10-15-2015, 06:15 PM | #41 | |||
| Re: RC4WD 1/10 Trail Finder 2 Kit w/Mojave II Hard Body ( PROBLEMS ) Quote:
Yes, hope the grill spreads the fenders out a bit. | |||
10-15-2015, 06:15 PM | #42 |
Rock Crawler Join Date: Sep 2012 Location: aloha state
Ohhh good idea ill try that hope thatll fixed that
10-15-2015, 06:25 PM | #43 |
| Re: RC4WD 1/10 Trail Finder 2 Kit w/Mojave II Hard Body ( PROBLEMS ) |
10-15-2015, 06:33 PM | #44 |
Rock Crawler Join Date: Jul 2005 Location: Spartanburg
You have the leaves themselves assembled incorrectly. The smaller leaves go under the main spring leaf. Try reassembling them, it should move the axle around. RC4WD Team Driver*Krawl Off-Road |
10-15-2015, 06:35 PM | #45 |
10-15-2015, 06:42 PM | #46 |
Lolz ok so no leafs aboved the main leafs spring? Its all on the bottom? I think ill just use 2 only leafs are to stiff The main leaf spring and the short one |
10-15-2015, 06:42 PM | #47 |
Yes, all leaves go below the main spring. RC4WD Team Driver*Krawl Off-Road |
10-15-2015, 06:47 PM | #48 |
Wahahahahha thanx a lot Darnit lol Gotta take it apart again |
10-15-2015, 07:49 PM | #49 |
| Re: RC4WD 1/10 Trail Finder 2 Kit w/Mojave II Hard Body ( PROBLEMS ) Perfect Thank you sir edge for the help I think the pitbull will rub on the front corner of the fender? Ill shaved those at a later time Next work on the body I was looking it at the body Just need a little pushed out not so much I tried bending it with my hand and it bends Without any problems Just need styrene I will try to connect the grill tomorrow and see if itll pushed out the fenders out |
10-15-2015, 07:56 PM | #50 |
Great to see it squared it up!
10-15-2015, 10:38 PM | #51 |
Yup Just need to listen sometimes But frustration get the best of me at times |
10-17-2015, 03:57 PM | #52 |
10-17-2015, 07:00 PM | #53 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
You can mount the battery plate in the forward position (the holes are pre-drilled in the chassis) so that it clears the full cab back. The only thing you'll need to do is make a custom link from the shift servo to the shifter. I have pix in my thread showing how I did mine. Or you can trim the cab back, but that kinda defeats the purpose IMO....
10-17-2015, 07:57 PM | #54 |
Anyone else have issues with the front diff carrier bearings being very loose in the housing? Mines so bad I don't dare run it. I can wiggle the carrier up/down about 1.5 mm. I think the housing is out of spec, we'll see what RC4wd says when I call them. I was planning on shimming it, but no amount if shims will remove the radial slop. The rear was "fine" in regards to housing spec, but still required much shimming to be within my tolerances. |
10-17-2015, 09:19 PM | #55 | |
10-17-2015, 09:23 PM | #56 | |
All i had to do took apart and put it back different way untill theres no play and put it back I still have a little play On it so i plan on getting k44 axles later time | |
10-18-2015, 01:39 AM | #57 |
10-18-2015, 09:45 AM | #58 |
Yes, as new2rocks has stated, move the tray to the forward mount. As for the skid...it is one of the single most effective mods that you can do to increase the performance of these trucks!
10-18-2015, 03:34 PM | #59 |
Quarry Creeper Join Date: Mar 2009 Location: western ny
Idk the more and more I'm reading the more I'm thinking bout whether I really want this truck . I used to hear nothing but good stuff about the tf2 and now all of a sudden since they made these changes all hell is breaking loose . Maybe they shoulda left well enough alone . I'm hoping that by the time the rtr comes out this will be all sorted out but I've started looking at other choices . What do you all think ? I've had an Axial and thought it performed well but always felt like I was giving up on the TRUE scale aspect . Is the TF2 worth the minor snafus for that REAL TRUE scale aspect ?
10-18-2015, 07:18 PM | #60 |
Rock Crawler Join Date: Aug 2011 Location: SB
Its a pretty strait forward build. Build par manual, if adding some upgrades you might have to get alittle creative. If you have a big problem I'm sure rc4wd will take care of you. No need to hesitate buddy, grab one and build her up. |
RC4WD 1/10 Trail Finder 2 Kit w/Mojave II Hard Body ( PROBLEMS ) - Similar Threads | ||||
RC4WD Mojave Body Set For Trail Finder 2 (Camo style) | rustneversleeps | RC4WD Trail Finder 2 | 5 | 09-04-2015 03:58 PM |
RC4WD Complete Mojave Body Set for Trail Finder 2 in both Yellow and White. | Rckcrwlr | General Scale Talk | 9 | 06-10-2012 09:08 PM |
