08-25-2016, 08:49 PM | #41 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: Two
A rider? No dolls in comp rigs... lol.
08-26-2016, 05:47 PM | #42 |
| Re: Two |
08-27-2016, 11:14 AM | #43 |
| Two
Axles clocked no binds, steering so much better, did need a spacer to clear rod end. Bec and HH BR mini installed, Promodeler 420 servo in running at 7.4v. End points set, I'm out to the rocks! |
08-27-2016, 11:20 AM | #44 |
| Re: Two
Looks good... can't you fit ESC & BEC on skidplate? Mounted on top your asking for problems.. Steering looks much better.. |
08-27-2016, 12:42 PM | #45 |
| Two
They are, that picture shows how I wired the BR mini and the bec. The bec has been shrink wrapped and folded over , air space created by 3M mount, fits under the hood. Steering is totally better, with the links like that and the servo pulling 420oz, it is so precise and crisp! Last edited by mikemcE; 08-27-2016 at 12:46 PM. |
08-27-2016, 02:11 PM | #46 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Two What he means is mounted esc/bec down on skid, right behind the front motor. You want everything low as possible. Also my front stock shocks were binding, I added some spacers at the top to make them cycle smoother. You should check yours too.
08-27-2016, 02:54 PM | #47 |
| Re: Two
Oh...... I was worried about rocks there. I have my rx down there now, need to rethink. Shocks were a mess along with my links binding, lot of time to get all smooth ! |
08-28-2016, 07:53 AM | #48 |
| Re: Two
Well some quality time spent, electronics down low now. |
09-04-2016, 01:50 PM | #49 |
| Two
Now I'm hooked!! Spent a couple of hours and went thru a bunch of packs and this baby is sweet . The driver is also slowly getting there I've got the dig down now. If I could see the right line , but I know that is only time and more practice! HANG UP AND DRIVE ! Last edited by mikemcE; 09-04-2016 at 01:52 PM. |
09-04-2016, 02:24 PM | #50 |
| Re: Two
How much run time you pulling with the 850s?
09-04-2016, 03:40 PM | #51 |
| Re: Two forgot to look I would guess about 20 - 25 minutes each I ran two trucks today , was gone for 3 hours, my 1300 packs give me 30 each, thats one hour took a 15 minute coke and AC break, 3 packs in 1 1/2 hr... so 25min or so till LVC |
09-04-2016, 03:57 PM | #52 |
| Re: Two
For sure, 20-25min is what I get too. My buddy with an xr10 and 800mah gets about an hour. My only guess is because he's runnin 55t motors.
09-05-2016, 10:16 AM | #53 |
Pebble Pounder Join Date: Feb 2013 Location: Mount Olive, AL
| Re: Two
I run the 500mah brood packs and I get 15-20 minutes each run, I'm running dual sidewinder micros and bec at 8v and they do great! Love the bully setup, mines been great also. I put the traxxas big bores with mini t springs and knuckle weights and just those two things made a huge difference
09-05-2016, 12:17 PM | #54 | |
| Re: Two Quote:
I have a set of the big bores, no springs or caps yet.... | |
09-05-2016, 02:50 PM | #55 |
| Re: Two
Get those big bores on there, it will help a ton. Will make it a lot more stable and predictable. Which big bores do you have? Also get some knuckle weights. Rc4wd, rcbros or krazed builds tungsten holders with tungsten slugs. |
09-05-2016, 02:57 PM | #56 | |
| Re: Two Quote:
hang up and drive ! | |
09-05-2016, 07:35 PM | #57 |
| Re: Two
Look in the bully picture thread, I posted two pictures of mine. You want those big bores.
09-06-2016, 01:18 PM | #58 |
Pebble Pounder Join Date: May 2016 Location: Warwick
| Re: Two |
09-06-2016, 03:07 PM | #59 |
| Re: Two |
09-06-2016, 03:18 PM | #60 |
| Re: Two I don't have the ones you show I will have the 2661's which are 3.75". They also have the 2660 which are 3.5" or 2662 which are 4"(believe those are the measurements). DLUX also has them on his website with lengths. Sent from my HTC One_M8 using Tapatalk |
