisma oil shocks is hands down the best shock setup Ive found for the SCX24. But I also have so many 1/24th parts that I Frankenstein'd mine.
Here is the losi shocks in rear and where I mounted them with different springs I had. The o ring was used for height adjustments. I would slide it up or down for whatever height I wanted. This is REARs only. Stock front end.
And here is the carisma oil shocks I have now...
And its final look with all 4 carisma shocks. In this final build, I used RGT 1/24 shock towers and now my front carisma oil shocks sit correctly. If I used carisma or losi shocks up front in stock locations, the ride height is WAY to high. This is why I moved the rear shock mount to the frame. It lowered the body and offered 4x more articulation.
Old 01-23-2020, 12:14 PM   #89
Many thanks for the reply
Skickat frĺn min iPhone med Tapatalk
Old 01-23-2020, 12:19 PM   #90
Anytime!
Old 01-24-2020, 09:33 AM   #91
Default Bigworm’s SCX24 Build
Tried to mount the Losi shocks but my frame is not the same as yours. If I mount them like you have they have not the same angle and the truck sits really high
Old 01-27-2020, 10:13 PM   #92
Sorry for the late reply.
You mounted them incorrectly bud. You need to mount them to the battery tray leg. The small one closest to rear end.
EDIT:
My bad, after a second look, it sure does look like you mounted them correctly. Sorry!
You will have to cut coils, try springs from clicker pens, and get inventive,
I think I cut mine or used others and used an o ring around the shock shaft as a perch to adjust my height. I think there are some photos of mine in this thread you can get ideas from.
Good luck!
Old 01-30-2020, 01:25 AM   #93
Thanks for the reply. Drilled new mounting holes in the chassie for the rear shocks. World great!
I just would like to find stiffer springs. Easier said then done.....
Tried some springs from penciles but they were all to small.
Old 01-31-2020, 12:13 AM   #94
Hi, I just got my Scx24 today and wanted to install some of the o rings I have sitting around into my steering like you did. But I was wondering how you took the front steering apart. I tried just to get the ball to pop out with it all mounted but that felt like I might break something. So should I go and unscrew the ball ends from the knuckles and and then try and pop the ball out with it detached? Is there a trick to popping the ball joints out easily?
BenTheFox150 is offline   Reply With Quote
Old 01-31-2020, 12:57 AM   #95
I took the ball ends out, because I had same issue.
Scx24 crc. Crawler 1/24
Wltoys a212. Shortcourse 1/24
Wltoys k969. Drifty 1/28
Mr_Wolf_Is_Innocent is offline   Reply With Quote
Old 01-31-2020, 10:09 AM   #96
I also took all ball ends out and added a couple rubber o rings to the linkage.
Dont forget to do the servo drag link to the steering linkage that holds both wheels. That has a lot of slop too.
Old 04-20-2020, 06:32 PM   #97
Where did you find 66mm Rc4wd tires? All the ones I find are 49mm
PFongemie is offline   Reply With Quote
Old 04-21-2020, 10:01 PM   #98
Sorry they are 61mm.
I got mine here.
https://store.rc4wd.com/Scrambler-Of...es_p_5142.html
Old 04-30-2020, 04:49 PM   #99
Originally Posted by pfongemie View Post
did you cut the tire foam or stuff all of it in?
This is the one i ordered
sent from my iphone using tapatalk
all in baby! Fat and juicy sidewalls!
Old 05-01-2020, 09:30 AM   #100
Nice my RC4WD wheels came in yesterday and tires and foams are due in today. Can’t wait to get them installed and see the difference
What tires did you get? Reason I ask, I put the whole foams in RC4WD scramblers. Which are very tall and wide. You might have to cut the foams for smaller ones. But I dont know.
Congrats on a fun Friday project!
Bigworm’s SCX24 Build - Similar Threads
Scx24 truggy build... lilws6 Micro Scale Rigs 21 08-13-2019 12:28 PM
