09-06-2016, 03:48 PM | #61 |
| Re: Two
Those are the fronts, I have those also. Thanks ! HANG UP AND DRIVE ! |
09-09-2016, 07:18 AM | #62 |
| Re: Two
Did a bit of measuring, my fronts are 4" rear 3.5" That is what I have as big bores, ordered caps and springs from Eric HANG UP AND DRIVE ! |
09-09-2016, 08:38 AM | #63 |
| Re: Two
Question, which way to mount and why ? Springs at top or bottom ? HANG UP AND DRIVE ! |
09-09-2016, 09:44 AM | #64 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: Two
If you can mount springs up.. to keep weight as low as possible... try shocks both ways and see what you like best.
09-12-2016, 06:17 PM | #65 |
| Two
I'm lost and pissed for tonight . Shocks built, fought traxxas ends, put on and I just don't know if the tops are correct.... Little side to side, seem OK. Bottom on servo side is #%*!!*# yeah, bangs into servo... Any ideas, not sure of longer ends for these shocks, or angled ?? Stock were angled, much larger diameter HANG UP AND DRIVE ! |
09-12-2016, 06:58 PM | #66 |
Rock Crawler Join Date: Jul 2011 Location: palm desert (southern cali)
| Two
Gonna have to run them outside the mount like I did on mine Sent from my iPhone using Tapatalk |
09-12-2016, 07:46 PM | #67 |
| Re: Two
I will have to make some tube extensions for the top. I don't think there are any longer or angled 3mm links HANG UP AND DRIVE ! |
09-12-2016, 09:22 PM | #68 |
RCC Addict Join Date: May 2012 Location: Folsom
| Re: Two
Run a cap mod on those guys. You can get some of the tiny 3mm rod ends from traxxas.
09-12-2016, 09:53 PM | #69 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Two
Tra2742x. Edit: and yes with the dlux stand offs, there is side to side play. You can get some small orings and put 1 on each side to help the play. Also the front not clearing the servo, that's why it comes with bent rod ends on the bottom. Or mount on the outside of the mounts. Last edited by 84yoda; 09-12-2016 at 09:58 PM. |
09-13-2016, 06:53 AM | #70 |
| Re: Two |
09-13-2016, 06:54 AM | #71 | |
| Re: Two Quote:
O ring is a great solution, I saw the bent ones, just not available in 3mm HANG UP AND DRIVE ! | |
09-13-2016, 11:11 AM | #72 |
| Re: Two
Yes there is, the ones on the stock shocks are 3mm. And rc4wd sells 3mm bent rod ends. Dlux also has bent 3mm rod ends. His are a little smaller then the ones that come on the bully front shocks.
09-13-2016, 02:40 PM | #73 |
Pebble Pounder Join Date: May 2016 Location: Warwick
| Re: Two
This is with the cap mod and bent ends from the stock shocks. You can even try the bent end on the piston shaft if you want to keep them right side up, might work and might not have to do the cap mod. Sent from my HTC One_M8 using Tapatalk |
09-13-2016, 02:55 PM | #74 |
| Re: Two
Piston shaft is 3mm is your cap mod 4mm ? I'm leaning that way HANG UP AND DRIVE ! |
09-13-2016, 03:10 PM | #75 |
| Re: Two
His is 3mm, since he's using bent rod ends. I used 3mm as well for my cap mod.
09-13-2016, 03:37 PM | #76 |
| Re: Two
Ya I'm gonna use these modded icons see how they do if not I have most to switch to big bores Sent from my iPhone using Tapatalk |
09-13-2016, 03:50 PM | #77 | |
| Re: Two Quote:
Sent from my HTC One_M8 using Tapatalk | |
09-13-2016, 03:55 PM | #78 | |
| Re: Two Quote:
I'm going to the bench with my Dremel! Thanks! | |
09-13-2016, 06:33 PM | #79 |
| Re: Two
Just finished the cap mod, letting dry tonight. Looks perfect, I am going to add some preload out back....just a bit soft, verrry close!
09-14-2016, 02:56 PM | #80 |
| Re: Two
Tune time !! HANG UP AND DRIVE ! |
