08-29-2016, 07:13 PM | #361 |
| Re: New Incision wheels coming....
Locked Up 2-56 acorn nuts + 3/8 2-56 set screws = scale win |
08-29-2016, 10:51 PM | #362 |
Rock Stacker Join Date: Feb 2015 Location: Vancouver, BC, Canada
| Re: New Incision wheels coming.... Nice.. are those center caps from Locked Up as well? Sent from my SM-G900W8 using Tapatalk Last edited by woody131; 08-29-2016 at 11:02 PM. |
08-30-2016, 06:08 AM | #363 | |
| Re: New Incision wheels coming.... Quote:
Gmade 1.9 RH03 wheel hubs (Silver) (4) | |
08-30-2016, 06:51 AM | #364 | |
12-02-2016, 09:04 AM | #365 |
What is the length of the stock hub hardware for Incision wheels? I know the threads are 2-56, but what is the length? Thanks.
12-02-2016, 09:08 AM | #366 |
| Re: New Incision wheels coming.... |
12-02-2016, 09:29 AM | #367 |
12-02-2016, 09:36 AM | #368 |
| Re: New Incision wheels coming.... The KMC wheels use 3/8 screws if you are running the center cap, use 1/4 if not running a center cap.
12-02-2016, 09:47 AM | #369 |
12-02-2016, 09:53 AM | #370 | |
01-06-2017, 05:01 PM | #371 |
Quarry Creeper Join Date: Aug 2008 Location: Sweden
How to they mount with Proline tires?
01-06-2017, 05:05 PM | #372 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
01-06-2017, 06:00 PM | #373 |
01-06-2017, 07:00 PM | #374 |
| Re: New Incision wheels coming.... It brought back memories of getting tires mounted on RC4WD wheels. I suppose longer hardware would have helped, but getting everything lined up and held in place while keeping the bead in position was not easy. It was the Pitbull PBX, so they are a narrow tire. I have mainly been using SSD wheels and several sets of the Chinese Method beadlocks and they are just super easy to get tires on, even Proline tires. My VP (Bully) wheels are also very easy to get tires on. |
01-06-2017, 07:03 PM | #375 | |
01-06-2017, 09:29 PM | #376 |
RCC Addict Join Date: Sep 2014 Location: Alberta
I mounted a set of the MR307 to my proline Hyrax and it was fine, other than the horribly fragile inner (backside) ring. Thing felt like it was made of pop can material, bent like crazy!!
01-06-2017, 09:30 PM | #377 |
You got a picture of the rear ring?
01-06-2017, 09:31 PM | #378 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
That doesn't sound good....
01-06-2017, 10:22 PM | #379 |
I don't have a photo, I ended up selling them. Sorry! Advice to anyone assembling these would be to tighten the rear screws evenly and in small increments. If you tighten one screw too much, it will bend the ring. Luckily, the ring was so malleable that once they're all tightened it will straighten itself out, for the most part. |
01-07-2017, 08:54 AM | #380 |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
Haven't had any issues mounting these to Proline, axial or Rc4wd tires. When mounting the ring it's common practice to work your way around while tightening to prevent ring distortion, same on 1:1 rings. These are a little different than other VP wheels like the methods and will require a little patience on your first attempt but easy once you figure them out. |
New Incision wheels coming.... - Similar Threads | ||||
Narrowing Stock XR10 wheels to fit Vanquish Incision Knuckles | The gasman | Tires and Wheels | 8 | 01-13-2014 06:46 PM |
vanquish XR-10 Incision Steering Knuckles and wheels | bikeboy | Axial XR10 | 35 | 03-07-2012 09:51 AM |
VP Incision Steering Knuckles/Stock Wheels | Mysterious | Axial XR10 | 9 | 12-11-2011 05:18 PM |
New 1.9 wheels coming | Gozer | Losi Mini-Rock Crawler | 4 | 10-21-2008 02:59 AM |
