Go Back   RCCrawler Forums > Vendors > RCP Crawlers
Thread: Bastard Jr. Feedback, Support, & FAQ
Old 03-10-2009, 01:31 PM   #101
Originally Posted by robbio4422 View Post
the only reason the servo is sill there is cuz i ran out of zipties for the rear link plates and i dont wanna cut them just to remove the servo... im lazy i guess, i have my rear lock out on the way. heading out to by some lexan sheets today so i can make my own body panals so ill pick up zipties. im pretty impressed on how this chassis performs. i have had no problems witht the tabs so far! yay
Ah...that's your dig servo...got it. It looks so cleanly installed, I thought it was rear steer
Seems to be a solid little rig for sure...I'm anxious to try one myslef.
CreepyCrawl is offline   Reply With Quote
Old 03-10-2009, 08:30 PM   #102
Will the VF dig work with this chassis??? Thanks
Mayze is offline   Reply With Quote
Old 03-12-2009, 09:16 PM   #103
Hoods, hoods, hoods?
HTRDDZL is offline   Reply With Quote
Old 03-14-2009, 12:23 AM   #104
so far....key words. I had to Weld another bastard back up. You would think for the price they could use some 10G tabs so they could get decent pen. on their welds or get a better welder that knows how to properly fuse a joint. If your welder wants to call me i teach a local class at a Jr. college and pipe weld and fab for a living so pm me and let me know.
noRCal is offline   Reply With Quote
Old 03-19-2009, 11:25 AM   #105
well you are right. it is cleanly mounted. it was there for the rear stear. i was a bit out of it when i was posting last and i was thinking of a different pic i thought i had posted. but i have my rear lock outs installed now and the servo is gone... lol does anyone have a pic the the "servo mount" that was fabricated in the first set of pics. im not the best at fabrication and something a bit more clear would be AWSOME.
i just tried to install a behind the axle steer kit and it didnt fit. the front stocks are a bit to "vertical" for the linkage to perform correctly. has anyone else tried the BAS system with success?
robbio4422 is offline   Reply With Quote
Old 03-24-2009, 02:43 PM   #106
thanks Rockpiledriver. the link is pretty good for the most part. i would like to see a build thread because i am pretty new at a complete build. a have an artr and took it apart to mount it to a bastard chassis but still have ?.mounted stock shocks and the articulation seems alittle less than when it was on factory chassis. i do still have the 3 link front and rear but i am going to change it to 4 link rear with a tcs link plate. will this help or do you think i need different shock, maybe shorter? thanks again. links to build threads please.
cavie98 is offline   Reply With Quote
Old 03-26-2009, 10:13 PM   #107
been looking at tubers for a while and realy like the looks of this ome, but ive read most tuberrs are top heavy. how is this one? could one be built with tube upper half instead of solid rod thanks
jtrojan is offline   Reply With Quote
Old 03-27-2009, 09:01 AM   #108
this tuber is very lightweight and being top heavy is no issue.
on a side note, i took my bastard to 1st place at our local tuesday night comp. each week this truck(and my driving) get better and better.
elbo is offline   Reply With Quote
Old 03-27-2009, 10:03 AM   #109
Originally Posted by jtrojan View Post
been looking at tubers for a while and realy like the looks of this ome, but ive read most tuberrs are top heavy. how is this one?.............
I think the Bastard Jr. is a great choice! Especially if you're look'n to build a "LIGHT" rig!.......
IMO this chassis really excels with a "LIGHT" rig set-up!.......
axelsnapr is offline   Reply With Quote
Old 04-03-2009, 09:16 AM   #110
I wasn't going to wait. I found just cuting some aluminum panels to be better for mounting stuff anyway. The receiver is under the hood and the ESC mounts NICE with velcro under the rear overhead panel.
I'm also running the front uppers out board the chassis and redrilling the servo plate to spread the links further apart just enough to let the chassis fit between the links during compression. So far, it's working very well but I was hoping to be able to fit the dig mounted mini servo on the VF in to it. Oh well.
Krakker is offline   Reply With Quote
Old 05-05-2009, 10:38 PM   #111
So would it be safe to say the hoods are not coming?
Old 05-07-2009, 10:47 PM   #112
Default Bastard help
I just got a bastard chassis - i am new to crawling and could use a ltttle bit of guidence in building this - i have the front end done axels and stright links still have to droop the shocks all 4 - now on to the problem i am having the rear - cant get the axel to sit with the pinion poining at the trans without using 1 3/4 of shims on the tri link and it looks wrong to me - does anyone have some pictures to share with a decent way to put this together - i have a lot of pictures saved with other builds like mine but not all are the same and most dont show the link setup clearly - should i run the front links inside outside of the chassis and whaer is it best to mount them on the axel - should i ditch the tri link and go 4 link - bent links where and stright links where - can ya tell i need some help - thanks
chris
activethunderrc is offline   Reply With Quote
Old 05-08-2009, 03:19 PM   #113
you will have to swith your rear upper links to a 4 link. make or buy links to get the correct length to have the pinion pointing at the tranny. you should be able to leave the front upper tri link as it came out of the box, mounted inside the chassis.
Old 05-08-2009, 04:24 PM   #114
Or you can add,
a 25mm axial spacer (axa1422 or equivilent)
and a 3mm x 20 mm set screw.
The 25mm spacer goes in between the upper link mount and the Y adapter on the rear axle.
Rockpiledriver is offline   Reply With Quote
Old 05-24-2009, 04:16 AM   #115
any idea of when or if the molded hood is going to be out?
Wicked_Jester is offline   Reply With Quote
Old 06-18-2009, 08:44 AM   #116
what length stand offs do I need for the chassis, if I don't have an axial to rob parts from?
CronusTRD is offline   Reply With Quote
Old 06-18-2009, 11:05 AM   #117
55mm
Old 06-21-2009, 11:37 AM   #118
how about a losi version bastard. inboard the links. delrin skid...
MX70 is offline   Reply With Quote
Old 06-22-2009, 10:15 AM   #119
The Bastard chassis works fine with the Losi the way it is.
Introducing LBJ
Old 06-22-2009, 10:08 PM   #120
Sounds like a question alot of us have been asking....
You may edit your posts
