10-20-2015, 09:49 PM | #81 |
Rock Crawler Join Date: Sep 2012 Location: aloha state
| Re: RC4WD 1/10 Trail Finder 2 Kit w/Mojave II Hard Body ( PROBLEMS ) They were talking about the tail lights They said its upside down I double triple quadraple check and its not even upside down See? Its on correctly Heres the part i need help in for sure I bolted the grill i wanted to see how it fits and i see that problems So how do fixed this? Those head lights sticks out a little i probably can shave some of it Im more worried about the sides |
10-21-2015, 08:22 AM | #82 |
Quarry Creeper Join Date: Nov 2013 Location: alberta
If you look at your tail light carefully you will see the moulded in reflector detail that should be at the bottom yours is at the top
10-21-2015, 09:43 AM | #83 |
| Re: RC4WD 1/10 Trail Finder 2 Kit w/Mojave II Hard Body ( PROBLEMS ) |
10-21-2015, 12:05 PM | #84 |
Pebble Pounder Join Date: Sep 2013 Location: Michigan
Do you have a side profile picture of the front grill?
10-21-2015, 01:00 PM | #85 |
Uh no not right now i can take a picture of it later today I dont know what to do with this part Ill probably can just glue this part and putty? |
10-22-2015, 08:17 AM | #86 |
I have been somewhat following this thread and just wanted to throw out there that the tail light "issue" is not an issue of this body or of rc4wd it's an "issue" since the original bruisers... I have been building bruisers for the past 15 years or so and the tail lights have always hung over. Here are some of my Toyotas, with Tamiya beds to show Even if you fill the seem properly, such as my good buddy mr.n00b did on. They still poke over a little bit |
10-22-2015, 12:27 PM | #87 |
Later on today im going to try and fixed those corners I dont have anything to soften that body Like a hair dryer Im going to burned it with my lighter lol From the inside ofcourse and see if i can bend those in place This body will be used as a practice basher body i guess Ill just get a new body for it later |
10-22-2015, 01:49 PM | #88 |
10-22-2015, 06:47 PM | #89 | |
Quarry Creeper Join Date: Mar 2009 Location: western ny
| Re: RC4WD 1/10 Trail Finder 2 Kit w/Mojave II Hard Body ( PROBLEMS ) Quote:
10-22-2015, 07:14 PM | #90 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
A hair dryer and some patience should work. Adding some styrene and doing some sanding should also work. 2003 Edge and I are looking into a couple of options and will post what we come up with. I probably won't be able to get back to it until next week, though.
10-22-2015, 07:46 PM | #91 |
10-22-2015, 07:52 PM | #92 |
10-22-2015, 07:53 PM | #93 | |
| Re: RC4WD 1/10 Trail Finder 2 Kit w/Mojave II Hard Body ( PROBLEMS ) Quote: Looks pretty damn good from here too bud | |
10-22-2015, 08:07 PM | #94 |
Thanx man I dont have a hairdryer to use If you do this like what i did Dont make the fire touch the body Just get close to it And its fast to get it hot 2 minutes for both sides Or took probably less than that To fixed that problem |
10-22-2015, 08:10 PM | #95 |
I think ill permanently attached that grill And putty those tiny gaps Also i cant grind those stuffs stickin out of the hood The corner lense is the problem if you grind it So im thinking of using a putty to extend the hood a little Match it with the grill |
10-22-2015, 09:19 PM | #96 |
Newbie Join Date: Jul 2015 Location: Cupertino
Uiiju Sent from my iPhone using Tapatalk |
10-23-2015, 09:16 AM | #97 |
Pebble Pounder Join Date: Oct 2006 Location: Montreal
Wow this body is horrible. I definitely won't be picking one up until they sort these issues. I hope they do it quickly. I realize an experienced hobbyist can work around them but why should they have to when the original TF2 body was fine.
10-23-2015, 10:37 AM | #98 |
I was like you the first time i saw this kit in my hand But now its worth every penny for me Its part of the fun making it work hahahah Kind of like ase certified mechanic Doing body work hahahah |
10-23-2015, 10:42 AM | #99 |
| Re: RC4WD 1/10 Trail Finder 2 Kit w/Mojave II Hard Body ( PROBLEMS ) Next thing to do I came up with an idea on how to properly align that headlights to the hood Ill shaved some from the fender so i can push it more a little So itll align with the hood The bar holding the grill from the inside will push out the grill I think that should work Ill work on it later today |
10-23-2015, 12:30 PM | #100 |
the headlight/marker light assembly protrudes out past hood/fender on the 1:1 Hilux |
RC4WD 1/10 Trail Finder 2 Kit w/Mojave II Hard Body ( PROBLEMS ) - Similar Threads | ||||
RC4WD Mojave Body Set For Trail Finder 2 (Camo style) | rustneversleeps | RC4WD Trail Finder 2 | 5 | 09-04-2015 03:58 PM |
RC4WD Complete Mojave Body Set for Trail Finder 2 in both Yellow and White. | Rckcrwlr | General Scale Talk | 9 | 06-10-2012 09:08 PM |
